Toniking
Connect the pc monitor connector to my raspberry, HELP ME!
Sun Feb 10, 2019 10:27 am
Good day,
I need your help, i broken my Asus laptop so i think to open the pc and connect the monitor to my raspberry but the monitor connector is lagger to raspberry's monitor attach.
Can you help me? I can buy an adapter?
mahjongg
Re: Connect the pc monitor connector to my raspberry, HELP ME!
Sun Feb 10, 2019 12:52 pm
"lagger"? you mean larger?
Most older monitors come either with a VGA, (which needs an adapter box), or with a larger white DVI-D connector, which can be used with a HDMI to DVI-D cable.
the pictorial buyers guide sticky is a good place to start reading.
If you are thinking to use the laptops LCD as a screen, then forget it.... it won't work, (unless you are some kind of hacker with a budget, and the technical know how, to buy and use a special interface board to convert a "raw" LCD panel to a HDMI capable monitor) buying a new monitor is much cheaper and easier.
Return to “Italiano”
