vxla
altq support on FREEBSD
Sat Nov 11, 2017 1:45 am
I'm running 12.0-CURRENT on a fresh install on my pi. Is altq support possibly by just recompiling my kernel with the necessary support?
Is there a config file available to use as a template?
TIA!
allfox
Re: altq support
Sat Nov 11, 2017 10:14 am
Google tells me ALTQ is the BSD networking scheduler.
I use Raspbian's tc command to control the qdisc on Linux network interface to do the same thing. It works out of the box, no kernel rebuilding is needed, unless you need some specific functions.
I didn't know Pi is able to run BSD now. I thought RISC OS is the only non Linux OS.
Re: altq support
Sat Nov 11, 2017 11:47 am
TIA!
As you mention version 12, I would guess you mean FreeBSD / RaspBSD ??
Obviously the developers of the Operating System would be the ideal place to ask questions ??
Last edited by fruitoftheloom on Sat Nov 11, 2017 11:54 am, edited 2 times in total.
Retired disgracefully.....
Re: altq support
Sat Nov 11, 2017 11:51 am
NetBSD
https://wiki.netbsd.org/ports/evbarm/raspberry_pi/
FreeBSD (RaspBSD)
https://wiki.freebsd.org/FreeBSD/arm/Raspberry%20Pi
http://www.raspbsd.org/
vxla
Re: altq support
Sun Nov 12, 2017 12:23 am
my bad, i thought these fora had folks running freebsd on pi.
cheers.
Re: altq support
Sun Nov 12, 2017 6:33 am
cheers.
Raspberry Pi Foundation / Raspberry Pi Trading de-facto Operating System for RPi SBC & CM is a customised Raspbian Operating System.
Whilst many users do run other Operating Systems such as BSD not many participate here, see the forum section:
viewforum.php?f=56
mahjongg
Re: altq support on FREEBSD
Sun Nov 12, 2017 1:14 pm
moved post to "OTHER OS", added "on freebsd" to subject line.
DirkS
Sun Nov 12, 2017 1:16 pm
Why not 'FreeBSD'?
mahjongg
Tue Nov 14, 2017 11:05 am
right you are...
Return to “FreeBSD”
