guachinver
resize partitions on a SD with debian?
Thu Jul 05, 2012 7:34 am
I'm new to linux and raspi, I filled my SD card with Debian, Apache, PHP, Mysql, etc. .., it works fine, now I only have 100MB free, on 8GB card
I have a debian install on VirtualBox in Windows Vista as host with a problem, gparted seems fine and sees the 3 partitions of my SD but GRUB does not work even if you reinstall it.
Before I use GParted. It is necessary after moving the swapfile partition with GParted to use GRUB?.
Another way to resize partitions?
A simple method for save the SD card contents?
Jim JKla
Re: resize partitions on a SD with debian?
Thu Jul 05, 2012 7:44 am
The raspi-config script on wheezy (debian) has a re-sizeing built into it you may find the answer there. ;)
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek ;)
If you find a solution please post it in the wiki the forum dies too quick
bredman
Thu Jul 05, 2012 7:45 am
To expand the image to fill the 8GB card, see the instructions at the end of this page
http://elinux.org/RPi_Easy_SD_Card_Setup
BenWiley4000
Thu Jul 05, 2012 9:46 pm
gparted is super useful for this but you can also potentially screw up everything ever. haha
Return to “Beginners”
