Page 2 of 2
Re: status of java on raspbian.
Posted: Mon Nov 18, 2013 10:23 am
by mcgyver83
I need only to run a small gui (jdownloader2) without any other java app, I need a JVM that doesn't need too much resources to show 2D stuff.
Posted: Mon Nov 25, 2013 8:50 am
by mcgyver83
So for not 3D or graphic stuff, only 2D?
Posted: Sat Mar 22, 2014 4:52 pm
by johnniepop
Maybe you should consider updating the information, since few days ago the official release of JDK8 for Raspberry Pi was made by Oracle. You can check it out here: http://www.oracle.com/technetwork/java/ ... 33151.html if you haven't already.
Cheers!
Posted: Wed Mar 26, 2014 7:58 am
by mcgyver83
I'll check!
Any idea about the performances? java7 vs java8?
Re: Status of Java on Raspbian
Posted: Wed Mar 26, 2014 8:15 am
by Fidelius
mcgyver83 wrote:Any idea about the performances? java7 vs java8?
Yes, please see this thread : Java ‹ Updating Java on Raspbian from 1.7.0 to 1.8.0
radu1337 wrote:So I started and stopped the Minecraft server with both versions of java:
1.7.0_40-b43 => 73 seconds
1.8.0-b129 => 51 seconds
The 1.8.0 version sometimes even starts under 50 seconds.
And this is so for normal "old" Java programs running on the new JVM 8, i.e. without exploiting new Java 8 features. OK, so Minecraft may not be a typical normal program, so we can't expect such a Java 8 performance increase for all our Java programs. But still, it doesn't use any special features of Java 8.
If however you use some new Java 8 features like its hardware accelerated 2D and 3D operation (JavaFX), you will see performance increases in an order of magnitude. For example the little Raspberry Pi sprite demo I did with Java 8 some time ago isn't possible with Java 7 on the Pi.
Java 8 is very nice indeed and an important update, in particular for our relatively slow Pi which needs any co-processor (GPU) help it can.
When will Raspbian include Java 8 as default? Please see Oracle's announcement a week ago here:
Henrik wrote:I expect to see the Raspberry Pi Linux repository and Raspbian etc images to be updated with Oracle JDK 8 sometime soon.
Henrik - Oracle Java team
Posted: Thu Apr 16, 2015 9:05 am
by xranby
IcedTea 2.5.5 has been released.
http://blog.fuseyism.com/index.php/2015 ... -released/
This free software OpenJDK release includes Edward Nevills latest ARM32 JIT that will enable boosted performance on all singlecore ARMv6 Raspberry PI systems. The new JIT is also more stable to use on the new multicore ARMv7 Raspberry PI 2 systems.
I hope raspbian can import the new
openjdk-7 7u79-2.5.5-1
package that is found in debian.
Posted: Fri Apr 17, 2015 12:36 am
by plugwash
I've recently uploaded 7u75-2.5.4-3+rpi1 which has the new jit to.raspbian jessie. I expect 2.5.5 to come through to both wheezy and jessie in-time but i'm currently watching what happens in Debian.
Anyone know how the new jit compares to oracle's propietary one?
Posted: Mon Jun 08, 2015 3:14 pm
by xranby
plugwash wrote:I've recently uploaded 7u75-2.5.4-3+rpi1 which has the new jit to.raspbian jessie. I expect 2.5.5 to come through to both wheezy and jessie in-time but i'm currently watching what happens in Debian.
There is something missing in the 7u75-2.5.4-3+rpi1 package it looks like the new jit is included in the sourcetree but disabled at runtime. I will have to examine the debian package to see if there is a missing build flag.
I tried to benchmark the new jit on the raspberry pi 1 and compared it with edward nevills reference build where the new jit work
http://openjdk.linaro.org/arm32jit/
I used SciMark 2.0a
http://math.nist.gov/scimark2/download_java.html
7u75-2.5.4-3+rpi raspbian
Composite Score: 2.773446704209826
FFT (1024): 1.6724202743674736
SOR (100x100): 6.285735331895986
Monte Carlo : 0.6632359390308941
Sparse matmult (N=1000, nz=5000): 2.4615385518271573
LU (100x100): 2.78430342392762
Edwards arm32 microJIT
Composite Score: 9.7088881566708
FFT (1024): 6.936563765379863
SOR (100x100): 17.71098303263207
Monte Carlo : 3.3608204434787985
Sparse matmult (N=1000, nz=5000): 9.579045785957213
LU (100x100): 10.957027755906072
oracle jdk8 b132
Composite Score: 23.92186747096536
FFT (1024): 21.518957822414773
SOR (100x100): 48.46466057515884
Monte Carlo : 8.494792808844737
Sparse matmult (N=1000, nz=5000): 20.277227914236352
LU (100x100): 20.8536982341721
The new OpenJDK JIT is 3 times faster compared to the old jit on a raspberry Pi 1
Oracles properitary JIT version is still about 2 times faster compared to the new jit in OpenJDK.
Posted: Sat Jun 20, 2015 1:56 pm
by plugwash
BTW i've just uploaded 7u79-2.5.5-1~deb8u1+rpi1 , might want to check the jit status with that.
Posted: Mon Jun 22, 2015 2:49 pm
by mcgyver83
So it's available via apt ?
Re: STICKY: status of java on raspbian.
Posted: Wed Apr 04, 2018 3:48 pm
by Teapot
Liberica JDK for Raspberry Pi
Versions: 10, 9.0.4, 9.01
https://www.bell-sw.com/java-for-raspberry-pi.html
Release Notes: "Liberica is a 100% open-source Java 10 implementation for Raspberry Pi. It is built from OpenJDK which BellSoft contributes to, is thoroughly tested and passed the JCK provided under the license from OpenJDK. It also contains JavaFX 10 with hardware-accelerated EGL support and Device IO API as additional modules. We currently provide two binaries suitable for different Raspberry Pi versions and OS combinations"
https://www.bell-sw.com/liberica-release-notes.html
