Andrea_07
JavaFX application on Raspberry Pi 3
Tue Oct 11, 2016 1:52 pm
Hi everybody!
I am dealing with the problem, that my JavaFX application does not work on my Raspberry.
The pre-installed version is Java 1.8.0_65.
Online i found out, that with Java 8u33, Oracle canceled the support for JavaFX on ARM devices, which causes my error on start of the application.
How can i install an older version of Java (easily)? When i try to deinstall Java8, it automatically tries to install Java7, except i make a super complicated command (i already found out about that one)...
I already tried to download 8u31 manually and install it, but i failed... (with apt-get install alternative)
Thank you in Advance!!!
Best, Andrea :mrgreen:
Andrea_07
Re: JavaFX application on Raspberry Pi 3
Wed Oct 12, 2016 9:56 am
Thank you very much!
How could i not manage to find that post? :?: :?: :?:
It works, with limitations (broken layout, not closeable) but well, it works. Thank you!
Return to “Java”
