stu232
Transfered Quake3 onto USB - now it won't boot.
Wed Dec 26, 2012 10:30 pm
With the help of a few tutorials I finally managed to build a working copy of Quake 3 :)
I copied the 'release-linux-arm' folder (and all sub folders) over onto a usb stick but when I try to run it I'm told that permission is denied!?
Total Linux n00b here, please be gentle. :)
efflandt
Re: Transfered Quake3 onto USB - now it won't boot.
Thu Dec 27, 2012 6:12 pm
FAT32 (or what Linux calls vfat) has no concept of directory or file permissions. Linux simulates file permissions, but since accidentally executing a file could have undesirable consequences, so execute permission for files is typically disabled by default. But with a mount option you can give all files on the USB execute and write permissions (to also record levels or scores).
Initially (once) you need to create a mount point (you likely already did this):
sudo mkdir /media/usbmem
Then mount the USB partition with fmask that basically gives all files 777 permissions:
sudo mount -o fmask=000 -t vfat /dev/sda1 /media/usbmem
You can either symlink (ln -s) the path to something on that to your home directory, or create a script in your personal ~/bin that cd's to the necessary directory and does sudo ./ioquake3.arm
Alternately an /etc/fstab entry could be used to mount it easily, but I need to test to see what would work best for that, especially if that USB device is not always present.
Return to “Gaming”
