Sarachiel
Raspberry PI + Java + DB
Tue Aug 05, 2014 6:52 pm
Hello there,
I've been experimenting with my RPI (rev B) latelty. I created a java application in which I used HSQLDB, but the performance is horrible. Does anyone had similar issues ? Is there any other DB to implement with Java that will run smoothly ?
Thanks in advance for Your answers :)
ltorok
Re: Raspberry PI + Java + DB
Wed Aug 06, 2014 4:29 am
Try H2 Database Engine, url: http://www.h2database.com/html/main.html
Performance is very good!
henrik
Sat Aug 23, 2014 1:16 pm
Sarachiel wrote:Hello there,
JavaDB is included in the Oracle JDK that is distributed with the Raspberry Pi OS images. It's basically a branded version of Apache Derby and works fine as a simple in-memory SQL database. Plenty of tutorials etc online.
http://docs.oracle.com/javadb/10.8.3.0/ ... index.html
Henrik - Oracle Java team
Howard
Wed Sep 03, 2014 10:55 pm
From my trials (not on Pi) Derby is rather large and uses lots of memory.
Of all the databases I tried I ended up with H2 - good SQL compliance, modest memory usage, supports in-memory database (use a connection URL something like: "jdbc:h2:nioMapped:h2/db;LOG=0;LOCK_MODE=0;UNDO_LOG=0") and is fast.
bullen
Sat Jan 20, 2018 1:38 pm
You can use my distributed HTTP JSON NIO async. to async. Java database ROOT:
https://github.com/tinspin/rupy/wiki/Storage
https://github.com/tinspin/rupy - A tiny Java async HTTP application server.
Return to “Java”
