Traditional Chinese - 中文
Posted: Sat Jun 18, 2016 4:18 am
by noteasy2
歡迎大家以瀪體中文討論, 當中夾雜英文相信無問題
Re: Traditional Chinese - 中文
Posted: Sat Jun 18, 2016 3:28 pm
by MarkHaysHarris777
noteasy2 wrote:歡迎大家以瀪體中文討論, 當中夾雜英文相信無問題
Well, no problem for you, maybe !
:D
I just picked up Xiang Qi ... I have learned the traditional names of the pieces (and how to recognize them!) and have even started to learn the strategy; cool game !
Posted: Thu Jun 23, 2016 4:32 am
by noteasy2
中文化, 首先要設定所在時區:
# sudo raspi-config
https://www.raspberrypi.org/documentati ... -config.md
及加安裝系統中文碼顯示如
C.UTF-8
en_HK.ISO-8859-1
en_HK.UTF-8
en_US.UTF-8
yue_HK.UTF-8
zn_HK.BIG5-HKSCS
zn_HK.UTF-8
再安裝中文字形及中文輸入法介面
#sudo apt-get update
#sudo apt-get upgrade
#sudo apt-get install fonts-arphic-uming
Smart Common Input Method,SCIM,輸入法對照表及GTK+輸入法標準部件
https://packages.debian.org/zh-tw/jessie/scim
#sudo apt-get install scim scim-tables-zh scim-chewing scim-gtk-immodule
重新啟動
CTL+shift 開始中文輸入法
Posted: Sun Jul 03, 2016 12:08 am
by noteasy2
為了方便大家,可到一個RPi繁體中文網
Noteasy2
Posted: Sat Jul 09, 2016 7:40 am
by cjan
:D
look out double cannon check mate and you be fine.
Posted: Sat Jul 09, 2016 7:42 am
by cjan
noteasy2 wrote:中文化, 首先要設定所在時區:
# sudo raspi-config
及加安裝系統中文碼顯示如
C.UTF-8
en_HK.ISO-8859-1
en_HK.UTF-8
en_US.UTF-8
yue_HK.UTF-8
zn_HK.BIG5-HKSCS
zn_HK.UTF-8
再安裝中文字形及中文輸入法介面
重新啟動
CTL+shift 開始中文輸入法
你應該註明是香港使用者。
Posted: Mon Jul 18, 2016 11:29 pm
by noteasy2
其實只要方便大家看,不會再分地區吧!香港,臺灣,英國,法國也好,用繁體為主,方便溝通吧,反正在這中文使用也不多.
熱插拔SD卡后HDMI無信號
Posted: Tue Oct 18, 2016 2:14 am
by RickyS
我在樹莓派3工作時(有HDMI輸出),將SD卡拔下,然後給樹莓派斷電,再插上SD卡并給樹莓派上電,但此時HDMI不再有輸出,清問哪位前輩遇到過?解決的方法還請多多指導。
Re: 熱插拔SD卡后HDMI無信號
Posted: Fri Nov 04, 2016 5:24 am
by cjan
RickyS wrote:我在樹莓派3工作時(有HDMI輸出),將SD卡拔下,然後給樹莓派斷電,再插上SD卡并給樹莓派上電,但此時HDMI不再有輸出,清問哪位前輩遇到過?解決的方法還請多多指導。
as your said, unplug sd-card before shutdown then sd-card die.
Posted: Wed Nov 23, 2016 2:17 am
by masafumi_ohta
我們日文 Raspberry Pi 使用者群組是很榮幸在此向您宣佈保留事件歡迎 Eben Upton 再次光臨這裡東京在 12 月 11 - 下月 ! 你為何不加入我們如果您居住在東京或是您可以來這裡 ! !
如需更多詳細資訊請查看下面的連結。我們將有專題演講談從 Eben 與絕佳課程關於 Raspberry Pi 使用案例日本。此外我們將會有攤位展現酷炫新奇的 Raspberry Pis !
Https://raspberrypi.connpass.com/event/44902/
Non-Japanese 出席者都歡迎來到我們的活動 ! 如果您需要協助您註冊參加該活動 , 請寄電子郵件給我 . masafumi ohta atmark gmail dot com 。
希望能看到您有下一月 !
Posted: Mon Feb 06, 2017 4:31 am
by InitX
RPi 跨越国界
Posted: Mon Feb 06, 2017 11:31 pm
by noteasy2
http://noteasy2.kmdns.net/?p=184
Double network address when set up static address:
有兩個網址,同時出現在無線Wi-Fi 的dhcp 和 static address ,所以便要在dhcpdc.conf 內再
Re: 熱插拔SD卡后HDMI無信號
Posted: Fri Mar 31, 2017 5:51 am
by duncan tse
試試 format sad card, reinstall o/s . 很多時可以有效
Re: 熱插拔SD卡后HDMI無信號
Posted: Fri Mar 31, 2017 5:53 am
by duncan tse
1 Reformat sad card, 2 reinstall OS. 很多時有效的
Posted: Sat Jun 10, 2017 10:48 pm
by noteasy2
這是因為hdmi 輸出解象度不能自動對應monitor.可以手動設定/boot/config.txt
https://www.raspberrypi.org/documentati ... t/video.md
# 硬設定為聲音和影象同時輸出至HDMI
hdmi_drive=2
# 設定輸出DMT
hdmi_group=2
# 設定輸出解象度1024x768 XGA 60Hz (HDMI_DMT_XGA_60)
hdmi_mode=16
# 使畫面不會走出熒幕外
overscan_left=20
overscan_right=12
overscan_top=10
overscan_bottom=10
Posted: Wed Jan 31, 2018 4:03 pm
by wtshing
以下用書面語發問,方便香港以外的人看。
想問一下,市面上的iot 產品是不是會在上唔到網的時候失靈,原因是因為連接不到產品的cloud?
如果是的話,市面上的iot 產品可否用自己LAN 的WIFI 輸入指令?
而RPi 的話,會否出現以上問題?
我又可不可以立一個當WIFI 失效而轉行BT (CATCH-UP) 的指令?
謝謝。
Posted: Fri Feb 02, 2018 9:35 am
by bertlea
>> 取決於哪些iot設備,不能一概而論。
>> 大部分不依賴雲可以使用本地網絡(LAN或WIFI)。
而RPi 的話,會否出現以上問題?
>> RPi不依賴雲可以使用本地網絡(LAN或WIFI)。 你可以把它當作一個小型的獨立電腦。
>> 不明白你的問題。 BT也需要網絡, 而WIFI只是連接至網絡的方法之一。
Posted: Tue Mar 13, 2018 5:56 am
by noteasy2
大家好,
好似無人想發表. 不如討論, 我對新3D打印的硬件 (Palette +)介紹一下,它是附加在單頭打印機前的自動filament系統,它會把sta 檔中, 4色filament_依你打印先後,連成一條為你要打印物件的filament. 再使用你的單頭打印出4色物件。
Posted: Sun Jun 10, 2018 5:02 am
by sengo
Posted: Thu Feb 21, 2019 3:53 pm
by BensonChiang
繁體中文萬歲! (灑花)
Posted: Fri Apr 12, 2019 10:23 am
by Issac
你好 我想問一下 關於 chormeium 的設定 我想控制關閉或打開"詢問是否翻譯網頁" 的選項 除了在 設定→進階→語言 內設定外, 用 Terminal的方式用指令去修改 是在 .config/chormium/Default/ 裡面的哪一個設定黨能夠 做設定? 謝謝
