Woll
Difference Between Bluej & Greenfoot
Wed Oct 07, 2015 9:19 pm
I've just installed the new Jessie Raspbian on to my old Raspberry Model B, which I'm planning on using for projects.
I was just wondering what is the difference between the Bluej Java IDE & the Greenfoot Java IDE?
I like the updated Raspbian thou. It's looking better. I like the time setting update, hopefully it will reset itself automatically between GMT & BST. I'll wait until any bugs are ironed out before updating my main Raspberry 2Bs. ;)
PS I like Linux better than Windows. :lol:
Who ate all the Pi's? Who ate all the Pi's?
Boris Johnson, Boris Johnson,
xranby
Re: Difference Between Bluej & Greenfoot
Fri Oct 09, 2015 11:03 am
BlueJ is the editor, BlueJ allows you to work with Objects and create any java application.
BlueJ allow you run code by instantiating objects by launching a class by using its public constructor.
A BlueJ application do not need to have a "main" method.
while
Greenfoot builds a framework around the BlueJ editor.
Greenfoot allows you to by point and click open a screen set a background and populate a world by adding objects to the world.
Greenfoot comes with an API that allows you for example to easily extand and update object in this world to become say a dolphin that swims around in the world by only having you to add a a handful lines of code to the dolphin class that tells what the dolphin should do when it receive an update.
Xerxes Rånby @xranby I once had two, then I gave one away. Now both are in use every day!
twitter.com/xranby
Woll
Fri Oct 09, 2015 11:58 am
Thanks for the reply.
I think Java is a bit over my head at the moment.
Hopefully MagPi will have some basic code now it's supplied with Raspbian.
Return to “Java”
