kpwillis
Power
Thu Oct 09, 2014 4:34 pm
I have created a cabinet for gaming. I have attached a 3 outlet power strip to a switch. The power strip powers a monitor, a Raspberry Pi, and a power amplifier. When I turn on the switch the monitor and amp power up but the Raspberry Pi does not. I see that power is getting to the unit because the LEDs are on but it does not start the boot sequence unless I open the machine and unplug it then re plug it in. I have tried 2 different ac adapters with the same results. Any ideas?
elatllat
Re: Power
Fri Oct 10, 2014 12:23 am
Likely you are having an amp shortage, so delay the pi on, or add isolation circuitry / micro UPS.
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
dan3008
Re: Power
Fri Oct 10, 2014 8:28 am
have you tried reimaging your SD? thats always my first port of call
dan3008 wrote:Pays your money, takes your choice
RaTTuS
Contact: Twitter YouTube
Re: Power
Fri Oct 10, 2014 9:00 am
are you sure ?
is the RPi powering up and just not displaying anything because the display has not responded to the the RPi?
is it HDMI ?
have you truied
hdmi_force_hotplug=1 #Use HDMI mode even if no HDMI monitor is detected
Covfefe
Jessie
Re: Power
Fri Oct 10, 2014 7:20 pm
Have you attempted to SSH into your pi? Many times when they look unresponsive or non functional I have been able to SSH in and fix the issue.
Return to “Gaming”
