rpiMike
Re: How to setup Minecraft 1.12 on Raspberry Pi 3
Sat Aug 19, 2017 10:17 am
You don't actually need to extract the files from the jar file. It looks like the Optifine_1.12_HD_U_C3.jar file exists - I don't know why it won't execute.
I would delete everything in you Downloads folder and re-download the jar file.
DerekLF
Sat Aug 19, 2017 12:01 pm
Tried that. But it gave the same error.
Thanks for all the help so far.
rpiMike
Sat Aug 19, 2017 1:58 pm
I think I've spotted the problem - your missing the capital F !
java -jar OptiFine_1.12_HD_U_C3.jar
DerekLF
Sun Aug 20, 2017 10:49 am
how did i miss and capital F?... :shock:
optifine is installed but the same error stays. "game ended with bad state(exit code 1)"
and this:
[12:43:15] [main/INFO]: Launching wrapped minecraft {net.minecraft.client.main.Main}
Java HotSpot(TM) Client VM warning: You have loaded library /home/pi/.minecraft/versions/1.11.2-OptiFine_HD_U_C3/1.11.2-OptiFine_HD_U_C3-natives-237350221019/liblwjgl64.so which might have disabled stack guard. The VM will try to fix the stack guard now.
It's highly recommended that you fix the library with 'execstack -c <libfile>', or link it with '-z noexecstack'.
[12:43:16] [main/ERROR]: Unable to launch
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_65]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_65]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_65]
at java.lang.reflect.Method.invoke(Method.java:497) ~[?:1.8.0_65]
at net.minecraft.launchwrapper.Launch.launch(Launch.java:135) [launchwrapper-1.12.jar:?]
at net.minecraft.launchwrapper.Launch.main(Launch.java:28) [launchwrapper-1.12.jar:?]
Caused by: java.lang.UnsatisfiedLinkError: /home/pi/.minecraft/versions/1.11.2-OptiFine_HD_U_C3/1.11.2-OptiFine_HD_U_C3-natives-237350221019/liblwjgl.so: /home/pi/.minecraft/versions/1.11.2-OptiFine_HD_U_C3/1.11.2-OptiFine_HD_U_C3-natives-237350221019/liblwjgl.so: cannot open shared object file: No such file or directory (Possible cause: can't load IA 32-bit .so on a ARM-bit platform)
at java.lang.ClassLoader$NativeLibrary.load(Native Method) ~[?:1.8.0_65]
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1938) ~[?:1.8.0_65]
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1854) ~[?:1.8.0_65]
at java.lang.Runtime.loadLibrary0(Runtime.java:870) ~[?:1.8.0_65]
at java.lang.System.loadLibrary(System.java:1122) ~[?:1.8.0_65]
at org.lwjgl.Sys$1.run(Sys.java:72) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:1.8.0_65]
at org.lwjgl.Sys.doLoadLibrary(Sys.java:66) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.Sys.loadLibrary(Sys.java:96) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.Sys.<clinit>(Sys.java:117) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at bes.I(SourceFile:2777) ~[bes.class:?]
at net.minecraft.client.main.Main.main(SourceFile:39) ~[Main.class:?]
... 6 more
i think this is the problem
rpiMike
Sun Aug 20, 2017 10:57 am
I'm not sure why you've got anything pointing to 1.11.2 !
When you installed Minecraft (java -jar Minecraft.jar) did you specify release 1.12 ?
Are you using my runOptifine1_12.sh script ?
DerekLF
Sun Aug 20, 2017 11:07 am
yes i'm using your run_optifine script. i was trying if 1.11.2 could work but neither work.
and 1.12 gives the exact same error..
[13:05:18] [main/INFO]: Launching wrapped minecraft {net.minecraft.client.main.Main}
Java HotSpot(TM) Client VM warning: You have loaded library /home/pi/.minecraft/versions/1.12-OptiFine_HD_U_C3/1.12-OptiFine_HD_U_C3-natives-317712789217/liblwjgl64.so which might have disabled stack guard. The VM will try to fix the stack guard now.
[13:05:19] [main/ERROR]: Unable to launch
java.lang.reflect.InvocationTargetException: null
Caused by: java.lang.UnsatisfiedLinkError: /home/pi/.minecraft/versions/1.12-OptiFine_HD_U_C3/1.12-OptiFine_HD_U_C3-natives-317712789217/liblwjgl.so: /home/pi/.minecraft/versions/1.12-OptiFine_HD_U_C3/1.12-OptiFine_HD_U_C3-natives-317712789217/liblwjgl.so: cannot open shared object file: No such file or directory (Possible cause: can't load IA 32-bit .so on a ARM-bit platform)
at bhz.I(SourceFile:2825) ~[bhz.class:?]
at net.minecraft.client.main.Main.main(SourceFile:38) ~[Main.class:?]
... 6 more
rpiMike
Sun Aug 20, 2017 11:20 am
Try steps 8 (Copy libraries) and 9 (Update lwjgl) again.
If that doesn't work, I would start from scratch with a freshly flashed sd card.
If you follow all steps exactly it should work fine.
DerekLF
Sun Aug 20, 2017 11:39 am
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Thread: Client thread
Stacktrace:
at Config.getDisplayModes(Config.java:1732)
at bib$a.<clinit>(GameSettings.java:3452)
at bib.<init>(GameSettings.java:315)
at bhz.aq(SourceFile:443)
-- Initialization --
Details:
Stacktrace:
at bhz.a(SourceFile:404)
at net.minecraft.client.main.Main.main(SourceFile:123)
-- System Details --
Details:
Minecraft Version: 1.12
Operating System: Linux (arm) version 4.9.35-v7+
Java Version: 1.8.0_65, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 103600208 bytes (98 MB) / 172093440 bytes (164 MB) up to 1060372480 bytes (1011 MB)
JVM Flags: 5 total; -Xmn128M -Xmx1024M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.12
LWJGL: 2.9.4
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
GL Caps:
Using VBOs: ~~ERROR~~ NullPointerException: null
Is Modded: Very likely; Jar signature invalidated
Type: Client (map_client.txt)
Resource Packs: ~~ERROR~~ NullPointerException: null
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
CPU: <unknown>
#@!@# Game crashed! Crash report saved to: #@!@# /home/pi/.minecraft/crash-reports/crash-2017-08-20_13.36.44-client.txt
ill try it from scrap..
DerekLF
Re: How to setup Minecraft 1.12.1 on Raspberry Pi 3
Sun Aug 20, 2017 6:09 pm
its me again :/
it gave this:
[20:06:03] [main/INFO]: [OptiFine] *** Reflector Forge ***
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.model.Attributes
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: mods.betterfoliage.client.BetterFoliageClient
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.asm.transformers.BlamingTransformer
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.event.world.ChunkWatchEvent$UnWatch
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.relauncher.CoreModManager
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.DimensionManager
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.GuiScreenEvent$DrawScreenEvent$Pre
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.GuiScreenEvent$DrawScreenEvent$Post
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.EntityViewRenderEvent$CameraSetup
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.EntityViewRenderEvent$FogColors
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.EntityViewRenderEvent$RenderFogEvent
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.eventhandler.Event
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.eventhandler.EventBus
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.eventhandler.Event$Result
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.property.ExtendedBlockState
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.client.FMLClientHandler
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.FMLCommonHandler
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: anh.getWaterColorMultiplier
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.addDestroyEffects
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.addHitEffects
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.canCreatureSpawn
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.canRenderInLayer
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.doesSideBlockRendering
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getBedDirection
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getExtendedState
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getFogColor
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getLightOpacity
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getLightValue
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getSoundType
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.hasTileEntity
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.isAir
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.isBed
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.isBedFoot
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.isSideSolid
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: and.isSideSolid
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: vg.canRiderInteract
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Field not present: vg.captureDrops
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Field not present: vg.capturedDrops
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: vg.shouldRenderInPass
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: vg.shouldRiderSit
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.event.ForgeEventFactory
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.ForgeHooks
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.ForgeHooksClient
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Field not present: ain.delegate
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.getDurabilityForDisplay
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.getRGBDurabilityForDisplay
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.isShield
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.onEntitySwing
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.shouldCauseReequipAnimation
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.showDurabilityBar
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: bwa.handleItemState
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: agv.hasOverlay
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: bhy.setKeyConflictContext
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: bhy.setKeyModifierAndCode
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: bhy.getKeyModifier
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.ForgeModContainer
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: bvv.parseFromReader
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: uz.shouldRenderHUD
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: uz.renderHUDEffect
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: va.isCurativeItem
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: avj.canRenderBreaking
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: avj.getRenderBoundingBox
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: avj.hasFastRenderer
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: avj.shouldRenderInPass
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: ceb$b.preDraw
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: ceb$b.postDraw
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: amu.countEntities
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: amu.getPerWorldStorage
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: amu.initCapabilities
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aym.getCloudRenderer
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aym.getSkyRenderer
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Method not present: aym.getWeatherRenderer
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.client.GuiModList
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.property.IExtendedBlockState
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.model.IModel
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.IRenderHandler
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.ItemModelMesherForge
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.settings.KeyConflictContext
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.settings.KeyModifier
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.model.pipeline.LightUtil
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.MinecraftForge
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.MinecraftForgeClient
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.model.ModelLoader
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.gui.NotificationModUpdateScreen
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderBlockOverlayEvent$OverlayType
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.client.registry.RenderingRegistry
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderItemInFrameEvent
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderLivingEvent$Pre
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderLivingEvent$Post
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderLivingEvent$Specials$Pre
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderLivingEvent$Specials$Post
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.ScreenshotEvent
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.client.SplashProgress
[20:06:03] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.event.world.WorldEvent$Load
[20:06:03] [main/INFO]: [OptiFine] *** Reflector Vanilla ***
---- Minecraft Crash Report ----
// Ooh. Shiny.
ive started from scrap, freshly flashed sd card, and i followed your instruction. half way i had to change some stuff due to 1.12 and 1.12.1
found this error. what did i miss?
[20:13:05] [main/ERROR]: Can't find the resource index file: /home/pi/.minecraft/assets/indexes/1.12.1.json
rpiMike
Sun Aug 20, 2017 6:16 pm
Did you install Minecraft 1.12.1 and OptiFine 1.12.1 HD U C5 ?
I've done a fresh install today - which worked fine.
When do you get that error ?
DerekLF
Sun Aug 20, 2017 6:28 pm
when i type:
cd ~/Minecraft && ./runOptifine1_12_1.sh
im gonna try and install it on another freshly flashed sd card..
rpiMike
Sun Aug 20, 2017 6:32 pm
That error looks like you haven't installed Minecraft 1.12.1
DerekLF
Sun Aug 20, 2017 8:03 pm
i just installed minecraft 1.12.1 but still the 1.12.1.json is missing
rpiMike
Sun Aug 20, 2017 9:38 pm
There isn't a 1.12.1.json file - only 1.12.json !
Did you edit something else in the runOptifine1_12_1.json file ?
The MINECRAFT_VERSION should stay as 1.12
DerekLF
Mon Aug 21, 2017 3:00 pm
ow okey,
well i only added my login, username and my password. nothing more
-- Head --
Stacktrace:
	at bid$a.<clinit>(GameSettings.java:3452)
	at bid.<init>(GameSettings.java:315)
	at bib.aq(SourceFile:443)
Details:
Stacktrace:
	at bib.a(SourceFile:404)
it keeps giving this error
and during the install of minecraft 1.12.1 i see this:
[17:08:43 WARN]: Couldn't download http://resources.download.minecraft.net/55/559e74952ee4642bf5619670ee0f9eeceb503bfa for job 'Resources'
java.net.SocketTimeoutException: Read timed out
	at java.net.SocketInputStream.socketRead0(Native Method) ~[?:1.8.0_65]
	at java.net.SocketInputStream.socketRead(SocketInputStream.java:116) ~[?:1.8.0_65]
	at java.net.SocketInputStream.read(SocketInputStream.java:170) ~[?:1.8.0_65]
	at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:1.8.0_65]
	at java.io.BufferedInputStream.fill(BufferedInputStream.java:246) ~[?:1.8.0_65]
	at java.io.BufferedInputStream.read1(BufferedInputStream.java:286) ~[?:1.8.0_65]
	at java.io.BufferedInputStream.read(BufferedInputStream.java:345) ~[?:1.8.0_65]
	at sun.net.www.http.HttpClient.parseHTTPHeader(HttpClient.java:704) ~[?:1.8.0_65]
	at sun.net.www.http.HttpClient.parseHTTP(HttpClient.java:647) ~[?:1.8.0_65]
	at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1536) ~[?:1.8.0_65]
	at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1441) ~[?:1.8.0_65]
	at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:480) ~[?:1.8.0_65]
	at com.mojang.launcher.updater.download.assets.AssetDownloadable.download(AssetDownloadable.java:97) ~[launcher.jar:1.6.73-j]
	at com.mojang.launcher.updater.download.DownloadJob.popAndDownload(DownloadJob.java:109) [launcher.jar:1.6.73-j]
	at com.mojang.launcher.updater.download.DownloadJob.access$000(DownloadJob.java:12) [launcher.jar:1.6.73-j]
	at com.mojang.launcher.updater.download.DownloadJob$1.run(DownloadJob.java:86) [launcher.jar:1.6.73-j]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_65]
	at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_65]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_65]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_65]
	at java.lang.Thread.run(Thread.java:745) [?:1.8.0_65]
i get the same warning every few seconds
and this one:
[17:15:11 WARN]: Couldn't download http://resources.download.minecraft.net/cc/cc1a80b6becfc6d6489c069f053d0a8adc71c339 for job 'Resources'
	at java.io.BufferedInputStream.read1(BufferedInputStream.java:284) ~[?:1.8.0_65]
	at sun.net.www.MeteredStream.read(MeteredStream.java:134) ~[?:1.8.0_65]
	at java.io.FilterInputStream.read(FilterInputStream.java:133) ~[?:1.8.0_65]
	at sun.net.www.protocol.http.HttpURLConnection$HttpInputStream.read(HttpURLConnection.java:3336) ~[?:1.8.0_65]
	at sun.net.www.protocol.http.HttpURLConnection$HttpInputStream.read(HttpURLConnection.java:3329) ~[?:1.8.0_65]
	at com.mojang.launcher.updater.download.MonitoringInputStream.read(MonitoringInputStream.java:28) ~[launcher.jar:1.6.73-j]
	at com.mojang.launcher.updater.download.Downloadable.copyAndDigest(Downloadable.java:140) ~[launcher.jar:1.6.73-j]
	at com.mojang.launcher.updater.download.assets.AssetDownloadable.download(AssetDownloadable.java:104) ~[launcher.jar:1.6.73-j]
rpiMike
Mon Aug 21, 2017 4:55 pm
Not sure - looks like your having issues downloading parts of Minecraft !
I've just created a video tutorial if it helps :
https://www.youtube.com/watch?v=yTRYomiQMAY&t=35s
DerekLF
Mon Aug 21, 2017 5:05 pm
ill be looking into it tommorow. thanks alot
DerekLF
Mon Aug 21, 2017 7:27 pm
java.util.zip.ZipException: error in opening zip file
  at java.util.zip.ZipFile.open(Native Method)
  at java.util.zip.ZipFile.<init>(ZipFile.java:219)
  at java.util.zip.ZipFile.<init>(ZipFile.java:149)
  at java.util.zip.ZipFile.<init>(ZipFile.java:163)
  at optifine.Patcher.process(Patcher.java:71)
  at optifine.Installer.installOptiFineLibrary(Installer.java:308)
  at optifine.Installer.doInstall(Installer.java:96)
  at optifine.InstallerFrame.onInstall(InstallerFrame.java:425)
  at optifine.InstallerFrame.connEtoC1(InstallerFrame.java:490)
  at optifine.InstallerFrame.access$7(InstallerFrame.java:484)
  at optifine.InstallerFrame$IvjEventHandler.actionPerformed(InstallerFrame.java:46)
  at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
  at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
  at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
  at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
  at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
  at java.awt.Component.processMouseEvent(Component.java:6535)
  at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
  at java.awt.Component.processEvent(Component.java:6300)
  at java.awt.Container.processEvent(Container.java:2236)
  at java.awt.Component.dispatchEventImpl(Component.java:4891)
  at java.awt.Container.dispatchEventImpl(Container.java:2294)
  at java.awt.Component.dispatchEvent(Component.java:4713)
  at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)
  at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
  at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
  at java.awt.Container.dispatchEventImpl(Container.java:2280)
  at java.awt.Window.dispatchEventImpl(Window.java:2750)
  at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
  at java.awt.EventQueue.access$500(EventQueue.java:97)
  at java.awt.EventQueue$3.run(EventQueue.java:709)
  at java.awt.EventQueue$3.run(EventQueue.java:703)
  at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
  at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
  at java.awt.EventQueue$4.run(EventQueue.java:731)
  at java.awt.EventQueue$4.run(EventQueue.java:729)
  at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
  at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
  at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
  at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
  at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
  at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
  at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
:?: :| :x
when i am in the optifine install menu and press install..
are there any other errors i havent got yet?
every time i reinstall minecraft i get a different error :/
im gonna follow your tutorial tomorrow i hope it helps. it looks like im the only one having this issue.
neilakos
Tue Aug 22, 2017 2:03 pm
Perhaps n00b question, but how often does Minecraft get updated?
chrisoh
Tue Aug 22, 2017 2:13 pm
https://minecraft.gamepedia.com/Version_history
Raspberry Pi 3 model B Idle @ 250mA
  • HDMI +200mA
  • Minecraft 1.9 Server +100mA
  • 2.4Ghz dongle +20mA
Sumie
Fri Aug 25, 2017 4:32 pm
Ha, that was a painful lesson. Using Autofill [Tab] after using partial file/directory names in the terminal is a good way to avoid this in the future.
Alexjenkins
Sun Aug 27, 2017 2:46 pm
Hi - i have a problem downloading the libraries for my pi2: all is get is
GnuTLS: A TLS fatal alert has been received.
GnuTLS: received alert [0]: Close notify
Unable to establish SSL connection.
Any help massively welcome!
rpiMike
Sun Aug 27, 2017 3:49 pm
Which step is it ?
Keep retrying - should get them eventually.
runboy93
Sun Aug 27, 2017 5:00 pm
How this works on Stretch?
rpiMike
Sun Aug 27, 2017 5:01 pm
Works fine on Stretch :)
Return to “Gaming”
