X-death
Street Of Rage Remake
Tue Dec 25, 2012 8:41 pm
Hi all
I'm wonder if the Raspi can launch the remake of Street Of Rage ?
i have do some search and the games seems to works very well in Ubuuntu :
http://www.n00bsonubuntu.net/content/ho ... ntu-11-10/
The shell commands seem's to be not works , maybe because Sega asked to remove it ....
i know this game has been made with SDL so maybe that's should works with no wine usage ?
Vanfanel
Re: Street Of Rage Remake
Thu Dec 27, 2012 9:56 am
No sources = no port.
CodenameV
Thu Dec 27, 2012 1:58 pm
Theres always openbor will need so tweaking I guess but it works great on the gp32
CodenameV
Sat Jan 05, 2013 5:47 pm
I've done a little more work today on beats of rage for the PI. And managed to get it working :)
clone from https://github.com/rofl0r/openbor.git
follow the instructions to compile , I used NO_GL=1 BUILD_DEBUG=1 while making
copy over a Pak file to the relevant folder.
once compiled before executing, I used
fbset -xres 512 -yres 384 -depth 16
then
SDL_FB_BROKEN_MODES=1 ./OpenBOR
and finally I got a display :)
I did have one or two problems with the Paks I downloaded , after a little reading I realised the compression used on my Paks was obsolete , I unpacked them into a folder and bingo I could play BOR at a good speed :)
Good luck
CodenameV
CodenameV
Sat Jan 05, 2013 5:54 pm
On my system if I use
fbset -xres 384 -yres 256 -depth 16
I get a much bigger play area , people will probably have to try different combos for different displays
CodenameV
InsertCoin25
Tue Jun 18, 2013 10:15 pm
How would I compile OpenBor for Raspberry Pi? This there a step by step guide for this? Or is there a compiled version already that could be uploaded here?
Thank You
InsertCoin25
P.S. Sorry if this is a double post.
mrpi64
Wed Jun 19, 2013 10:09 am
Vanfanel wrote:No sources = no port.
Not allways... Use an emulator! Like a DS rom using Desmume.
I'm happy to help.
https://www.raspberrypi.org/forums/viewtopic.php?f=78&t=51794 - List of games that work on the Pi.
InsertCoin25
Wed Jun 19, 2013 4:03 pm
Ok...this make no sense. CodenameV got OpenBor compiled to work on Raspberry Pi and was wondering how he did it.
Thank You
InsertCoin25
duberry
Location: standing on a planet that's evolving. And revolving at nine hundred miles an hour
Wed Jun 19, 2013 4:30 pm
no allways. !!!
all though an emulator! may run the game
its is no port!
lend me your arms, fast as thunderbolts, for a pillow on my journey.
If the environment was a bank, would it be too big to fail
so long; and thanks for all the pi
InsertCoin25
OpenBor on RaspberryPi
Thu Jun 20, 2013 6:28 pm
no allways. !!!
its is no port!
I am not talking about Streets of Rage Remake. I am talking about Openbor which plays .paks made with the OpenBor Engine. I was wondering how he got OpenBor compiled to play on Raspberry Pi, as he stated above, in this thread.
Thank You
InsertCoin25
Jessie
Thu Jun 20, 2013 10:13 pm
I would be interested in that as well. Beats of Rage used a scripting engine so it shouldn't be too hard to port it over. I have a number of good games made with open BOR (my favorites are the Golden Axe fan games.)
CodenameV
Sat Jun 22, 2013 2:17 pm
I have got a compiled version ready in a tar file if anyone would like it just drop me your email address , the file is just under 2mb
in addition you'll need is to download a openbor game pak , unpack it using the tools and move into the pak folder and then play-a-way :) my favs are golden axe and final fight
InsertCoin25
Sat Jun 22, 2013 4:39 pm
PM sent with email address.
Thank You
InsertCoin25
InsertCoin25
Mon Jun 24, 2013 1:36 am
Anyone else having problems getting OpenBor to boot? Mine goes straight to a black screen when I execute the runopenbor.sh and just hangs there, making me reboot the Pi. Do I need to run this through the terminal?
Thank You
InsertCoin25
CodenameV
Mon Jun 24, 2013 10:18 am
InsertCoin25 wrote:Anyone else having problems getting OpenBor to boot? Mine goes straight to a black screen when I execute the runopenbor.sh and just hangs there, making me reboot the Pi. Do I need to run this through the terminal?
Thank You
InsertCoin25
I've email you over a step by step on how I got this to work , and yes it runs must faster from terminal , so if you are in X logout and try again :)
ulysess
Thu Jan 16, 2014 12:52 pm
any progress?
Mis apuntes de...Raspberry Pi: http://misapuntesde.com
Google Docs RPi: http://goo.gl/Iwhbq
karl0ss
Sun Feb 16, 2014 5:40 pm
would like a copy of the tar if you would post here please mate?
mgoulart
Mon Feb 17, 2014 12:52 pm
CodenameV,
I was trying to compile PainTown (OpenBOR + Mugen) to RPi but I corrupted my SD card during the process.
Do you intend to try to compile PainTown too?
CodenameV
Wed Feb 19, 2014 1:15 pm
I'll certainly try to give it a go , as for the compiled openbor if anyone would like it ,it's currently on my skydrive so send me you email address ( PM if you prefer ) and I'll share it to you
CodenameV
mgoulart
Thu Feb 20, 2014 5:55 pm
CodenameV,
Thank you for the file, I will test it using my SD card test!!!
mgoulart
Thu Feb 20, 2014 9:16 pm
CodenameV,
Is it take a while to load a pak file? I tried 6 paks but all of them freezes in black screen.
The menu screen works normally but I tried to run paks with and without menu screen and only black screen.
CodenameV
Thu Mar 06, 2014 10:46 am
mgoulart wrote:CodenameV,
Hi using the included tools unpack the pak file and try it again , I remember having a few problems with certain pak files until I unpacked them ( then later repacked them )
CodenameV
Thu Mar 06, 2014 10:58 pm
I managed to compile paintown today, but in its current state its very slow, if I get chance I will try and optimize it more towards the PI hardware , if anyone else fancies trying the compiling is simple , just download the source from the project web site
http://paintown.sourceforge.net/
I downloaded version 3.6
http://sourceforge.net/projects/paintow ... 2/download
unpack it and execute the easy-compile-ubuntu script and that was it
I'll try and post the compiled version later but for now why not give it a go yourselves :)
mgoulart
Fri Mar 07, 2014 12:43 am
CodenameV,
Did you compile it using SDL engine or Allegro 5 engine?
I will try to use the unpack tool!
CodenameV
Fri Mar 07, 2014 12:13 pm
The SDL engine to start with and heres a link to the compiled file sitting on my onedrive
https://onedrive.live.com/redir?resid=F ... 60DA%21182
for anyone whos interested :) , download the source from the above link , untar , when completed untar the compiled file and copy into the folder, then just run paintown , either from terminal or X but its obviously much slower in X
Return to “Gaming”
