Battant
Unable to compile gettext-0.19.8.1
Thu Dec 28, 2017 4:07 pm
I tried to compile gettext-0-19-8-1 imy rasbery pi model b with FReebsd 12 (raspbsd) but i get this error
Make
/use/ports/devel/gettext-tools/work/gettext-0.19.8.1/gettext-tools/intl/.libs/libinl.so ; undefined référence to “ptread_create”
Cc : error : linker command failed with exit code 1 (use -v to see invocation )
Error code 1
Configuration
Freebsd 12.0 (raspbsd) arm6 on raspberry Pi model B
Could you help me please ?
Tanks for your support
Best regards
Battant
Battant
Re: Unable to compile gettext-0.19.8.1
Fri Dec 29, 2017 11:40 am
Here is the compliete gettext compile output message
/usr/ports/devel/gettext/work # ls
.build_done.gettext._usr_local
.configure_done.gettext._usr_local
.extract_done.gettext._usr_local
.patch_done.gettext._usr_local
stage
root@raspberry-pi:/usr/ports/devel/gettext/work # cd ..
root@raspberry-pi:/usr/ports/devel/gettext # make install
===>  Staging for gettext-0.19.8.1
===>   gettext-0.19.8.1 depends on executable: gettext - found
===>   gettext-0.19.8.1 depends on executable: msgfmt - not found
===>  Building for gettext-tools-0.19.8.1
/usr/bin/make  all-recursive
Making all in doc
Making all in intl
Making all in gnulib-lib
/usr/bin/make  all-am
Making all in libgrep
Making all in src
/bin/sh ../libtool  --tag=CC    --mode=link cc   -g -O2    -o recode-sr-latin recode_sr_latin-recode-sr-latin.o  recode_sr_latin-filter-sr-latin.o ../gnulib-lib/libgettextlib.la  ../intl/libintl.la
libtool: link: cc -g -O2 -o .libs/recode-sr-latin recode_sr_latin-recode-sr-latin.o recode_sr_latin-filter-sr-latin.o  ../gnulib-lib/.libs/libgettextlib.so /usr/ports/devel/gettext-tools/work/gettext-0.19.8.1/gettext-tools/intl/.libs/libintl.so -L/usr/local/lib ../intl/.libs/libintl.so -lm -lncurses -Wl,-rpath -Wl,/usr/local/lib
/usr/ports/devel/gettext-tools/work/gettext-0.19.8.1/gettext-tools/intl/.libs/libintl.so: undefined reference to `pthread_create'
cc: error: linker command failed with exit code 1 (use -v to see invocation)
*** [recode-sr-latin] Error code 1
make[6]: stopped in /usr/ports/devel/gettext-tools/work/gettext-0.19.8.1/gettext-tools/src
1 error
*** [all] Error code 2
make[5]: stopped in /usr/ports/devel/gettext-tools/work/gettext-0.19.8.1/gettext-tools/src
1 error
*** [all-recursive] Error code 1
make[4]: stopped in /usr/ports/devel/gettext-tools/work/gettext-0.19.8.1/gettext-tools
1 error
make[3]: stopped in /usr/ports/devel/gettext-tools/work/gettext-0.19.8.1/gettext-tools
1 error
===> Compilation failed unexpectedly.
Try to set MAKE_JOBS_UNSAFE=yes and rebuild before reporting the failure to
the maintainer.
*** Error code 1
Stop.
make[2]: stopped in /usr/ports/devel/gettext-tools
*** Error code 1
Stop.
make[1]: stopped in /usr/ports/devel/gettext-tools
*** Error code 1
Stop.
make: stopped in /usr/ports/devel/gettext
could you help me please ?
Thansks for your support
Best regards
Battant
Return to “FreeBSD”
