bdacasc
Ports mgmt pkg
Thu Nov 29, 2018 8:11 am
Greetings!
Noob on Freebsd here
Can someone please explain what I am doing wrong here?
I have been trying to follow this guide
https://fosskb.in/2017/05/26/installing ... pberry-pi/
All is fine and dandy until the last part.
When I do
cd /usr/ports/ports-mgmt/pkg
make install
I get :
root@rpi2:~ # cd /usr/ports/ports-mgmt/pkg
root@rpi2:/usr/ports/ports-mgmt/pkg # make install
===> Building/installing dialog4ports as it is required for the config dialog
===> Cleaning for dialog4ports-0.1.6
/!\ ERROR: /!\
Ports Collection support for your FreeBSD version has ended, and no ports are
guaranteed to build on this system. Please upgrade to a supported release.
No support will be provided if you silence this message by defining
ALLOW_UNSUPPORTED_SYSTEM.
*** Error code 1
Stop.
make[3]: stopped in /usr/ports/ports-mgmt/dialog4ports
*** Error code 1
Stop.
make[2]: stopped in /usr/ports/ports-mgmt/dialog4ports
===> Options unchanged
/!\ ERROR: /!\
*** Error code 1
Stop.
make[1]: stopped in /usr/ports/ports-mgmt/pkg
*** Error code 1
Stop.
make: stopped in /usr/ports/ports-mgmt/pkg
Here is the hardware
(lshw from a diffrent sd card running stretch )
description: ARMv7 Processor rev 5 (v7l)
product: Raspberry Pi 2 Model B Rev 1.1
serial: 000000002306d053
width: 32 bits
capabilities: smp
*-core
description: Motherboard
physical id: 0
*-cpu:0
description: CPU
product: cpu
physical id: 0
bus info: cpu@0
capacity: 900MHz
capabilities: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm cpufreq
*-cpu:1
description: CPU
product: cpu
physical id: 1
bus info: cpu@1
capacity: 900MHz
*-cpu:2
description: CPU
product: cpu
physical id: 2
bus info: cpu@2
capacity: 900MHz
*-cpu:3
description: CPU
product: cpu
physical id: 3
bus info: cpu@3
capacity: 900MHz
*-memory
description: System memory
physical id: 4
*-usbhost
product: DWC OTG Controller
vendor: Linux 4.14.79-v7+ dwc_otg_hcd
physical id: 1
bus info: usb@1
logical name: usb1
version: 4.14
capabilities: usb-2.00
configuration: driver=hub slots=1 speed=480Mbit/s
*-usb
description: USB hub
product: SMC9514 Hub
vendor: Standard Microsystems Corp.
physical id: 1
bus info: usb@1:1
version: 2.00
configuration: driver=hub maxpower=2mA slots=5 speed=480Mbit/s
*-usb:0
description: Generic USB device
product: SMSC9512/9514 Fast Ethernet Adapter
physical id: 1
bus info: usb@1:1.1
version: 2.00
configuration: driver=smsc95xx maxpower=2mA speed=480Mbit/s
*-usb:1
product: 802.11n WLAN Adapter
vendor: Realtek
physical id: 4
bus info: usb@1:1.4
version: 2.00
serial: 00e04c000001
configuration: driver=rtl8192cu maxpower=500mA speed=480Mbit/s
*-network:0
description: Ethernet interface
physical id: 2
logical name: eth0
serial: b8:27:eb:06:d0:53
capacity: 100Mbit/s
capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=smsc95xx driverversion=22-Aug-2005 duplex=full firmware=smsc95xx USB 2.0 Ethernet ip=192.168.10.44 link=yes multicast=yes port=MII speed=100Mbit/s
*-network:1 DISABLED
description: Wireless interface
physical id: 3
bus info: usb@1:1.4
logical name: wlan0
serial: 74:da:38:1a:b3:b9
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=rtl8192cu multicast=yes wireless=unassociated
What is it that I do not understand?
Command me, dark lords
Return to “FreeBSD”
