Page 3 of 9
Re: How to install/ build/ play Quake 3....
Posted: Fri Nov 16, 2012 11:16 am
by ScottBouch
I have a moderate overclock, and decent 2A power supply, via a hub, no worries for Quake!
I also havea 5V 10A PSU, but not had the need for it just yet!
Cheers, Scott
Posted: Fri Nov 16, 2012 8:26 pm
by jackjt8
How would one go about changing the screen resolution.... Without starting the game?
Posted: Fri Nov 16, 2012 10:09 pm
by raspberrypiguy1
sim_tcr wrote:i am able to launch the game. But as soon as i enter the game pi crashes.
Any thoughts?
Now game is not launching and see the message "Warning pak0.pk3 is present but its checksim (****) is not correct. Please re-install the point release"
I tried redownloading Paks.zip and extracting it. But still same message.
Strange... When downloading the Pak files do you get any error messages? Any other noticeable errors when downloading/ installing/ extracting? How far into the launch do you get? Have you done all the steps in my video?
Sorry 'bout that!
The Raspberry Pi Guy ;)
Posted: Fri Nov 16, 2012 10:14 pm
by raspberrypiguy1
dextrus wrote:Have you overclocked your Pi at all? I find that the game really exposes any underlying problems with power-supplies etc.
We have one Pi that overclocks to high just fine, but crashes as soon as Quake starts. Another Pi copes just fine. A student of mine had it crash on a non-overclocked Pi but tried my power supply and it worked fine.
/Dextrus
I do stress in the video that your Power supply is crucial when it comes to intensive applications like Quake 3... It really is important to get a good PSU for your Pi; they are not that expensive and, as you can see, the results are beneficial. I use a Kindle charger that is about £10... Or something like that!
Posted: Fri Nov 16, 2012 10:17 pm
by raspberrypiguy1
jackjt8 wrote:How would one go about changing the screen resolution.... Without starting the game?
What do you mean? The screen resolution was auto, wasn't it? What kind of monitor are you using? I think that there might be some hidden option in the start menu but as I said I thought the screen resolution was automatic?
Posted: Sat Nov 17, 2012 4:43 am
by Chris1975
Works great!! :)
Compiled without any issues.
Can I move my pack files over from my Quake 3 cd?
Thanks for the tutorial.
Posted: Sat Nov 17, 2012 8:11 am
by raspberrypiguy1
Chris1975 wrote:Works great!! :)
Glad it worked out for you! However I don't know what you mean by your question! Can you expand on it please? You can move your Pak files around but.... Why?
Posted: Sat Nov 17, 2012 10:31 pm
by dextrus
Yes, if you copy Pak0.pk3 from your cd to the base3q directory on the Pi, you will unlock the full game providing you enter the CD key. Multiplayer works a treat!
/Dextrus
Posted: Sun Nov 18, 2012 12:55 am
by Chris1975
/Dextrus
I figured as much,but it's always wiser to ask.Now just have find that darned disc.Thanks dextrus and pi guy!!
Posted: Wed Nov 21, 2012 4:24 pm
by sim_tcr
This was my second attempt to run Quake 3.
I reformatted my Card and installed latest Raspbian from downloads page.
Followed the instructions given in the beginning of the thread exactly.
But when running the game i get below message and game not starting.
ioq3 1.35 linux-arm Nov 21 2012
----- FS_Startup -----
Current search path:
/root/.q3a/baseq3
./baseq3/pak8.pk3 (9 files)
./baseq3/pak7.pk3 (4 files)
./baseq3/pak6.pk3 (64 files)
./baseq3/pak5.pk3 (7 files)
./baseq3/pak4.pk3 (272 files)
./baseq3/pak3.pk3 (4 files)
./baseq3/pak2.pk3 (148 files)
./baseq3/pak1.pk3 (26 files)
./baseq3/pak0.pk3 (1387 files)
./baseq3
1921 files in pk3 files
WARNING: pak0.pk3 is present but its checksum (2985612116)
execing default.cfg
execing q3config_server.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
--- Common Initialization Complete ---
IP: 127.0.0.1
IP: 192.168.1.40
Opening IP socket: 0.0.0.0:27960
My pi is not overclocked.
Can someone assist?
Posted: Thu Nov 22, 2012 12:03 pm
by dextrus
I can't see anything "wrong" with the output. What memory split are you using?
Posted: Thu Nov 22, 2012 12:05 pm
by sim_tcr
dextrus wrote:I can't see anything "wrong" with the output. What memory split are you using?
Is that normal?
How to check memory split? What should be done to use correct memory split?
Posted: Thu Nov 22, 2012 6:19 pm
by jackjt8
It wasn't... The first time I used it it wasn't auto.
But, at the time I was using it I had a hd screen... But that broke and then I hadda bring out the old and reliable VGA... But the resolution I had it on before must be too great for it.. (More than 640x480)
is there anyway to reset it without building it?
I am trying to boost the screen resolution up to 1024x768 so it works but... The raspberry pi just doesn't like hdmi-vga conversion without it set to hdmi VGA mode.
Posted: Sun Nov 25, 2012 9:54 pm
by danica_patrick
Just finished unzipping and moving the pak files to the right folder, navigated to /quake3/build/release-linux-arm/ and tried sudo ./ioquake3.arm and I get the following message:
sudo: ./ioquake3.arm: command not found :?
Gee, this can't be good! I did notice some error messages as it finished compiling... what steps should I take to try and fix it - start over?
Posted: Tue Dec 04, 2012 8:41 am
by Me77111
I'm getting a 404 Not Found on the first command.... Did this a few days ago and it worked, but I decided to try other distros, now I came back and wanted it back on. Doesn't work though >.<
Posted: Tue Dec 04, 2012 5:35 pm
by jackjt8
Any way to fix sound?
I had it working via hdmi, but as soon as I try to use the 3.5mm jack I get nothing.
Posted: Wed Dec 05, 2012 2:59 am
by Me77111
jackjt8 wrote:Any way to fix sound?
When I had it before, sound worked. You need to make sure your audio settings are set to auto detect or 3.5mm jack for it to work though. Maybe you have it set to force HDMI?
Posted: Wed Dec 05, 2012 6:53 am
by Me77111
No more 404 errors. seemed to resolve itself.
Posted: Wed Dec 05, 2012 4:13 pm
by jackjt8
Well I've tried that but no luck.
As for the config.txt yes, I have used force HDMI, but I've also turned off HDMI sound.
Posted: Wed Dec 05, 2012 7:03 pm
by sharmajar
After following these steps to the letter to compile the code I am getting this error.
CC code/es/es_glimp.c
CC code/es/etc1encode.c
In file included from /opt/vc/include/interface/vcos/vcos_assert.h:149:0,
                 from /opt/vc/include/interface/vcos/vcos.h:114,
                 from /opt/vc/include/interface/vmcs_host/vc_dispmanx.h:33,
                 from /opt/vc/include/bcm_host.h:46,
                 from /opt/vc/include/EGL/eglplatform.h:95,
                 from /opt/vc/include/EGL/egl.h:36,
                 from code/es/es_glimp.c:36:
/opt/vc/include/interface/vcos/vcos_types.h:38:33: fatal error: vcos_platform_types.h: No such file or directory
compilation terminated.
CGAME_CC code/cgame/cg_main.c
code/es/etc1encode.c:68:12: warning: ‘dsize’ defined but not used [-Wunused-variable]
code/es/etc1encode.c:72:18: warning: ‘ldropped’ defined but not used [-Wunused-variable]
code/es/etc1encode.c:72:28: warning: ‘ltested’ defined but not used [-Wunused-variable]
code/es/etc1encode.c:764:27: warning: ‘block_encode_search’ defined but not used [-Wunused-function]
make[2]: *** [build/release-linux-arm/client/es_glimp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
code/es/etc1encode.c: In function ‘etc1_compress_tex_image’:
code/es/etc1encode.c:1107:36: warning: ‘b’ may be used uninitialized in this function [-Wuninitialized]
code/es/etc1encode.c:1106:36: warning: ‘g’ may be used uninitialized in this function [-Wuninitialized]
code/es/etc1encode.c:1105:36: warning: ‘r’ may be used uninitialized in this function [-Wuninitialized]
make[2]: Leaving directory `/home/pi/quake3'
make[1]: *** [targets] Error 2
make[1]: Leaving directory `/home/pi/quake3'
make: *** [release] Error 2
I don't know why this happens but I can assume it is due to a missing dependant file.
I have follow TheRaspberryPiGuy's instruction to the letter and when it comes to compiling the code, it all goes horribly wrong.
Could someone please help me resolve this issue?
Posted: Thu Dec 06, 2012 9:26 pm
by Mr_Ranger
Nice article, got it running on my RasPi. Thank you. :D
Posted: Fri Dec 07, 2012 2:36 am
by sim_tcr
Mr_Ranger wrote:Nice article, got it running on my RasPi. Thank you. :D
Can you give me the location where you downloaded the pack files? I tried from multiple locations. Two complete fresh installs ans still stuck with below error.
Posted: Sat Dec 08, 2012 6:31 pm
by Mr_Ranger
There's a zip file within the files that are downloaded. Just be sure to unzip them in the proper folder.
Posted: Sat Dec 08, 2012 9:26 pm
by Shadaez
I successfully built it, put the pak files in and it runs, but its really slow and buggy. I've tried quite a few things, im recompiling it now to see if that helps, but any tips? I've tried with and without overclocks and multiple powerful power supplies including a 2A 5v tablet charger.
My audio is crackly in game, too.
Posted: Sun Dec 09, 2012 3:42 am
by efflandt
I followed the instructions and it works great in Raspian on rev 2.0 B Pi on 32" 1080p HDTV with HMDI audio. The only a/v related settings uncommented in /boot/config.txt are:
disable_overscan=1
gpu_mem=128
My LG TV has a mode called "Just Scan" which attempts to fill the screen with whatever signal it receives. It looked like it was pillar boxed (maybe just the menus?) in default 640x480, but game itself was full screen when set 1024x768. Takes me back to the days when I used to play Linux Q2 on-line too long into the nights w/3DFX VooDoo graphics.
However, playing Q3 on the Pi revealed that overclock settings that work fine for everything including compiling Q3 caused it to spontaneously reboot. So Q3 is good for testing overclock limits that should work for anything else.
