meddyliol
Raspi 2 and Piface
Fri Mar 20, 2015 12:13 pm
I have a Rasp Rev 2 and a Piface. I have ordered one of the new Raspi's. My question is, the old Pi has a 26 pin GPIO's and the new one has 40 pins. Is there any way I can connect the new Pi to the Piface?
Cheers
Brian
Raspberry Pi B, Raspberry Pi 2, monitor, powered hub, mouse, keyboard and Volvo V50 car
leon_heller
Re: Raspi 2 and Piface
Fri Mar 20, 2015 12:23 pm
You need the new Piface Digital 2:
http://uk.farnell.com/piface/piface-dig ... EN-SKU-MDC
Mine works very well.
I think that the old Piface Digital should work with the RPi 2, but there might be mechanical problems unless you connect them with a ribbon cable.
Leon Heller
G1HSM
DirkS
Fri Mar 20, 2015 1:29 pm
leon_heller wrote:I think that the old Piface Digital should work with the RPi 2, but there might be mechanical problems unless you connect them with a ribbon cable.
Actually, ribbon cables are less likely to fit than the connectors used on add on boards...
leon_heller
Fri Mar 20, 2015 2:08 pm
You are right, I just checked it. Actually, I wasn't thinking of the connector but other components getting in the way.
Leon Heller
G1HSM
Fri Mar 20, 2015 2:19 pm
You will need the very latest PiFace libraries, there's a bug introduced with the 3.18.x kernels that breaks the PiFace code. The 2B can't run on anything earlier than a 3.18.5 kernel.
This is a doctor free zone.
meddyliol
Fri Mar 20, 2015 3:08 pm
Thanks for your replies. I decided to order a new one and will try and sell my old one.
meddyliol
Fri Mar 20, 2015 3:39 pm
As a matter of interest, I had my old one connected to the Pi via a ribbon cable and a port saver adapter. Does anyone know if a 40 pin port adapter is available? I could then get a standard 40 pin female - female ribbon cable. Or would it be better to get a male to female ribbon cable?
Hope I'm not confusing anyone, I think I know what I mean
Brian
bulletmark
Fri Mar 20, 2015 10:19 pm
I connected my original PiFace board to my new model 2 B using a $2 stacking header like this http://www.adafruit.com/products/1112. Propped the other side of the board up and put a couple of cable ties around the 2 boards to keep them together. Works well.
meddyliol
Sat Mar 21, 2015 8:36 am
But the stacking header is 26 pin, the new Pi is 40 pin. What am I missing?
Cheers
Brian
bulletmark
Sat Mar 21, 2015 8:49 am
meddyliol wrote:But the stacking header is 26 pin, the new Pi is 40 pin. What am I missing?
The original PiFace board is only 26 pin and they are exactly compatible with the first 26 pins of the new Pi 2.
killor
Mon Jun 01, 2015 12:32 pm
meddyliol wrote:Thanks for your replies. I decided to order a new one and will try and sell my old one.
Could you post a sketch of the measures Piface digital 2 board :?:
I'm trying to make a enclsure but can not find the measures. :cry:
Thank you very much
We have a discount for purchases made in ETSY site :o
Discount Codes :MAYTHE4TH :!:
