bsdnilux
FreeBSD: No Drivers SCFB available
Tue Dec 26, 2017 10:28 am
Hello
I have created xorg.conf with :
Section "Device"
Identifier "Generic FB"
Driver "scfb"
Option "NoAccel" "True"
# Option "ShadowFB" "False" #
EndSection
But the log of startx tells that no module for driver "scfb" can be found. It seems that X11 will not work on Freebsd.
uname -a gives: FreeBSD generic 12.0-CURRENT #0 r327038, 2017 arm64
Any help would be greatly helpful.
k-pi
Re: FreeBSD: No Drivers SCFB available
Tue Dec 26, 2017 2:44 pm
bsdnilux
Tue Dec 26, 2017 3:40 pm
Thank you
I reinstall it ! ;) and I will try it,
(my sd card will have: ftp://ftp.freebsd.org/pub/FreeBSD/snaps ... MAGES/12.0)
ftp://ftp.freebsd.org/pub/FreeBSD/snaps ... 038.img.xz
from https://wiki.freebsd.org/FreeBSD/arm/Raspberry%20Pi from RPI3 info link.
I have reinstalled, installed the xf86-video-scfb !!
I read here:
https://www.freebsd.org/doc/handbook/x-config.html
Xorg -configure does not do anything. It tells me : list of video drivers modesettings and scfb.
scfb trace: probe strar
no devices to configure. configuration failed.
pkg install   xf86-video-scfb  twm xclock  xinit less
LeaveVT
It enters into VT, but leaves it immedialy :( X11 does not stay, just vanish to tty after 1 second.
I can see the TWM loaded, into framebuffer, but i am into TTY (no X11) :(
SOLVED !!
I needed to install xorg (1gb) and to remove /etc/X11/xorg.conf
pkg install twm xorg xterm xauth
Done ! X11 works on RPI3 !!!!
Return to “FreeBSD”
