Giana Sisters Return
Posted: Tue Feb 10, 2015 3:58 pm
by Vanfanel
I have released a proper Raspberry Pi port of this little gem.
It uses Rpi hardware for fullscreen scaling and tearing-less display.
Download and enjoy!
We've released a new version with accurate scanline simulation using GLES2 shaders.
It's downloadable from:
http://www.gianas-return.de/?page_id=453
Re: Giana Sisters Return
Posted: Tue Feb 10, 2015 4:07 pm
by DigitalLumberjack
Looks great, i didn't knew the game !
I'll test this tonight, thank you !
Posted: Tue Feb 10, 2015 4:47 pm
by KitchUK
Vanfanel wrote:I have released a proper Raspberry Pi port of this little gem.
Download and enjoy!
PS: It was supposed to use my new triple buffer technique, but the native 2D API of the Raspberry Pi seems to have a function I need broken at the moment. I will release a new version as soon as this is resolved by the firmware/SDK people.
This might seem like a silly question but what would you achieve with a triple buffer? Look forward to playing this!
Posted: Tue Feb 10, 2015 5:10 pm
by Vanfanel
KitchUK wrote: This might seem like a silly question but what would you achieve with a triple buffer? Look forward to playing this!
As it's now, it uses a double buffer scheme which works alright but I use a function which blocks until next vsync arrives, which is not optimal at all. No problem with this game, as it only takes ~30% of the CPU to run, but this is not the correct way to control the framerate.
A triple buffer scheme would prevent this function blocking until next vsync and provide even smoother screen updates.
Posted: Thu Mar 12, 2015 12:42 am
by 13i11
Hello, This looks interesting. I downloaded the pi port when this was originally posted about a month ago and was waiting for my pi 2 to arrive to try it out. After is showed up when I try to run it I get :
 ./giana_rpi: /lib/arm-linux-gnueabihf/libm.so.6: version `GLIBC_2.15' not found (required by ./giana_rpi)
I am running up to date Raspbian with retropie installed via the setup script. Also I can no longer find the pi download at the link provided in original post, why was it removed?
Anyways thanks for all the Pi related gaming stuff you have done for the community, hope I can play this game soon!
edit: So in the process of converting my system to running off my usb HDD somehow I managed to lose my giana_rpi folder. I never got it to run anyways but I still wanna add this to my native rpi games collection. I keep checking the site with all the links for different systems hoping the rpi version will be listed again but still nada. I have been trying google as well to see if the link was moved somewhere else but all I can find in info on the psp ports and dreamcast, etc...
Please repost a link with the rpi version. I know I can't be the only person itching to play this on the pi. :D
Posted: Sat Apr 11, 2015 6:27 pm
by 13i11
Is there actually a pi version anymore, or are we supposed to use the linux version from downloads page? Not trying to be a nuisance would just like to play some games on my pi. :mrgreen:
Posted: Thu Apr 23, 2015 3:45 pm
by 13i11
Download and enjoy!
I know I am kicking a dead horse here but where is the download link? :?:
Posted: Thu Apr 23, 2015 4:14 pm
by Vanfanel
Isn't the game downloadable from the Pi Store?
If it's not, or if you prefer, send me a PM and I will mail it to you. A new version was supposed to be released weeks ago.
Posted: Thu May 14, 2015 12:47 pm
by Vanfanel
New version released, now using scanlines simulation via shaders.
Works in conjunction with interpolation, so the result is very amiga-like!
Go to the first post for download link.
Posted: Sun May 17, 2015 1:24 pm
by araya
Running up-to-date raspbian here, game won't start..
Posted: Mon May 25, 2015 3:48 pm
by 13i11
So game runs well, however some tweaks were needed to get it to start. Since the libc6 version with wheezy is not up to par with the requirements of the game I updated it.
sudo nano /etc/apt/sources.list
replace wheezy with jessie and save.
sudo apt-get update
then
sudo apt-get install libc6
after install finishes re-edit sources.list to say wheezy again to avoid upgrading your entire system to jessie.
reboot and try the script.
This will get the game running however I do not know the implications for the rest of the system. I am not a linux guru at all but the above instructions worked for me and I haven't had any issues.
Of course you could also just run jessie but I'll wait till the foundation updates raspbian to jessie base since I did try a full upgrade with jessie sources and things got a bit wierd. I was told the game is not compatible with X but I had same results running from console as I did running from a terminal within X, no performance hits that I could see either.
Hope this helps. :D
