ajtwlsdlqp
Help Plz UART Comm with Java
Sun Feb 18, 2018 8:51 am
i want to do UART Rx Comm with Java
i linked
pi's Rx <---> Device Tx
pi's GND <-> Device GND
pi's 5V <----> Device 5V
and i try
this site ('http://pi4j.com/example/serial.html") and
this site ("https://eclipsesource.com/de/blogs/2012 ... -and-rxtx/")
result is same -> NonsuchPort
result Pi4J
<-- The Pi4J Project -->
Serial Communication Example
| PRESS CTRL-C TO EXIT |
| Connecting to: /dev/ttyS0 (1200,8N1) {FC:NONE} |
| We are sending ASCII data on the serial port every 1 second. |
| Data received on serial port will be displayed below. |
==>> SERIAL SETUP FAILED : Failed to SET terminal attributes for the serial port. (Error #5)
result RxTx
javax.comm.NoSuchPortException
at javax.comm.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:105)
at TwoWaySerialComm.connect(TwoWaySerialComm.java:13)
at TwoWaySerialComm.main(TwoWaySerialComm.java:82)
i want use pi's 8, 10 (GPIO 14, 15)
/dev/ttyAMA0
i search that pi3's case need turn off BLE so i turn off using
$sudo vi /boot/config.txt
add at last line
#bt disabled
dtoverlay=pi3-disable-bt
$sudo systemctl disable hciuart
$sudo reboot -h
$dmesg | grep Bluetooth
plz help me.. i just want to Rx Function in pi3
os version is ubuntu mate
and i already try update and upgrade ..
thanks
Gaou
Re: Help Plz UART Comm with Java
Thu Mar 01, 2018 8:18 am
I've had many problems using Pi4J in the past, UART wasn't stable etc...
Try using JSerialCom (http://fazecast.github.io/jSerialComm/), since then i have no problem using the pi3 serial port.
Dont forget you should hace these lines in the /boot/config.txt
enable_uart=1
dtoverlay=pi3-disable-bt (specific for Pi3)
And in the /boot/cmdline.txt, delete this
console=serial0,115200
Good luck
Gaou
Return to “Java”
