Games that uses libGLESv2.so doen't work in raspbian stretch
Posted: Sun Aug 27, 2017 2:30 pm
by cpcbegin
I can't run a lot of games in new raspbian stretch, they worked OK in jessie:
error while loading shared libraries: libGLESv2.so: cannot open shared object file: No such file or directory
I'm using a fresh instalation of latest debian stretch in a raspberry pi 2.
Some of the games than now doen't work are Maldita Castilla, Hurrican, Cubixmania, They need to be feed, etc...
Re: Games that uses libGLESv2.so doen't work in raspbian stretch
Posted: Sun Aug 27, 2017 4:45 pm
by rpiMike
I had a similar issue with 'The Little Crane That Could' :
Starting game from /home/pi/littlecrane-rpi
./littlecrane: error while loading shared libraries: libEGL.so: cannot open shared object file: No such file or directory
WARNING: the following commands could break your Raspbian install
I tried the following which didn't work for this game :
sudo ln -s /usr/lib/arm-linux-gnueabihf/libEGL.so.1.0.0 /usr/lib/libEGL.so
sudo ln -s /usr/lib/arm-linux-gnueabihf/libGLESv2.so.2.0.0 /usr/lib/libGLESv2.so
Then copied the old libraries from a Raspbian Jessie install to my game folder and used :
sudo ln -s ~/littlecrane-rpi/libEGL.so /usr/lib/libEGL.so
sudo ln -s ~/littlecrane-rpi/libGLESv2.so /usr/lib/libGLESv2.so
This worked for this game but subsequently broke my OpenGL setup and had to re-flash Raspbian Stretch.
Posted: Sun Aug 27, 2017 4:56 pm
by runboy93
Maybe you could report this on github?
https://github.com/raspberrypi
Posted: Sun Aug 27, 2017 5:07 pm
by runboy93
Do you use VC4 or other driver (software renderer?), glxinfo? Or did you just do fresh install and tried instantly without update etc stuff?
I've seen lot of these errors in time when there were not experimental OpenGL added yet (2013-2015), searched Google.
http://mattyjwilliams.blogspot.fi/2013/ ... s-via.html
Read everything after this:
"Minecraft fails to start: something about a problem loading shared library libGLESv2.so"
I've tried search what is changed for OpenGL in Stretch, but failed to find anything dramatically changed stuff for it.
Posted: Sun Aug 27, 2017 5:59 pm
by topguy
If these games are made with the VC4 libraries then these has changed names in Stretch.
They now have "brcm" (Broadcom) in their names.
pi@raspberrypi:/opt/vc/lib $ ls -l /opt/vc/lib/*brcm*
-rw-r--r-- 1 root root 202072 Jul  3 10:07 /opt/vc/lib/libbrcmEGL.so
-rw-r--r-- 1 root root 105768 Jul  3 10:07 /opt/vc/lib/libbrcmGLESv2.so
-rw-r--r-- 1 root root  99208 Sep 22  2016 /opt/vc/lib/libbrcmOpenVG.so
-rw-r--r-- 1 root root  78532 Jul  3 10:07 /opt/vc/lib/libbrcmWFC.so
You can create symbolic links to the old names.
cd /opt/vc/lib
sudo ln -s libbrcmEGL.so libEGL.so
sudo ln -s libbrcmGLESv2.so libGLESv2.so
sudo ln -s libbrcmOpenVG.so libOpenVG.so
sudo ln -s libbrcmWFC.so libWFC.so
This might solve your problem but I dont know the games you talk about so cant be sure.
Posted: Sun Aug 27, 2017 6:03 pm
by runboy93
This sounds nasty, so we have manually do this for each game?
That is just workaround, but really need to be fixed for next release(s), very strange nobody has done bug report yet to github, maybe still using Jessie?
And there is older topic:
viewtopic.php?f=66&t=191638
"However, doing an rpi-update did bring back the shared libs in /opt/vc.", most likely kernel 4.9.44 or 4.9.45 was used via rpi-update?
Posted: Sun Aug 27, 2017 6:14 pm
by topguy
No you do it once, and that should fix a lot of the games that was built for Jessie.
Its not a bug, if the game was built for a previous version of an operating system there is never any guarantee that they will work on next version. Probrammers are not psychics.
Posted: Sun Aug 27, 2017 6:32 pm
by runboy93
Fix could be apply by default, like for many different things was fixed in the past.
Posted: Sun Aug 27, 2017 6:41 pm
by topguy
Its a fix that potentially gives duplicate library names in "/opt/vc/lib" and "/usr/lib/arm-linux-gnueabihf/" (which was the case in Jessie) so the best fix is to compile the programs with correct unique library names.
Posted: Sun Aug 27, 2017 7:25 pm
by cpcbegin
I try topguy solution and update the firmware but now I get a blinked white screen instead of the error message.
The games than stop working in new raspbian stretch are Maldita Castilla (Cursed Castille), Super Crate Box, They Need To Be Fed, Hurrican, CubixMania, and Air Hockey Arcade.
I didn't activate the experimental Open-GL acceleration.
It is a fresh install, but I ran:
sudo apt-get update
sudo apt-get upgrade
sudo rpi-update
sudo apt-get install libgles2-mesa libsdl2-dev
The kernel is:
Linux raspberrypi 4.9.45-v7+ #1031 SMP Fri Aug 25 19:02:16 BST 2017 armv7l GNU/Linux
I also ask the issue to their respective creators in order to recompile their games.
Posted: Thu Aug 31, 2017 11:46 am
by runboy93
https://github.com/RPi-Distro/firmware/issues/3 (closed)
So we have just to wait until software developers have fixed their libraries.
Posted: Sat Nov 04, 2017 11:40 am
by Chips
Is this problem still there in latest raspbian stretch ?
Am i the only one who find it stupid that it's up to the developer to update the library name in their tool chain ?
The GLES and EGL optimized for broadcom should be the default one available in common place, not hidden somewhere...
Posted: Sat Nov 04, 2017 3:00 pm
by topguy
Only if you consider it a problem. I find the current situation better.
Probably not, but there are people that do not agree either. Its not uncommon for developers to update their software to support newer versions of OS. And its not like its a huge job.
Not really hidden if every guide/tutorial regarding GLES on Raspberry Pi points to "/opt/vc".
Posted: Sat Nov 04, 2017 4:27 pm
by Chips
I should be stupid but... what makes it better ?
Note that i don't even understand why we need to keep MESA GLES implementation too.. who need this when we (should) have accelerated one :)
It is not a quick job if you consider compatibility with others ARM boards which are more conventional for their GLES library name... even doing it in the "dirty way" (so breaking compatibility) would needs months before all developers do it (if they even care)...
Moreover i would not say theses modifications are needed for newer version of OS but for specific board (raspberry here). I mean debian stretch on others ARM boards doesn't have this issue, this is purely a raspberry choice breaking general GLES consensus ... so we are going another step further with specificity regarding GLES on raspberry which is not going in the good way in my opinions...
Posted: Sat Nov 04, 2017 6:59 pm
by topguy
IMO having libraries with duplicate names are a worse solution, which was the case in Jessie.
Having unique names should make the transition easier when we get to the next big Raspbian release.
I may agree with your opinion on the Mesa libraries but I don't have the complete picture and the accelerated OpenGL drivers are still in testing. So having software OpenGL rendering should make more software packages work out of the box.
The Raspberry Pi are different from a lot of other ARM boards.
Posted: Sat Nov 04, 2017 7:47 pm
by Chips
Yes but here we are talking about GLES which is a standardized interface, hence the SOC specificities should not interfere in this case (it's a pity that's even without this point it's already not true :( )...
Posted: Sat Nov 04, 2017 8:43 pm
by ShiftPlusOne
They're not compatible/interchangeable libraries. The source code of existing applications needs to be modified in order to use libbrcmGLESv2.so. 99.999% of software that links against libGLESv2.so won't work on the pi. Likewise, software written specifically for raspberry pi won't work with libGLESv2.so.
So we were in the situation that the only thing distinguishing these incompatible libraries was their path. Some software intended to work with the mesa driver would pick up the wrong library and fail and the same goes the other way. Software has no reliable way of knowing which library will be available on the system. With the accelerate open source drivers, the previously mentioned 99.999% of software actually has a chance of running and there's a clear distinction between the libraries. You can install neverball from the apt repo and it will just work without having to modify the source code. That's the direction we would like to move in.
If this still doesn't make sense, you can take a look at some of these issues:
https://jogamp.org/bugzilla/show_bug.cgi?id=1290
https://github.com/anholt/mesa/issues/24
https://github.com/raspberrypi/firmware/issues/625
Posted: Sat Nov 18, 2017 4:44 pm
by cpcbegin
Latest version of Retropie is still running under Debian Jessie because of this problem.
Posted: Sat Nov 18, 2017 5:11 pm
by ShiftPlusOne
cpcbegin wrote: Latest version of Retropie is still running under Debian Jessie because of this problem.
I am sure the developers of retropie have heard about symlinks.
Posted: Thu Dec 07, 2017 1:13 am
by josephlee
This worked for me.
Posted: Sat Dec 09, 2017 8:41 am
by jdonald
josephlee: installing the Mesa libs is sufficient for some programs, but that alone won't fix old software built on dispmanx.
Here's an approach to run those three GameMaker games (Maldita Castilla, Super Crate Box, They Need to Be Fed).
1. If you've enabled the OpenGL driver on Stretch, disable the overlay by editing /boot/config.txt to comment out dtoverlay=vc4-kms-v3d, then reboot.
2. Then run any of these apps the same way the Minecraft Pi wrapper script does. For example:
LD_LIBRARY_PATH=/opt/minecraft-pi/lib/brcm ./SuperCrateBox
Although this will put your system into a state lacking full OpenGL (and thus unable to run other games like Minecraft Java Edition), you can just as easily flip it back. I haven't tried littlecrane-rpi, but this might work there as well.
edit: However the two SDL2 Webfoot games (CubixMania and Air Hockey Arcade) with their modified SDL2 seem to attempt to load /opt/vc/lib/libGLESv2.so regardless (as revealed via strace). This is resolved with a subset of topguy's recommendation:
cd /opt/vc/lib
At least that's safer than changing libraries under /usr/lib/arm-linux-gnueabihf/
Among the games listed by cpcbegin, Hurrican is the SDL 1.2 one which makes it amenable to mcrpi-wrapper. With full OpenGL+KMS enabled, run it like so:
LD_PRELOAD=libbcm_host.so.1.0 LD_LIBRARY_PATH=/opt/minecraft-pi/lib/mesa ./hurrican
It would be cool to have Mesa EGL wrappers for the other apps too. Over time the Mesa driver could achieve performance that exceeds that of the old closed-source brcm one and we'd benefit even if the authors never update their software. It's no small task to support a LD_PRELOAD library like mcrpi-wrapper, but I do believe it to be possible in all these cases. I've written more about that elsewhere:
Edit: I've built a wrapper for GameMaker Pi runner.
