tietze111
Can't change System Property in Java (java -D)
Wed Sep 30, 2015 1:03 pm
I tried to follow this Tutorial: http://www.oracle.com/technetwork/artic ... 77662.html
I installed Java and when I execute "java -version" I get the following output:
java version "1.8.0_60"
Java™ SE Runtime Environment (build 1.8.0_60-b27)
Java HotSpot™ Client VM (build 25.60-b23, mixed mode)
My problem is that I can't change the system property sun.security.smartcardio.library. It's at the end of the second section (install Java) in the Tutorial.
What I tried is:
java -D sun.security.smartcardio.library=/usr/lib/arm-linux-gnueabihf/libpcsclite.so.1
But I always get this error:
Error: Could not find or load main class sun.security.smartcardio.library=.usr.lib.arm-linux-gnueabihf.libpcsclite.so.1
What did I do wrong?
Thank you in advance and have a nice day,
tietze111
xranby
Re: Can't change System Property in Java (java -D)
Wed Sep 30, 2015 1:40 pm
tietze111 wrote:...
What I tried is:
it is the space between the -D and sun.security.smartcardio.library=/usr/lib/arm-linux-gnueabihf/libpcsclite.so.1 that cause the problem
use
java -Dsun.security.smartcardio.library=/usr/lib/arm-linux-gnueabihf/libpcsclite.so.1
also check with ldd that libpcsclite.so.1 can load all of its dependencies
ldd /usr/lib/arm-linux-gnueabihf/libpcsclite.so.1
Xerxes Rånby @xranby I once had two, then I gave one away. Now both are in use every day!
twitter.com/xranby
tietze111
Wed Sep 30, 2015 9:01 pm
Thank you for your help! :)
When using the command without the space the following output comes (java command usage help):
Usage: java [-options] class [args...]
(to execute a class)
or java [-options] -jar jarfile [args...]
(to execute a jar file)
where options include:
-d32 use a 32-bit data model if available
-d64 use a 64-bit data model if available
-client to select the "client" VM
-server to select the "server" VM
-minimal to select the "minimal" VM
The default VM is client.
-cp <class search path of directories and zip/jar files>
-classpath <class search path of directories and zip/jar files>
A : separated list of directories, JAR archives,
and ZIP archives to search for class files.
-D<name>=<value>
set a system property
-verbose:[class|gc|jni]
enable verbose output
-version print product version and exit
-version:<value>
Warning: this feature is deprecated and will be removed
in a future release.
require the specified version to run
-showversion print product version and continue
-jre-restrict-search | -no-jre-restrict-search
include/exclude user private JREs in the version search
-? -help print this help message
-X print help on non-standard options
-ea[:<packagename>...|:<classname>]
-enableassertions[:<packagename>...|:<classname>]
enable assertions with specified granularity
-da[:<packagename>...|:<classname>]
-disableassertions[:<packagename>...|:<classname>]
disable assertions with specified granularity
-esa | -enablesystemassertions
enable system assertions
-dsa | -disablesystemassertions
disable system assertions
-agentlib:<libname>[=<options>]
load native agent library <libname>, e.g. -agentlib:hprof
see also, -agentlib:jdwp=help and -agentlib:hprof=help
-agentpath:<pathname>[=<options>]
load native agent library by full pathname
-javaagent:<jarpath>[=<options>]
load Java programming language agent, see java.lang.instrument
-splash:<imagepath>
show splash screen with specified image
See http://www.oracle.com/technetwork/java/ ... index.html for more details.
"ldd /usr/lib/arm-linux-gnueabihf/libpcsclite.so.1" gives me the following output:
linux-vdso.so.1 (0x7efa0000)
/usr/lib/arm-linux-gnueabihf/libarmmem.so (0x76f83000)
libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0x76f5e000)
librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0x76f47000)
libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0x76f1f000)
libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0x76de2000)
/lib/ld-linux-armhf.so.3 (0x54b15000)
Does it mean that it can load all dependencies or is there an error?
Best regards,
tietze111
xranby
Wed Sep 30, 2015 9:36 pm
tietze111 wrote:Thank you for your help! :)
This is as expected, you have successfully changed a system property in Java using the -D flag and thus solved the question you asked.
however you have not specified what program to run!
The tutorial only mention that
"Note: The source code for the examples shown in this article is available at https://bitbucket.org/johanvos/javafx-pi-nfc "
it is unfortunate that the tutorial assume everyone know what to do with the sourcecode
i can only give you a quick outline what you need to do since I have never tested compile or use this project:
You need to
1.checkout the source-code to this example project using mercurial,
2. compile it using maven and then
3. run the compiled jar!
hg clone https://bitbucket.org/johanvos/javafx-pi-nfc
cd javafx-pi-nfc/NfcPi
mvn compile
java -Dsun.security.smartcardio.library=/usr/lib/arm-linux-gnueabihf/libpcsclite.so.1 -jar some-generated.jar
tietze111 wrote: "ldd /usr/lib/arm-linux-gnueabihf/libpcsclite.so.1" gives me the following output:
Best regards,
tietze111
This means that the libpcsclite.so.1 shared library find its dependencies. This is good news.
twitter.com/xranby
Return to “Java”
