Joining Pi's for emulation
Posted: Sun Jun 09, 2013 3:05 pm
by PrinceTumby
Just to see what is possible, would it be possible to hook up multiple Pi's together and use them for emulation? Please don't tell me i'm an idiot and it's really easy or something. I'm only just a rookie geek. :oops:
Re: Joining Pi's for emulation
Posted: Mon Jun 10, 2013 7:29 am
by mongrol
Instead can I tell you you're an idiot and it's very very very hard?
Posted: Mon Jun 10, 2013 8:43 am
by DaveDriesen
What are you planning to emulate?
You will find it very difficult to "cluster" a number of pi's together, and running an emulation would probably not be very efficient either due to the overhead involved. Speed would suffer.
That said, it's interesting to know exactly what you would be looking to emulate.
Dave Driesen
Linux dev and oldskool elite
Posted: Mon Jun 10, 2013 8:57 am
by welshy
Prince Tumbly
Although it seems a practical possibility, unfortunately it’s not. As with all ‘Super Computers’ the program code would have to be substantially re-written (or from scratch) to share the workload across the CPU/GPU cores, it’s called ‘parallel processing’ or ‘distributed’ computing (either between discrete computers or across a network).
Cray Inc’s ‘Titan’ is currently KING of the supercomputers with 299,008 processor cores (CPU’s: AMD Opteron and GPU’s: Nvidia Tesla) and a theoretical ‘peak’ performance of 27 petaFLOPS!
Posted: Mon Jun 10, 2013 3:09 pm
by JxPond
In addition to rewriting the emulation code, one would have to have incredibly fast interconnections. The Pi only has USB2 and GPIO pins. Not exactly what one needs to connect multi gpus together.
Instead of worrying about emulation, why not give scratch or python a go and program a little game of your own. The Pi has quite a nice GPU.
Posted: Wed Jun 12, 2013 12:35 pm
by welshy
JxPond
I believe Southampton University used MPI protocol via Ethernet to parallel the nodes to build their Raspberry Pi Supercomputer.
Posted: Thu Jun 13, 2013 2:54 pm
by 4thdwarflord
Yes, there are several tutorials for joining pis together using mpi, but there is probably very little software that would take advantage of the extra power.
Posted: Sat Jun 22, 2013 10:16 am
by mrpi64
actually, 3d things would, as the pi can only render a certain amount of polygons!
