BrendonShaw
Java Home not define (wso2ei-6.4.0 installation)
Fri Nov 23, 2018 9:13 am
I am trying to install wso2ei-6.4.0, but it will not run due to the following error messages:
Error: JAVA_HOME is not defined correctly.
 CARBON cannot execute java
I have executed Java -verison and have the following return
java version "1.8.0_65"
Java(TM) SE Runtime Environment (build 1.8.0_65-b17)
Java HotSpot(TM) Client VM (build 25.65-b01, mixed mode)
I know the java directory, using Java -which
/usr/bin/java
How do I run Java from any of the directory to execute the installation of wso2ei-6.4.0?
Return to “Java”
