concerning steam
Posted: Tue Feb 05, 2019 12:30 am
by isaiah
how do you use steam on raspberry pi?
Re: concerning steam
Posted: Tue Feb 05, 2019 7:59 am
by DougieLawson
Posted: Thu Oct 24, 2019 2:07 am
by Zilla707
You should be able to download the steam installer (.deb file) from https://store.steampowered.com/about/ and then just run it by double clicking it in the downloads folder. Then, just log in, and any games that run on linux that you have in your library can be played, though they might lag. I have only tried it on the RPi os for laptops, but it should work on the standard Raspbian desktop.
Posted: Thu Oct 24, 2019 3:12 am
by Imperf3kt
That won't work, it's designed for an x86 based PC.
Follow Dougielawson's advice and use steam link, not steam.
Of course, your PC is still required in order to actually use it, so unless you want to play your steam games in a different room of the house without lugging your computer around, just play your steam games on your PC itself.
Posted: Thu Oct 24, 2019 10:31 pm
by Moonmarch
You can install steam using the command you will the package is not available error:
sudo apt install steam
Based on the Debian repository Steam is only available on i386 which is Intel CPU only if you are using Linux, here is a link to the repository web page:
https://packages.debian.org/buster/steam
You can use Steam Link on the RPI here is a link to the Steam Link for Raspberry Pi web page:
Steam Link App for Raspberry Pi:
https://support.steampowered.com/kb_art ... -IFGH-6589
