RaspberryPiBoy
Stella Download?
Wed Jun 04, 2014 3:04 pm
Hi where can I download stella? I tried 'sudo apt-get install stella' but said it could not find the file or something?
DeeJay
Re: Stella Download?
Wed Jun 04, 2014 3:50 pm
Is it an Atari emulator? Something like that seems to be in the Raspbian repositories.
pi@raspberrypi ~ $ apt-cache search stella
openocd - Open on-chip JTAG debug solution for ARM and MIPS systems
savi - satellite constellation visualisation
starplot - 3-dimensional perspective star map viewer
stella - Atari 2600 Emulator for SDL & the X Window System
stellarium - real-time photo-realistic sky generator
stellarium-data - Stellarium data files
gliese - stellar data set from the Third Catalogue of Nearby Stars
yale - stellar data set from the Yale Bright Star Catalog
pi@raspberrypi ~ $ sudo apt-get install stella -s
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
  stella
0 upgraded, 1 newly installed, 0 to remove and 37 not upgraded.
Inst stella (3.7.2-1 Raspbian:7.0/stable [armhf])
Conf stella (3.7.2-1 Raspbian:7.0/stable [armhf])
pi@raspberrypi ~ $
Have you updated recently?
sudo apt-get update
How To Ask Questions The Smart Way: http://www.catb.org/~esr/faqs/smart-questions.html
How to Report Bugs Effectively: http://www.chiark.greenend.org.uk/~sgtatham/bugs.html
RaspberryPiBoy
Wed Jun 04, 2014 5:34 pm
Hi yes its an atari 2600 emulator. I found a website on how to install it but does not seem to work now. I thought somebody might know a link to download it.
mahjongg
Wed Jun 04, 2014 5:39 pm
Simply do an:
more info here:
http://www.element14.com/community/comm ... spberry-pi
Wed Jun 04, 2014 5:40 pm
RaspberryPiBoy wrote:Hi yes its an atari 2600 emulator. I found a website on how to install it but does not seem to work now. I thought somebody might know a link to download it.
It should be in the repostories
sudo apt-get update
sudo apt-get dist upgrade
https://packages.debian.org/wheezy/stella
Retired disgracefully.....
DeeJay
Wed Jun 04, 2014 7:53 pm
fruitoftheloom wrote: It should be in the repostories
It IS in the repositories. I demonstrated that in my reply at 4.50 pm earlier today. The enquirer seemed not to notice.
Wed Jun 04, 2014 9:51 pm
DeeJay you posted 1 minute before me, apologies for regurgitation.........
DeeJay
Wed Jun 04, 2014 10:26 pm
fruitoftheloom wrote:DeeJay you posted 1 minute before me, apologies for regurgitation.........
It happens... No apology needed, but thanks anyway. The emphasis was for the benefit of the enquirer: sorry in return if you thought I was sniping at you.
DJ.
RaspberryPiBoy
Thu Jun 05, 2014 7:53 am
Hi strange doesnt seem to install on my pi! Maybe I will have to try updating again?
welshy
Thu Jun 05, 2014 10:00 am
RaspberryPiBoy
As previously noted by other posters, the problem is probably the repository package locations as they are often changed/moved. If using a 'Fresh' Raspbian Image you need to update the package lists
sudo apt-get update
Once this is done the current repo paths and lists will be updated then its just
To run stella from Console/Terminal just Type: stella
Stella can also be Compiled from Source Code yourself if you so wish by downloading it from the Stella Website
"The list of things I have heard now contains everything!"
RaspberryPiBoy
Thu Jun 05, 2014 5:29 pm
Hi Welshy
Stange, it worked when I tried it today, maybe was some form of a glitch.
welshy
Thu Jun 05, 2014 6:02 pm
RaspberryPiBoy wrote:Hi Welshy
Could be it was being moved/altered in the Repos when you tired previously so wasn't accessible.
Return to “Gaming”
