PoLiTvS
Re: Xbox360 USB control pad
Mon Jan 28, 2013 5:04 pm
Adanteh wrote:It's because of a faulty mapping file. I had the same issue here.
I'd recommend making a mapping file with the following code included. It's the default mapping that's included within xboxdrv. That should do the trick:
# XBMC Configuration
# This configuration file that with XBMC by emulating a wireless
# Xbox360 controller connected to the xpad kernel driver. It uses the
# configuration files that come with XBMC, so it should work out of
# the box without any further configuration of XBMC.
[xboxdrv]
ui-clear = true
extra-devices=false
extra-events=false
deadzone=6000
device-name = "Xbox 360 Wireless Receiver"
[ui-buttonmap]
#A=BTN_A
A=KEY_ENTER
#B=BTN_B
B=KEY_BACKSPACE
X=KEY_X
Y=KEY_ESC
#Steuerkreuz Links macht A, Steuerkreuz Rechts macht B
#DU=BTN_0
DU=KEY_UP
#DD=BTN_1
DD=KEY_DOWN
#DL=BTN_LEFT
DL=KEY_LEFT
#DR=BTN_RIGHT
DR=KEY_RIGHT
START=BTN_START
GUIDE=BTN_MODE
BACK=BTN_BACK
LB=BTN_TL
RB=BTN_TR
#TL=BTN_THUMBL
TL=BTN_RIGHT
#TR=BTN_THUMBR
TR=BTN_LEFT
RT=KEY_EQUAL
LT=KEY_MINUS
[ui-axismap]
#x2=REL_RX:10
#y2=REL_RY:-10
x1=REL_X:10
y1=REL_Y:10
# The resp filter moves the neutral position to zero to work around a
# bug in XBMC, that causes bogus events when neutral position is
# elsewhere. It loses a bit of precision in the trigger as result, but
# that isn't noticable.
LT^resp:127:255=ABS_Z
RT^resp:127:255=ABS_RZ
# EOF #
Nice! It works with both "own compiled" and "precompiled" drivers! I've only changed my device name, classic XBox controller over here.
Anyway I can't put to work some buttons, specially "start" and "back"... Hints? Maybe keymap issue? Can you share your xml's, please? Thanks in advance!
Adanteh
Mon Jan 28, 2013 11:28 pm
I have the same problem there, however every time I change stuff it stops working for me. Plus, I really have no idea where you can even find the keys that are used right now. I know KEY_C should open up a context menu, but I want to be able to view different keys that can be used. The mapping is still pretty lackluster.
I have the default keymap file right now
<!-- This file contains the mapping of keys (gamepad, remote, and keyboard) to actions within XBMC -->
<!-- The <global> section is a fall through - they will only be used if the button is not          -->
<!-- used in the current window's section.  Note that there is only handling                       -->
<!-- for a single action per button at this stage.                                                 -->
<!-- For joystick/gamepad configuration under linux/win32, see below as it differs from xbox       -->
<!-- gamepads.        -->
<!-- The format is:                      -->
<!--    <device>                         -->
<!--      <button>action</button>        -->
<!--    </device>                        -->
<!-- To map keys from other remotes using the RCA protocol, you may add <universalremote> blocks -->
<!-- In this case, the tags used are <obc#> where # is the original button code (OBC) of the key -->
<!-- You set it up by adding a <universalremote> block to the window or <global> section:       -->
<!--    <universalremote>             -->
<!--       <obc45>Stop</obc45>         -->
<!--    </universalremote>            -->
<!-- Note that the action can be a built-in function.                 -->
<!--  eg <B>XBMC.ActivateWindow(MyMusic)</B>                         -->
<!-- would automatically go to My Music on the press of the B button. -->
<!-- Joysticks / Gamepads:        -->
<!--   See the sample PS3 controller configuration below for the format.                      -->
<!--  Joystick Name:        -->
<!--   Do 'cat /proc/bus/input/devices' or see your xbmc log file  to find the names of       -->
<!--   detected joysticks. The name used in the configuration should match the detected name. -->
<!--  Button Ids:        -->
<!--   'id' is the button ID used by SDL. Joystick button ids of connected joysticks appear   -->
<!--   in xbmc.log when they are pressed. Use your log to map custom buttons to actions.      -->
<!--  Axis Ids / Analog Controls                                                              -->
<!--   Coming soon.        -->
<keymap>
  <global>
    <keyboard>
      <p>Play</p>
      <q>Queue</q>
      <f>FastForward</f>
      <r>Rewind</r>
      <left>Left</left>
      <right>Right</right>
      <up>Up</up>
      <down>Down</down>
      <left mod="ctrl">analogseekback</left>
      <right mod="ctrl">analogseekforward</right>
      <pageup>PageUp</pageup>
      <pagedown>PageDown</pagedown>
      <return>Select</return>
      <enter>Select</enter>
      <backspace>Back</backspace>
      <key id='65446'>Back</key>
      <m>ActivateWindow(PlayerControls)</m>
      <s>ActivateWindow(shutdownmenu)</s>
      <escape>PreviousMenu</escape>
      <i>Info</i>
      <menu>ContextMenu</menu>
      <c>ContextMenu</c>
      <space>Pause</space>
      <x>Stop</x>
      <period>SkipNext</period>
      <comma>SkipPrevious</comma>
      <tab>FullScreen</tab>
      <printscreen>Screenshot</printscreen>
      <s mod="ctrl">Screenshot</s>
      <minus>VolumeDown</minus>
      <plus>VolumeUp</plus>
      <equals>VolumeUp</equals>
      <zero>Number0</zero>
      <one>Number1</one>
      <two>Number2</two>
      <three>Number3</three>
      <four>Number4</four>
      <five>Number5</five>
      <six>Number6</six>
      <seven>Number7</seven>
      <eight>Number8</eight>
      <nine>Number9</nine>
      <numpadminus>VolumeDown</numpadminus>
      <numpadplus>VolumeUp</numpadplus>
      <numpadzero>Number0</numpadzero>
      <numpadone>Number1</numpadone>
      <numpadtwo>Number2</numpadtwo>
      <numpadthree>Number3</numpadthree>
      <numpadfour>Number4</numpadfour>
      <numpadfive>Number5</numpadfive>
      <numpadsix>Number6</numpadsix>
      <numpadseven>Number7</numpadseven>
      <numpadeight>Number8</numpadeight>
      <numpadnine>Number9</numpadnine>
      <backslash>ToggleFullScreen</backslash>
      <home>FirstPage</home>
      <end>LastPage</end>
      <!-- Multimedia keyboard keys -->
      <browser_back>Back</browser_back>
      <browser_forward/>
      <browser_refresh/>
      <browser_stop/>
      <browser_search/>
      <browser_favorites>ActivateWindow(Favourites)</browser_favorites>
      <browser_home>XBMC.ActivateWindow(Home)</browser_home>
      <volume_mute>Mute</volume_mute>
      <volume_down>VolumeDown</volume_down>
      <volume_up>VolumeUp</volume_up>
      <next_track>SkipNext</next_track>
      <prev_track>SkipPrevious</prev_track>
      <stop>Stop</stop>
      <play_pause>Pause</play_pause>
      <launch_mail></launch_mail>
      <launch_media_select>XBMC.ActivateWindow(MyMusic)</launch_media_select>
      <launch_app1_pc_icon>ActivateWindow(MyPrograms)</launch_app1_pc_icon>
      <launch_app2_pc_icon>ActivateWindow(MyPrograms)</launch_app2_pc_icon>
      <launch_file_browser/>
      <launch_media_center/>
      <!-- MS Media Center keyboard shortcuts sent by MCE remotes -->
      <!-- See http://msdn.microsoft.com/en-us/library/bb189249.aspx -->
      <p mod="ctrl,shift">Play</p>        <!-- Play -->
      <s mod="ctrl,shift">Stop</s>        <!-- Stop -->
      <p mod="ctrl">Pause</p>             <!-- Pause -->
      <f mod="ctrl,shift">FastForward</f> <!-- Fwd -->
      <b mod="ctrl,shift">Rewind</b>      <!-- Rew -->
      <f mod="ctrl">SkipNext</f>          <!-- Skip -->
      <b mod="ctrl">SkipPrevious</b>      <!-- Replay -->
      <d mod="ctrl">Info</d>              <!-- MCE Details -->
      <f10>VolumeUp</f10>                 <!-- MCE Vol up -->
      <f9>VolumeDown</f9>                 <!-- MCE Vol down -->
      <f8>Mute</f8>                       <!-- MCE mute -->
      <g mod="ctrl">OSD</g>               <!-- MCE Guide -->
      <m mod="ctrl">ActivateWindow(music)</m>    <!-- MCE My music -->
      <i mod="ctrl">ActivateWindow(pictures)</i> <!-- MCE My pictures -->
      <e mod="ctrl">ActivateWindow(video)</e>    <!-- MCE videos -->
      <m mod="ctrl,shift">PlayerControl(ShowVideoMenu)</m> <!-- MCE DVD menu -->
      <!-- MCE keypresses without an obvious use in XBMC -->
      <o mod="ctrl">Notification(MCEKeypress, Recorded TV, 3)</o>
      <t mod="ctrl">Notification(MCEKeypress, Live TV, 3)</t>
      <t mod="ctrl,shift">Notification(MCEKeypress, My TV, 3)</t>
      <a mod="ctrl">Notification(MCEKeypress, Radio, 3)</a>
      <u mod="ctrl">Notification(MCEKeypress, DVD subtitle, 3)</u>
      <a mod="ctrl,shift">Notification(MCEKeypress, DVD audio, 3)</a>
    </keyboard>
  </global>
  <LoginScreen>
    <keyboard>
      <end>XBMC.ShutDown()</end>
    </keyboard>
  </LoginScreen>
  <Home>
    <keyboard>
      <i>info</i>
    </keyboard>
  </Home>
  <VirtualKeyboard>
    <keyboard>
      <backspace>Backspace</backspace>
    </keyboard>
  </VirtualKeyboard>
  <MyFiles>
    <keyboard>
      <space>Highlight</space>
      <delete>Delete</delete>
      <m>Move</m>
      <r>Rename</r>
    </keyboard>
  </MyFiles>
  <MyMusicPlaylist>
    <keyboard>
      <space>Back</space>
      <u>MoveItemUp</u>
      <d>MoveItemDown</d>
    </keyboard>
  </MyMusicPlaylist>
  <MyMusicPlaylistEditor>
    <keyboard>
      <u>MoveItemUp</u>
      <d>MoveItemDown</d>
    </keyboard>
  </MyMusicPlaylistEditor>
  <MyMusicFiles>
    <keyboard>
      <space>Playlist</space>
      <q>Queue</q>
    </keyboard>
  </MyMusicFiles>
  <MyMusicLibrary>
    <keyboard>
      <q>Queue</q>
    </keyboard>
  </MyMusicLibrary>
  <FullscreenVideo>
    <keyboard>
      <f>FastForward</f>
      <r>Rewind</r>
      <period>StepForward</period>
      <comma>StepBack</comma>
      <backspace>Fullscreen</backspace>
      <quote>SmallStepBack</quote>
      <opensquarebracket>BigStepForward</opensquarebracket>
      <closesquarebracket>BigStepBack</closesquarebracket>
      <return>OSD</return>
      <enter>OSD</enter>
      <m>OSD</m>
      <i>Info</i>
      <o>CodecInfo</o>
      <z>AspectRatio</z>
      <t>ShowSubtitles</t>
      <t mod="ctrl">SubtitleAlign</t>
      <l>NextSubtitle</l>
      <left>StepBack</left>
      <right>StepForward</right>
      <up>BigStepForward</up>
      <down>BigStepBack</down>
      <a>AudioDelay</a>
      <escape>Fullscreen</escape>
      <v>XBMC.ActivateWindow(Teletext)</v>
      <up mod="ctrl">SubtitleShiftUp</up>
      <down mod="ctrl">SubtitleShiftDown</down>
    </keyboard>
  </FullscreenVideo>
  <VideoTimeSeek>
    <keyboard>
    </keyboard>
  </VideoTimeSeek>
  <FullscreenInfo>
    <keyboard>
      <f>FastForward</f>
      <r>Rewind</r>
      <o>CodecInfo</o>
      <i>Back</i>
      <d mod="ctrl">Back</d>
      <m>OSD</m>
    </keyboard>
  </FullscreenInfo>
  <PlayerControls>
    <keyboard>
      <m>Back</m>
    </keyboard>
  </PlayerControls>
  <Visualisation>
    <keyboard>
      <f>FastForward</f>
      <r>Rewind</r>
      <return>ActivateWindow(MusicOSD)</return>
      <enter>ActivateWindow(MusicOSD)</enter>
      <m>ActivateWindow(MusicOSD)</m>
      <i>Info</i>
      <p>ActivateWindow(VisualisationPresetList)</p>
      <v>ActivateWindow(VisualisationSettings)</v>
      <n>ActivateWindow(MusicPlaylist)</n>
      <left>SkipPrevious</left>
      <right>SkipNext</right>
      <up>IncreaseRating</up>
      <down>DecreaseRating</down>      <!--<back>NextPreset</back>!-->
      <o>CodecInfo</o>
      <l>LockPreset</l>
      <escape>FullScreen</escape>
    </keyboard>
  </Visualisation>
  <MusicOSD>
    <keyboard>
      <f>FastForward</f>
      <r>Rewind</r>
      <m>Back</m>
      <i>Info</i>
      <o>CodecInfo</o>
    </keyboard>
  </MusicOSD>
  <VisualisationSettings>
    <keyboard>
      <f>FastForward</f>
      <r>Rewind</r>
      <m>Back</m>
      <i>Info</i>
      <o>CodecInfo</o>
      <v>Back</v>
    </keyboard>
  </VisualisationSettings>
  <VisualisationPresetList>
    <keyboard>
      <f>FastForward</f>
      <r>Rewind</r>
      <m>Back</m>
      <i>Info</i>
      <o>CodecInfo</o>
      <p>Back</p>
      <v>Back</v>
    </keyboard>
  </VisualisationPresetList>
  <SlideShow>
    <keyboard>
      <zero>ZoomNormal</zero>
      <one>ZoomLevel1</one>
      <two>ZoomLevel2</two>
      <three>ZoomLevel3</three>
      <four>ZoomLevel4</four>
      <five>ZoomLevel5</five>
      <six>ZoomLevel6</six>
      <seven>ZoomLevel7</seven>
      <eight>ZoomLevel8</eight>
      <nine>ZoomLevel9</nine>
      <i>Info</i>
      <o>CodecInfo</o>
      <period>NextPicture</period>
      <comma>PreviousPicture</comma>
      <plus>ZoomIn</plus>
      <minus>ZoomOut</minus>
      <return>Rotate</return>
      <enter>Rotate</enter>
      <r>Rotate</r>
    </keyboard>
  </SlideShow>
  <ScreenCalibration>
    <keyboard>
      <return>NextCalibration</return>
      <enter>NextCalibration</enter>
      <d>ResetCalibration</d>
      <r>NextResolution</r>
    </keyboard>
  </ScreenCalibration>
  <GUICalibration>
    <keyboard>
    </keyboard>
  </GUICalibration>
  <VideoOSD>
    <keyboard>
      <m>Back</m>
      <g mod="ctrl">Back</g> <!-- MCE Guide button -->
      <i>Info</i>
      <o>CodecInfo</o>
    </keyboard>
  </VideoOSD>
  <VideoMenu>
    <keyboard>
      <m>OSD</m>
      <i>Info</i>
      <o>CodecInfo</o>
      <z>AspectRatio</z>
      <l>NextSubtitle</l>
      <a>AudioDelay</a>
      <enter>Select</enter>      <!-- backspace>Fullscreen</backspace -->
    </keyboard>
  </VideoMenu>
  <OSDVideoSettings>
    <keyboard>
      <i>Info</i>
      <o>CodecInfo</o>
    </keyboard>
  </OSDVideoSettings>
  <OSDAudioSettings>
    <keyboard>
      <i>Info</i>
      <o>CodecInfo</o>
    </keyboard>
  </OSDAudioSettings>
  <VideoBookmarks>
    <keyboard>
    </keyboard>
  </VideoBookmarks>
  <MyVideoLibrary>
    <keyboard>
      <w>ToggleWatched</w>
    </keyboard>
  </MyVideoLibrary>
  <MyVideoFiles>
    <keyboard>
      <q>Queue</q>
    </keyboard>
  </MyVideoFiles>
  <MyVideoPlaylist>
    <keyboard>
      <space>Back</space>
      <u>MoveItemUp</u>
      <d>MoveItemDown</d>
    </keyboard>
  </MyVideoPlaylist>
  <MyPictures>
    <keyboard>
    </keyboard>
  </MyPictures>
  <ContextMenu>
    <keyboard>
      <c>Back</c>
      <menu>Back</menu>
    </keyboard>
  </ContextMenu>
  <Scripts>
    <keyboard>
      <i>info</i>
    </keyboard>
  </Scripts>
  <MusicInformation>
    <keyboard>
      <i>Back</i>
    </keyboard>
  </MusicInformation>
  <MovieInformation>
    <keyboard>
      <i>Back</i>
    </keyboard>
  </MovieInformation>
  <PictureInfo>
    <keyboard>
      <i>Back</i>
      <o>Back</o>
    </keyboard>
  </PictureInfo>
  <Teletext>
    <keyboard>
      <v>Back</v>
    </keyboard>
  </Teletext>
  <FileBrowser>
    <keyboard>
    </keyboard>
  </FileBrowser>
  <ShutdownMenu>
    <keyboard>
      <s>Back</s>
    </keyboard>
  </ShutdownMenu>
  <AddonInformation>
    <keyboard>
      <i>Back</i>
    </keyboard>
  </AddonInformation>
  <AddonSettings>
    <keyboard>
    </keyboard>
  </AddonSettings>
</keymap>
PoLiTvS
Wed Jan 30, 2013 2:52 pm
I've got it working, with a semi-decent config, with the stock (raspbmc precompiled) driver.
1. No keymap at all
2. xbmc.ini for the xboxdrv:
#X1: 0 Y1: 0 X2: 0 Y2: 0  du:0 dd:0 dl:0 dr:0  start:0 back:0  TL:0 TR:0  A: 0 B: 0 X: 0 Y: 0  black: 0 white: 0  LT: 0 RT: 0
[xboxdrv]
#ui-clear = true
extra-devices = false
extra-events = false
deadzone = 6000
device-name = "Microsoft Xbox Controller S"
[ui-buttonmap]
# Face buttons
A = KEY_ENTER
B = KEY_BACKSPACE
X = KEY_X
Y = KEY_ESC
# D-Pad
du = KEY_UP
dd = KEY_DOWN
dl = KEY_LEFT
dr = KEY_RIGHT
# Start / Back buttons
start = KEY_SPACE
back = KEY_I
# White / Black buttons
white = KEY_C
black = KEY_I
# Stick buttons
TL = BTN_RIGHT # Left stick buttons
TR = BTN_LEFT # Right stick buttons
# Triggers
RT = KEY_EQUAL # Right trigger
LT = KEY_MINUS # Left trigger
[ui-axismap]
#x2=REL_RX:10
#y2=REL_RY:-10
x1=REL_X:10
y1=REL_Y:10
# that isn't noticeable.
# EOF #
3. start.sh file:
#!/bin/bash
rmmod xpad
modprobe uinput
modprobe joydev
/usr/bin/xboxdrv --config /home/pi/xboxdrv/xbmc.ini --silent &
4. And rc.local entry:
#!/bin/sh -e
# XBox controller
/home/pi/xboxdrv/start.sh
exit 0
And I think that's it!
heiNey
Thu Apr 11, 2013 9:31 pm
nm.
Liskat
Thu Apr 25, 2013 2:10 pm
I've got XBMC running on Raspbian (http://michael.gorven.za.net/raspberrypi/xbmc) The precompiled xboxdrv binaries work fine for me but only if I start it with the --config flag. The keyboard.xml in .xbmc doesn't work yet.
I found this init.d script for a xbox360 dance mat on Ubuntu:
http://www.onlydreaming.net/files/xboxdrv
Maybe someone with a more bash knowledge than me can adapt it to run on the rpi, to let the system properly start, stop and restart the driver if needed.
Edit: I don't think using sudo is needed when it is ran by rc.local.
So i got my controller.sh/load.sh setup like:
/usr/bin/xboxdrv --config /etc/mapping.xml --silent &
sleep 1
By adding the sleep command the ctrl-c message goes to background.
Alza2013
Sun May 12, 2013 6:39 pm
Made a easy to follow guide from the info within this thread, posted on Raspbmc´s forum.
Setup guide for Microsoft Xbox 360 controller
http://forum.stmlabs.com/showthread.php?tid=8659
rafacdiaz
Thu Oct 24, 2013 10:28 am
Hi!!!!!
Just comment about this issue, I got a Xbox360 wired controller and using a Pimame (raspbian with emulation station), it install automatically this driver, and you can use it from the beginning, without any extra installation. This controller, although is made by microsoft.......no comments about.........works very fine with our Raspberry Pi, the only little problem, it´s must be plugged, on the Raspberry Pi, with a power supply powerful (I don´t know if it works with chargers of less than 1 amp).
Thanks and sorry for my terrible english.
BlueLotus
Mon Dec 09, 2013 8:09 am
I am using a linux machine, so is it possible to use 360 pad with my PC? Is there any other configurations have to met to get the 360 pad working on the system? I would like to install this application.
Ellery
windows 8 upgrade
welshy
Mon Dec 09, 2013 11:23 am
rafacdiaz
Welcome to the Forum! A power supply of at least 1A should be enough to supply two wired XBox360 controllers straight from the RPi USB ports without an external Powered Hub. (I use an HTC phone charger).
BlueLotus
Welcome to the Forum! It depends on which Linux Distro you are using, Ubuntu should automatically detect an Xbox360 controller and configure it for use, others may required downloading the Drivers (In a Terminal type: sudo apt-get install xboxdrv).
"The list of things I have heard now contains everything!"
myles786
Wed May 21, 2014 9:44 pm
welshy wrote: BlueLotus
I'm trying to figure out the same thing as BlueLotus - how to use a Xbox 360 wireless controller --> wireless dongle-Pi --> Lan --> PC.
When you say Ubuntu are you referring to Arch Linux? I haven't seen an Ubuntu Operating System Image for Pi.
(noob here)
welshy
Thu May 22, 2014 7:12 am
myles786 wrote:
welshy wrote: When you say Ubuntu are you referring to Arch Linux? I haven't seen an Ubuntu Operating System Image for Pi.
(noob here)
No, there isn't one, he was referring to a PC so my assumption was he was using Ubuntu/Mint or other such Distro. For use/set-up of an Xbox 360 pad on the RPi (Using Raspbian Wheezy) see my guide
Here - http://www.raspberrypi.org/forums/viewt ... 39#p492539
Return to “Gaming”
