k33py
B+ image help please guys
Mon Dec 01, 2014 6:21 am
hi guys, after writing the both B+ images posted on here I'm not getting any boot menu. I get booted straight in xbmc and I don't seem to get any other option. Am I missing something here ?
EDIT I got it working now using the rpi-update via a b model. Just updating XBMC to KODI then adding some roms.
Can somebody tell me how to load up the emulators please ?
Hookem
Re: 01/16 UltraSlim = Retro/Gaming/Q3|XBMC 12/13|Desktop + m
Thu Dec 04, 2014 6:11 am
Can someone help? I want to setup my usb snes controller to exit games so don't need to have a mouse/keyboard after set everything up.
Silhouette35
Sat Dec 06, 2014 7:28 am
I was curious if there was a way, on the B+ img, to get a wifi usb adapter to work?
On previous XMBC images alone, like Raspbmc, wifi worked fine with minimal config in Xbmc only, but I cant seem to get it to work on UltraSlim. I'm trying to have a little cabling hooked up as possible.
Help would be greatly appreciated!
(Excuse the new-ish flavor of my msg...this is all very new to me!!)
Cheers
Hookem
Sat Dec 06, 2014 8:28 am
Yes there is away to get WiFi all all xbmc devices. Go to LXDE desktop open LXTerminal type in the command (sudo apt-get install wpasupplicant wpagui) This will install the wpa_gui. also you might have to do a sudo apt-get update if you have not done so yet.
(Let me know if that worked for you Silhouette35)
spannernick
Sun Dec 07, 2014 4:31 pm
hi why are you not using Emulation Station 2.0 on this image..?
And I can't get it to resize the sd card its say it has 0 space of 1.3 GB when its a 16gb sd card...weird..
How many emulators are in it,it looks like you not have Sega CD in there..?
I am using retropie and it better,I am going to put XBMC in it some and I might shear the image if you want it but its going to be 16GB cos I don't have a 4 GB sdcard.(I have put in a menu in terminal so you can select what you want from there. I have VNC in it to so I can remotely connect to it.)
jwest80
Sun Dec 14, 2014 1:19 am
I am having issues on first Boot. Press the Enter key to start raspi-config. Unfortunately, at this point my USB and Ethernet ports appear to not be working. So I am just stuck at this point with no input devices.
I have used NOOB successfully with keyboard, mouse, and wireless wifi adapter so I believe my peripherals are fine.
I am using the B+ model. Any ideas?
mahjongg
Sun Dec 14, 2014 1:33 am
grit
Fri Feb 06, 2015 11:15 am
I am now testing this on the RPi2 but the omxplayer for the intro video gives a very persistent dbus error and the joystick detects too fast so you can hardly select a game from the emulationstation menu.
I use imame4all for mame emulation and it also has a problem with the joystick, (Using the xin-mo dual joystick hardware usb thingy)
But all and all this was what I expected after the upgrade to the RPi2
bakan723
Wed Feb 25, 2015 8:31 pm
is there any way to add in other emulators like gba manaully? or neo geo or sega master system?
swshatkin
Fri Feb 27, 2015 6:43 am
Hi everyone, total noob here, I don't really get how you guys are installing this for a B+, how are you altering the command line txt file and making it work, I have the image and flashed it to my sd card but no dice, help please, I appreciate it
LordvanZed
Sat Mar 07, 2015 7:29 pm
Hello. Really love your work and your afforts.
Will there be a port for the raspberry pi 2? That would be so awesome!
Also, does anyone have a noob friendly guide for setting this up with 2 controller support etc. ? =)
stainy
Tue Mar 10, 2015 7:43 pm
Ok... Does 1.6 work on Rpi2? because I`ve img`d a few times on different cards and it doesn`t boot at all..
I`ve double checked everything. Retropie works so I know I don`t have a duff pi2..
thanks
C-Fu
Wed Mar 11, 2015 8:03 am
stainy wrote:Ok... Does 1.6 work on Rpi2? because I`ve img`d a few times on different cards and it doesn`t boot at all..
thanks
You might have better luck by copying RPi2 raspbian /boot files into UltraSlim's, although I've not tested this one yet.
swierkocki
Fri Mar 20, 2015 7:47 pm
How the hell do I get this running. I've got noobs on it at the moment but what do I do with the image file? Totally lost
expandables
Sat Mar 21, 2015 12:52 am
This image is depreciated wait for the new update. :mrgreen:
By thinking like an engineer you can create a raspberry pi.
Michael Jackson enthusiast.
I got the PI model B, B+ and PI 2 model B.
When will I get the A? I don't know.
swierkocki
Sat Mar 21, 2015 9:41 am
So I don't need anything but the ultra slim files?
Rionoskae
Mon Mar 23, 2015 6:42 pm
You can update the image yourself if you have a Raspberry Pi Model B (or other compatible model).
Simply boot the image up on the compatible Pi model and run the following:
sudo apt-get update && sudo apt-get upgrade -y
That should be all you need :)
That is the abbreviated version anyways - I did a quick write up with details as well if anyone is interested.
http://everyday-tech.com/update-your-ra ... bian-base/
Also - @ LordvanZed . I wrote a guide that contains documentation on controller setup. It is on the very first post of this thread.
@TakenOver83 - I would be happy to update the image for the new model if you don't mind me hosting it....Just let me know.
~Cheers
Skedone
Wed Apr 08, 2015 6:54 am
Wish thus was updated for rpi2 anyone got a guide on running rasberian os and recalbox on same card
Return to “Gaming”
