jaylongley
Re: TUTORIAL: How to get Minecraft Pi edition working!
Mon Mar 11, 2013 6:32 pm
Matt
in reply to your error "failed to add service – already in use"
directions to fix that issue are at:
http://www.instantsupportsite.com/self- ... d-service/
message me if you need a hand with it.
Jay
http://www.InstantSupportSite.com/self-help/
mattrweaver
Tue Mar 12, 2013 10:40 pm
raspberrypiguy1 wrote:
mattrweaver wrote:I have followed these instructions but when I enter ./minecraft-pi I get the message " failed to add service - already in use?"
What am I doing wrong?
Hmmmm.... I would run through everything again! Sorry about that but something has obviously gone wrong with the download!
Jemographic wrote:Do I use "Sudo aptitude install minecraft"
or something along those lines at all :?:
Actually, it was the memory split. I had it set at 16. Changed it to 32 and it works
~Jemo :ugeek:
No... You follow the tutorial!
The Raspberry Pi Guy
thelordmeatball
Thu Mar 14, 2013 1:58 pm
Do we know if it works on the 256mb board?
<MB>
adam van gaalen
Thu Mar 14, 2013 2:12 pm
It does! My son has been playing it on both a 256MB and a 512MB Rpi.
The results were the same.
mrpi64
Mon Mar 18, 2013 11:00 am
Check out my recent post on survival mode too! :D
I'm happy to help.
https://www.raspberrypi.org/forums/viewtopic.php?f=78&t=51794 - List of games that work on the Pi.
feasty
Tue Mar 19, 2013 5:17 pm
There are some tutorials on programming Minecraft Pi Edition here:
http://www.piprogramming.org/main/?page_id=256
drapacioli
Tue Mar 19, 2013 6:00 pm
hmm, so I got this downloaded and extracted, ran the command to start it, and the window loads, but nothing happens, it just sits at a black screen? The process is using CPU power though, about 25% pretty consistently.
wallarug
Sat Apr 06, 2013 4:33 am
I had the same problem:
Shouldn't it say somewhere that:
' the minimum memory split for minecraft pi edition is 64mb'
Thanks anyway.
sander2
Sun Jun 16, 2013 1:08 pm
jaylongley wrote:Matt
Jay
Ah, that worked for me! I had only 16 MB for GPU (as I seldom use it with a screen attached). With 64MB for GPU (in memorysplit) I have minecraft running on the Raspi.
Type raspi-config
Scroll down to memory_split
Delete the numbers in there and replace with the number 64
Press Enter
Scroll down to Finish
Reboot when prompted and retry running minecraft-pi
Thank you!
tomvde2012
Wed May 21, 2014 6:19 pm
thx man works perfect #firstpiproject :D
Ja$on
Thu May 22, 2014 3:47 pm
MC pi isn't very fun. it is like an old old version of pocket edition. but that is just my opinion. have fun messing with it.
dubble
Sat Aug 23, 2014 4:10 am
jaylongley wrote:
Matt
Jay
I have also encountered this problem --only this didn't fix it. Are there any other solutions to try? I had it running a while ago, but for some reason it doesn't work any more. Also, I have the Model A
rspitz
Tue Sep 09, 2014 7:09 pm
Hi Minecrafters,
my son is an avid MC player on his Windows PC, and I'd like to point his attention to the MC Pi ed. to maybe spawn some interest in programming. Before even trying, I have a few questions:
- Would MC Pi ed. run on a headless Pi, having XMing on his PC?
- Since the Pi ed. is such an old version, I'm afraid he might get bored quickly and turn away before even starting to dig into it. Have there been any updates since 0.1.1?
Regards, Richard
chaoticlapras
Sun Feb 01, 2015 12:12 pm
rspitz wrote:Hi Minecrafters,
Regards, Richard
It would run on a headless pi, probably.
He probably would get bored, yes, and there haven't been any updates. If you search hard enough, there ARE a few of us who have hacked the assembly, but honestly, it's fairly bad unless you want to do Python programming. If he's using a PC to access it, he'd probably not be that interested.
The Mojang team have said a few months ago that it is not a priority, but I believe they said they are working on something. So maybe in 2050 we'll be on 0.1.2. :-)
This space is reserved for something actually useful, and will probably never be filled.
B.Goode
Sun Feb 01, 2015 12:32 pm
chaoticlapras wrote:
rspitz wrote:I have a few questions:
No, and no.
Although I can't find explicit documentation to prove it, minecraft pi edition seems to want to output to a display that is directly connected to the RPi.
I've asked a number of times in these forums for a way to run mcpi in a headless configuration and have never got a positive response.
Crate
Mon Oct 21, 2019 12:46 pm
I’m getting an error
/lib/ld-linux-armhf.so.3: No such file or directory
It there a way to fix this?
Return to “Gaming”
