imdavid95
PARENT DETECTOR (PIR MODULE)
Sat May 31, 2014 11:02 pm
Salve a tutti, cercavo di seguire questa guida --> http://www.raspberrypi.org/learning/parent-detector/
Il problema è che quando scrivo il codice in python per il modulo pir e lo compilo, mi da i seguenti errori:
riga 1: import: not found
riga 2: import: not found
riga 4: sensorPin: not found
riga 6: syntax error: word unexpected (expercting")")
Ho provato a reinstallare la libreria gpio ma da ancora lo stesso errore.
premetto che io sono un programmatore ma non ho mai utilizzato sistemi linux, quindi siate il più chiari possibile, grazie per la pazienza.
DeeJay
Re: PARENT DETECTOR (PIR MODULE)
Sun Jun 01, 2014 6:26 am
Add a new first line - missing from the tutorial -
#!/usr/bin/env python
import RPi.GPIO as GPIO
import time
sensorPin = 7
imdavid95
Sun Jun 01, 2014 1:11 pm
DeeJay wrote:Add a new first line - missing from the tutorial -
import time
sensorPin = 7
Thank you so much!
I have another problem at step 5, when i run the program:
File " ./pirCamere.py", line 5, in <module>
import picamera
ImportError: no module named picamera
I have tested the camera module and it works.
DeeJay
Sun Jun 01, 2014 1:43 pm
See Step 4 of the same tutorial.
"To control the Camera Board using Python we need to install a module called picamera. Use the following commands to do this at the Linux prompt:"
imdavid95
Sun Jun 01, 2014 4:28 pm
DeeJay wrote:See Step 4 of the same tutorial.
I did it but it don't work, the same error
DeeJay
Sun Jun 01, 2014 9:13 pm
It works for me, so I don't think I can be of any more help.
(Just to check: do you have a file named picamera.py in the directory from which you are running these tests? That would confuse the import mechanism... )
MattHawkinsUK
Sun Jun 01, 2014 9:57 pm
Make sure you do :
sudo apt-get update
before installing picamera.
My Raspberry Pi blog and home of the BerryClip Add-on board : http://www.raspberrypi-spy.co.uk/
Follow me on Google+, Facebook, Pinterest and Twitter (@RPiSpy)
Mon Jun 02, 2014 8:54 am
You will also want to do
sudo raspi-config
to enable the camera (but do not choose the reboot on exit this time) because you'll also want
sudo apt-get install rpi-update && sudo rpi-update && sudo reboot
to get the latest firmware.
This is a doctor free zone.
imdavid95
Mon Jun 02, 2014 9:51 am
I did all you write, here ( https://www.mediafire.com/?7k8o4lxwufm4jg0 ) there is the link to download the screenshot of the photo, where you can see the error message.. i can't connect the raspberry on internet
imdavid95
Tue Jun 03, 2014 8:15 pm
Please i need really help.. is for my Term Paper
Tue Jun 03, 2014 8:31 pm
So you don't have a internet connection. Please post the output from the following
ifconfig -a
route -n
ping -c3 192.168.ggg.ggg # your home router/gateway address
cat /etc/resolv.conf
ping -c3 8.8.8.8 # google
ping -c3 google.com
On your windows machine
ipconfig /all
Check the wire between your RPi and your home router, check the LEDs on both ends of the wire.
imdavid95
Sat Jun 07, 2014 2:19 pm
I connect the raspberry on internet and i run the .py and it worked.
At step 6 when i run the program, when PI see the movement and start recording it crash and write on the console:
pi@raspberrypi ~ $ sudo ./pirCamera.py
GPIO pin 7 is HIGH
mmal: mmal_vc_port_parameter_set: failed to set port parameter 32:2:ENOSYST
File "./pirCamera.py", line 30, in <module>
    cam.start_recording(fileName)  # new
File "/usr/lib/python2.7/dist-packages/picamera/camera.py", line 795, in start_recording
    self, camera_port, output_port, format, resize, **options)
File "/usr/lib/python2.7/dist-packages/picamera/encoders.py", line 431, in __init__
    parent, camera_port, input_port, format, resize, **options)
File "/usr/lib/python2.7/dist-packages/picamera/encoders.py", line 124, in __init__
    self._create_encoder(**options)
File "/usr/lib/python2.7/dist-packages/picamera/encoders.py", line 491, in _create_encoder
prefix="Enable to set SEI")
File "/usr/lib/python2.7/dist-packages/picamera/exc.py", line 112, in mmal_check
raise PiCameraMMALError(status, prefix)
picamera.exc.PiCameraMMALError: Enable to set SEI: Function not implemented
Thank you for the help.
davidevb6
Tue Jun 24, 2014 9:11 pm
Enable PiCamera
	sudo apt-get update
	sudo pip install picamera
	sudo apt-get install python-picamera
to test if working
		raspistill -o cat.jpg -t 10000
if you receive this error
mmal: Failed to run camera app. Please check for firmware updates
you need to:
set 256 MB of ram in your video card using rasp-config
check this 2 file
sudo nano /etc/modprobe.d/raspi-blacklist.conf
blacklist spi-bcm2708
blacklist i2c-bcm2708
sudo nano /etc/modules
	w1-therm
	w1-gpio pullup=1
	i2c-dev
	i2c-bcm2708
	spi-bcm2708
	snd-bcm2835
	bcm2708_wdog
IS IMPORTANT THE ORDER OF MODULE !!!!
if you have different order, you could have some problem.
MrEngman
Tue Jun 24, 2014 9:57 pm
davidevb6 wrote:#Enable PiCamera#
sudo apt-get update
#to test#
#if you receive this error#
#you need to:#
#set 256 MB of ram in your video card using rasp-config#
#check this 2 file#
w1-therm
w1-gpio pullup=1
i2c-dev
i2c-bcm2708
spi-bcm2708
snd-bcm2835
bcm2708_wdog
Nice and confusing. Why do you need to do this? I went through the Parent Detector Tutorial and it works without problems. No need for any of that.
A couple of things that haven't been mentioned. I found it a bit awkward plugging in the camera cable. Make sure it's plugged in OK. The other thing is the camera can take a fair chunk of current so make sure you use a decent power supply. Failing when it detects motion and starts the camera recording will generate a current spike and so could indicate an inadequate power supply.
MrEngman
davidevb6
Fri Jun 27, 2014 1:19 am
:oops:
I've formatted my answer, now is more clear (i hope).
yeap, probably some modules are not necessary but are the same settings i use, so i'm sure it works.
probably there is not necessary to enable 1wire module
the only things i want to explain are "keep attention to the order of loading module" it taken me a lot of time to come out of this issue :P
Return to “Italiano”
