gdw35
Re: How to install/ build/ play Quake 3....
Sun Jan 13, 2013 3:29 am
I have been able to build Quake successfully and it runs great. The problem is that there is no sound. I have followed most of the help tips I can find to get the sound working but none appear to work. I am using HDMI audio and doing some testing with other applications shows that for anything using the alsa drivers audio is working fine but anything that uses the pulse audio drivers is silent.
Are there any config tools or settings that I should be looking at for the pulse audio drivers that could resolve my problem?
gdw35
Sun Jan 13, 2013 5:04 am
Problem solved!!!
I removed pulseaudio from the system and it all started working. Now enjoying Quake with the sound up.
Very happy. :D :D :D
Gurkan
Tue Jan 15, 2013 12:24 am
Any chance there will be a full version of Q3 for the pi instead of just a demo?
ShiftPlusOne
Tue Jan 15, 2013 1:11 am
Gurkan wrote:Any chance there will be a full version of Q3 for the pi instead of just a demo?
Of course, just provide the data from your legally obtained quake 3 install.
6677
Tue Jan 15, 2013 10:19 pm
This is just the engine. It will run any id tech 3 compatible content including that from your original quake 3 CD or the steam version. I personally use it to play open arena.
Davespice
Contact: Twitter
Wed Jan 16, 2013 11:44 am
gdw35 wrote:Problem solved!!!
Well done old chap. I have been trying to get the sound working for a while. Pulse Audio is a daemon isn't it? I wonder if it would work if you just shut down the daemon without having to remove it entirely? That way you could have a bash script to shut down the demon, run the game, and restart the daemon.
Sassinak
Fri Jan 18, 2013 9:38 pm
Hmmm, the PK3 packages are "wrong", esp. PK0
any other source ?
6677
Sat Jan 19, 2013 9:23 pm
Sassinak wrote:Hmmm, the PK3 packages are "wrong", esp. PK0
any other source ?
They work fine for me. Are they in the right folder?
Otherwise the files from openarena also work absolutely fine.
Sassinak
Sat Jan 19, 2013 11:45 pm
Yes they are, they're not corrupt or anything, just that when I start the game I get a warning that pk0(?) is not the size "expected..."
You say I can use files from openarena? Same packaging ? or do I rename the zips to *.pk3 ?
dextrus
Sun Jan 20, 2013 12:25 am
It's good that you worry about this. I did at first. But then the original file was from 1999 the engine we're reading it from is much later that... Maybe the IoQuake version just defaults to "false"? I haven't checked. As long as it works and we have legitimate data, be happy.
Are there any Pi only quake servers? I'm not suggesting running the server on a Pi, but has anyone set up one for us Pi owners? I might.. But I suspect if anyone did and mentioned it, it would get swamped.
/Dextrus
Have more FUN with your Pi. Visit www.pi-fun.com
Sassinak
Sun Jan 20, 2013 3:47 am
If only it started ! But no, it's not just a warning, it's a fail. I haven't played around with it in 2 days, I will give better information on just what the message is.
Meanwhile, OMXPlayer leaves a background and is uncontrollable from the keyboard - except ^C - been working on that too !
6677
Sun Jan 20, 2013 6:04 pm
there are no zips in open arena or q3.
You have made sure you extracted the archive in the first place right?
kevintmckay
Sun Jan 20, 2013 11:35 pm
Works great, thanks... BTW where do you do your memory GPU split to get best performance?
Yamahanytro
Fri Feb 01, 2013 4:37 am
I went through and made sure I did everything right but when I run
sudo ./ioquake3.arm
I get the error
vchiq_lib: Incompatible VCHIQ library - driver version 5 (min 3), library version 2 (min 2)
* failed to open vchiq instance
I ran
apt-get update && apt-get upgrade
and it says I have no updates. Please help. I don't believe I messed up anywhere along the way.
Jamulisprime
Sun Feb 17, 2013 11:21 pm
I got the game to install, and boot up, but when i try to play it crashes, from the text it says its unable to find sound files. got it to play finally, sounds pops and cracks, game lags then it crashes.
QBall1977
Mon Mar 11, 2013 9:18 am
Dear All,
From what I've read you need the updated version of this that will run with the latest Raspbian. I think I'm coming to the conclusion that it is better to often (roll your own) than download the image. The Hexxeh image no longer seems in place anyway. :roll:
If you get the VCHQ error it is as you are running the old version. Building it myself now! SSH is a wonderful thing. :D
Just trying to get this right so I can use it as an example with Kids. Anyone got this working with a PS3 pad? I've easily configured Wii-mote, and Xbox pad, but for the holy trinity I need the PS3 pad! Note to all those trying only OFFICIAL GENUINE PS3 pads seem to work via bluetooth, tried it with several others, but they fail to connect! :evil:
____________________________________________
Looking for where to start - try Kernel Panic - http://goo.gl/EEQ5J
theoB610
Mon Apr 29, 2013 6:22 pm
How big is the install? will it eat up my memory?
QBall1977
Wed May 01, 2013 10:25 pm
Quick question, not sure if in the right section, but does anyone know how to change the size of the console (~) while playing quake 3. On the projector when demo-ing to kids via HDMI the text is teeny tiny and very very hard to read. I had a look through all the Quake 3 commands I could find, but nothing obvious. Please, anyone got any tips?
Game runs great, I recommend removing pulseaudio as recommended and install the DispManx SDL drivers for improved performance. :D
Museste
Sat Jul 20, 2013 7:09 am
Hi
I think theres a little confusion where the pak files need to go. I unzipped them into quake3/baseq3 and it didnt work. I then tried quake3/build/release-linux-arm/baseq3 then all was sweet.
theoB610
Wed Aug 07, 2013 11:31 am
I'm having problems exiting quake (not that you'd ever want to).
It seems to get stuck on the last page of the credits.
mrpi64
Fri Aug 09, 2013 10:22 am
It doesn't work for me! Can someone plz upload a pre-compiled version for the Pi to somewhere like dropbox? Thanks.
I'm happy to help.
https://www.raspberrypi.org/forums/viewtopic.php?f=78&t=51794 - List of games that work on the Pi.
mrpi64
Sun Aug 11, 2013 3:09 pm
Ok, it works now. Any mods that I can use?
I'm happy to help.
raspberrypiguy1
Sun Aug 25, 2013 10:38 am
Sorry I have been absent from this conversation... If anyone else has any future problems/concerns please email me or comment on my YouTube video. Not here on the forums!
The Raspberry Pi Guy
Matt, The Raspberry Pi Guy YouTube channel, author of Learn Robotics with Raspberry Pi, available now: http://mybook.to/raspirobots, Computer Science & Electronics Undergraduate at The University of Edinburgh
MatthewG
Sat Oct 12, 2013 5:37 pm
Hello.
I'm not entirely sure what I'm doing wrong here and i don't even know if this post is active anymore
but anyway I'm write at the end where you have to change the directory to "cd /quake3/build/release-linux-arm/"
and I'm getting the error: " No such file or directory " please help me out, it would suck to get this far and just have to abandon it through something so stupid.
Thanks,
Matt.
Return to “Gaming”
