50l3r
Calibrating axis joystick problem
Wed Jan 29, 2014 1:40 pm
I acquired this interface with buttons for 2 players (http://www.arcadeoutlet.es/es/interface ... sb-2p.html #)
I follow this steps to connect my joysticks with raspberry pi (http://angelverde.info/configuracion-av ... mic-koala/)
I have done all the steps to the calibration of dipositive. I recognized it as Bus 001 Device 009: ID 16c0: 05e1 VOTI CDC-ACM class devices (modems)
The fact is that to calibrate eg axis 0, my device only returns 1 when I move it to the right and 0 in the center and left. In the tutorial says it should return 0, 128 and 255. The axis 1 returns 1 when I move it down and 0 in all other cases.
This results in the mame me, I just work right, bottom and buttons. Left and above does not work.
In windows all joysticks and buttons works fine.
I have run jstest / dev/input/js0 me and detects all buttons and right / bottom of the two joysticks.
js call only detect 4 axis. But i have 2 joysticks:
Joystick has 4 axes and 22 buttons.
Correction for axis 0 is broken line, precision is 0.
Coeficients are: 0, 0, 536870912, 536870912
Correction for axis 1 is broken line, precision is 0.
Correction for axis 2 is broken line, precision is 0.
Correction for axis 3 is broken line, precision is 0.
StrawberryDorbs
Re: Calibrating axis joystick problem
Thu Jan 30, 2014 11:19 pm
I'm also having exactly the same problem as you. Right side works fine, left side doesn't at all. On windows it's calibrated fine, all sides working as they should.
When I run the jcal I get exactly the same message too. Very frustrating.
I read somewhere about someone having a similar problem and installing a i386.deb package. Whenever I try and put this on usb and find it on my pi, it doesn't show up on the usb stick?
50l3r
Fri Jan 31, 2014 1:32 am
i execute tail -f /var/log/syslog when i plug in/out the usb joystick
Jan 31 01:10:54 raspberrypi kernel: [   48.458230] usb 1-1.3: USB disconnect, device number 5
Jan 31 01:10:57 raspberrypi kernel: [   51.253379] usb 1-1.3: new low-speed USB device number 6 using dwc_otg
Jan 31 01:10:57 raspberrypi kernel: [   51.360054] usb 1-1.3: New USB device found, idVendor=16c0, idProduct=05e1
Jan 31 01:10:57 raspberrypi kernel: [   51.360087] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jan 31 01:10:57 raspberrypi kernel: [   51.360104] usb 1-1.3: Product: THT Arcade console 2P USB Player
Jan 31 01:10:57 raspberrypi kernel: [   51.360119] usb 1-1.3: Manufacturer: THT
Jan 31 01:10:57 raspberrypi kernel: [   51.378515] input: THT THT Arcade console 2P USB Player as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input3
Jan 31 01:10:57 raspberrypi kernel: [   51.380388] hid-generic 0003:16C0:05E1.0004: input,hidraw2: USB HID v1.01 Joystick [THT THT Arcade console 2P USB Player] on usb-bcm2708_usb-1.3/input0
50l3r
Fri Jan 31, 2014 1:54 am
I found this possible solution http://www.raspberrypi.org/phpBB3/viewt ... 4&start=25
Need to recompile the kernel raspbian, if you are using this operating system. My knowledge not reach there :(
Return to “Gaming”
