hobopi
Re: GAMES LIST: Games That Work On The Pi
Thu Jun 05, 2014 9:26 am
Conquest of Elysium 3. This game has a raspberry pi version as well.
http://www.illwinter.com/coe3.html
TheGreatNi
Thu Jun 05, 2014 3:08 pm
hobopi wrote:Conquest of Elysium 3. This game has a raspberry pi version as well.
I'm afraid that page leads to a nasty 404 (I have an archived web page if you want proof).
This one works for me:
http://goo.gl/6xaI0
The game does have to be purchased to use the pi version, however, which can be purchased from here:
http://goo.gl/wJMhFA
mrpi64
Tue Jun 17, 2014 10:08 am
Sorry, I can't do much now - I have 2 minutes to do my spanish homework :( .
I'm happy to help.
https://www.raspberrypi.org/forums/viewtopic.php?f=78&t=51794 - List of games that work on the Pi.
AmigaGamer
Thu Jun 19, 2014 7:54 pm
OpenXCOM is now at a stable 1.0 release. http://openxcom.org/
*should* work on the PI, only potential problem i can see is YAML library in raspbian is an older version so YAML c++ may need updating.
When i find my UFO enemy unknown disks ill try building it..
mrpi64
Fri Jun 20, 2014 10:10 am
Ok.
I'm happy to help.
kimbrasil
Sun Jun 22, 2014 7:59 am
New tested game on my Raspbian armhf (with armel compiled deb), some errors but run. Always need to press R to change view.
Sonic Robo Blast 2
# wget http://repos.srb2.org/deb/debian/dists/stable/main/binary-armel/srb2-data_2.0.6-2_all.deb
# dpkg -i --force-architecture srb2-data_2.0.6-2_all.deb
# wget http://repos.srb2.org/deb/debian/dists/stable/main/binary-armel/srb2_2.0.6-5_armel.deb
# dpkg -i --force-architecture srb2_2.0.6-5_armel.deb
Image Image
mrpi64
Tue Jul 01, 2014 3:04 pm
I remember trying Lincity - it didn't work too well.
I'm happy to help.
TheGreatNi
Tue Jul 01, 2014 7:47 pm
mrpi64 wrote:I remember trying Lincity - it didn't work too well.
I can confirm Lincity works just fine ;)
I actually have a lot of games that I need to post here, and I'm currently building a front-end for them all...I'll post here first about it! :mrgreen:
EDIT: I'm a bash scripting newb, I'll just say that upfront, and I need some help to get the aforementioned "front-end" to work...
I plan on using dialog (similar to the retropie installer) to download all of the games and their data into a folder, then use the same script as a menu to select the game you want to play. However, I'm unsure how to use dialog's input... take this example script below:
#!/bin/bash
VALUES=$(dialog --stdout --title "Forum Radiolist" --checklist "Choose and option:" 40 40 \ 20 \
 "Apples" \ "A red, round fruit." off \
 "Oranges" \ "A round, orange fruit." off \
 "Cat Food" \ "Food for cats, don't try at home!" off \
clear
echo $VALUES
Now let's imagine that the user only wants Apples and Cat Food...how do I set the script to only download those two? Thanks in advance (I hope)!
mrpi64
Wed Jul 02, 2014 10:03 am
Thanks.
I'm happy to help.
mrpi64
Wed Jul 09, 2014 7:18 am
Does TF2 really work on a Pi?
I'm happy to help.
TheGreatNi
Wed Jul 09, 2014 3:20 pm
mrpi64 wrote:Does TF2 really work on a Pi?
There's a fake video on youtube, but just like I said, it's clearly fake.
It's available for x86 machines running Ubuntu. That's the only way you can play it on linux. Sorry buddy! ;)
mrpi64
Fri Jul 11, 2014 2:27 pm
I had my suspicions
I'm happy to help.
TheGreatNi
Sun Jul 20, 2014 12:03 am
Hey again.
In my quest for more RPi fun, I stumbled across PiFox, a Starfox clone written in ARM assembly!
To run it (apparently) you must clone the pifox repo (https://github.com/ICTeam28/PiFox) along with the emulator that runs it, piemu (https://github.com/ICTeam28/PiEmu).
I cloned it, ran cmake, and then tried to make. But, it just returns an error. Help?
prissille
Tue Aug 05, 2014 9:49 am
#!/bin/bash
clear
echo $VALUES
In this time, I try to do a front end for raspberry games (and homebrew console) and make a specific distro like chameleon or piplay. Maybe we could work together ...
Anyway, I'll look at your script if I can do something
Sorry for my english, I'm french
prissille
Tue Aug 05, 2014 2:00 pm
You can use your var $VALUES like an array.
Look the code below, i put working example to show you a way to use it (but not the good one, you certainly need to directly test the value inside the first boucle and launch function ... )
#!/bin/bash
VALUES=$(dialog --stdout --title "Forum" --checklist "Choose" 40 40 20 \
"Apples" "Red Fruit" off \
"Orange" "Orange Fruit" off \
"Cat_Food" "Cat Food" off)
echo $VALUES
if [ $? -eq 0 ]
then
	for value in $VALUES
	do
		echo "your value: $value"
	done
else
	echo cancel selected
fi
echo "$value"
if test "$value" = \"Orange\"
then
	echo "You choose Orange. Why !!!!!!"
fi
case "$value" in
	\"Apples\")
		echo "Apples again"
	\"Orange\")
		echo "Orange again"
		echo "No Var"
esac
if [ $? -eq 0 ] >> test if answer is ok (=0) or cancel (=1)
after you can check your value into an array of string. I've change "Cat_Food". You can check value inside for with (if test) or (case) to launch function. Don't forget \" to check value.
TheGreatNi
Sun Aug 10, 2014 3:47 pm
TheGreatNi wrote:Hey again.
Turns out this newb had no idea what he was talking about :roll: PiFox runs independent of any OS on pi. You literally put it's files onto an sd card, insert, and play. PiEmu is used to emulate the game off of a pi.
That would be very interesting! I'll send you a link of the script...it's not even close to finished, but it sorta works... :P
prissille wrote:You can use your var $VALUES like an array.
#!/bin/bash
echo $VALUES
if [ $? -eq 0 ]
then
	do
	done
else
fi
echo "$value"
then
fi
case "$value" in
	\"Apples\")
		echo "Apples again"
	\"Orange\")
		echo "Orange again"
		echo "No Var"
esac
When I get a chance, I'll be sure to test this out! Thank you so much for your help! :mrgreen:
abishur
Thu Aug 28, 2014 7:41 pm
I've enjoyed "The Ur-Quan Masters" (Star Control II)
Utilizing Dos Box I've been able run various Edutainment games such as
Treasure Mountain
Midnight Rescue
Outnumbered
I have even successfully run Chips Challenge on Windows 95 using Dos Box, but I think it would run better in a different dos emulator.
Dear forum: Play nice ;-)
TheGreatNi
Tue Sep 02, 2014 10:19 pm
abishur wrote:I've enjoyed "The Ur-Quan Masters" (Star Control II)
Treasure Mountain
Midnight Rescue
Outnumbered
This post, while a legitimate contribution, needs it's own thread as a compatibility list for dosbox on pi. Am I the only one who thinks this?
abishur
Wed Sep 03, 2014 6:25 pm
Treasure Mountain
Midnight Rescue
Outnumbered
Good Idea, A wiki page listing compatibility of various games might be even more useful now that I'm thinking it.
Something like -
Red - Does not Work
Yellow - Work with minor errors or stuttering
Green - 100% compatible
I dunno, just talking out loud here.
mrpi64
Fri Sep 05, 2014 7:31 am
Treasure Mountain
Midnight Rescue
Outnumbered
Hmmm, they are not really running natively, are they? Not sure.
I'm happy to help.
mrpi64
Fri Sep 05, 2014 7:32 am
Treasure Mountain
Midnight Rescue
Outnumbered
Something like -
Red - Does not Work
That would be a great idea. Shame i can't remember if most of them work or not. And it would have to be dark colours to read them properly.
I'm happy to help.
TheGreatNi
Fri Sep 05, 2014 12:46 pm
Do we have a wiki?
Either way, start with Wikipedia's list of DOS games, and work your way through, play testing each one.
http://en.wikipedia.org/wiki/Index_of_MS-DOS_games
Me personally, I don't love DOS games, so this isn't something I'd contribute to, but it really needs it's own sticky thread or something outside of this one...
mrpi64
Wed Sep 17, 2014 9:49 am
Hmmm, a wikipedia page containing a list of games for the Pi... Sounds interesting.
I'm happy to help.
TheGreatNi
Wed Sep 17, 2014 12:44 pm
mrpi64 wrote:Hmmm, a wikipedia page containing a list of games for the Pi... Sounds interesting.
That's not what I meant.
I meant you take the list I posted and make a compatibility thread on the forums, not a wikipedia page...
Return to “Gaming”
