DarkPlatinum
Contact: Website YouTube
Re: How to setup Minecraft 1.12.1 on Raspberry Pi 3
Fri Jun 21, 2019 9:38 am
1.13.2 still is not effective but is better than nothing. As you can see it shows that the server is lagging when it is "overloaded".
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3 1 * Raspberry Pi 3B + :mrgreen:
Check Out My Raspberry Site (Run on a Raspberry Pi 3B :) ): https://html.dynu.net
quavoce
Sun Jun 30, 2019 7:35 am
Minecraft 1.12.2 works really well on the RPi4! By allocating 512MB to GPU on the 2GB Pi, the game world generates much faster and tends to run between 20 and 30 fps. It plays really well now!
One thing to note with Raspbian OS Buster, it doesn’t have the correct jvm library, so I needed to copy “/usr/lib/jvm/jdk-8-oracle-arm32-vfp-hflt” from an older Pi image.
Btw should it be possible to run multiplayer between two Pis running this version of Minecraft? I couldn’t get it to work after opening the game to LAN.
rpiMike
Sun Jun 30, 2019 7:52 am
My new 1.12.2 tutorial should install oracle java 8 for you:
https://www.raspberrypi.org/forums/view ... 8&t=243946
Weeffyy
Mon Jul 01, 2019 12:31 pm
Is it possible to install Minecraft 1.14 on the raspberry pi 4?
rpiMike
Mon Jul 01, 2019 3:27 pm
Only when a 64bit OS is available for the Pi4.
tazz4843
Sat Jul 27, 2019 4:07 am
Upgraded to 1.14.4, OptiFine, it installs no problem, but it won't run. Error posted below:
[22:00:26] [main/ERROR]: Unable to launch
java.lang.ClassNotFoundException: net.minecraft.client.main.Main
	at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:185) ~[launchwrapper-of-2.1.jar:2.1]
	at java.lang.ClassLoader.loadClass(ClassLoader.java:588) ~[?:?]
	at java.lang.ClassLoader.loadClass(ClassLoader.java:521) ~[?:?]
	at java.lang.Class.forName0(Native Method) ~[?:?]
	at java.lang.Class.forName(Class.java:398) ~[?:?]
	at net.minecraft.launchwrapper.Launch.launch(Launch.java:155) [launchwrapper-of-2.1.jar:2.1]
	at net.minecraft.launchwrapper.Launch.main(Launch.java:30) [launchwrapper-of-2.1.jar:2.1]
Caused by: java.lang.NullPointerException
	at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:176) ~[launchwrapper-of-2.1.jar:2.1]
	... 6 more
Any help?
Check me out on Reddit: reddit.com/u/tazz4843
rpiMike
Sat Jul 27, 2019 4:57 am
	... 6 more
Any help?
As far as I am aware 1.13 and above requires a 64 bit OS.
tazz4843
Sat Jul 27, 2019 2:27 pm
	... 6 more
Any help?
Mmm, not that I know. I'm running Java 1.14.4 on my x86 laptop. ~15FPS with a crappy GPU and CPU in local worlds. I only plan to play on servers with 1.14.4 on the Pi.
jdonald
Sat Jul 27, 2019 9:50 pm
I recall the holdup earlier was not having an LWJGL3 build for armhf. Apparently they have an official one as of May: https://github.com/LWJGL/lwjgl3/issues/206
Any help?
These old scripts don't stop on errors, so they'd appear to "install no problem" then print java.lang.ClassNotFoundException: net.minecraft.client.main.Main at the end even if you had something catastrophic from the start like a differently named homedir. You can add #!/bin/sh -e at the top of each script to debug appropriately.
To port the 1.12.1 scripts to 1.13 or above, at a minimum you'll have to make it download the LWJGL3 binary instead of LWJGL2. Alternatively you could try mmlpi which claims support for 1.14.
Also, the 1.13+ thread could be a good spot for continued discussion.
Snapwhiz914
Sun Sep 15, 2019 12:36 pm
I get an error every time I try this guide:
OpenJDK Server VM warning: Option UseConcMarkSweepGC was deprecated in version 9.0 and will likely be removed in a future release.
Exception in thread "main" java.lang.ClassCastException: class jdk.internal.loader.ClassLoaders$AppClassLoader cannot be cast to class java.net.URLClassLoader (jdk.internal.loader.ClassLoaders$AppClassLoader and java.net.URLClassLoader are in module java.base of loader 'bootstrap')
	at net.minecraft.launchwrapper.Launch.<init>(Launch.java:34)
	at net.minecraft.launchwrapper.Launch.main(Launch.java:28)
Any ideas?
jdonald
Mon Sep 16, 2019 3:03 am
This topic was written long ago and Raspbian no longer comes with Oracle Java 8 preinstalled.
Use a newer guide such as this one for 1.12.2: https://www.raspberrypi.org/forums/view ... p?t=243946
Xann
Re: Setting up a controller on RPi Minecraft 1.12.1
Sun Sep 22, 2019 2:48 am
Can you set up a PlayStation DualShock 4 or Xbox Wireless controller with Raspberry Pi Minecraft 1.12.1 optifine?
By Xann. :D
Vishwanth
Wed Sep 25, 2019 7:42 pm
Dear Mike when i tried to download Minecraft i wasn't able to well you see on number 14 you said to run optifine but when i did it says that runoptifine file has not been found please and by the here is a video clip to show you the problem.
https://drive.google.com/file/d/1ThDV5G ... YwHrF/view
Thanks,
VishwanthKarthikeyan
Axel Lopez
Thu Oct 24, 2019 2:13 am
resulta que tengo una version mas reciente del raspbian y me aparece algo como ./runOptifine1_12_1.sh: 52: ./runOptifine1_12_1.sh: /usr/lib/jvm/jdk-8-oracle-arm32-vfp-hflt/jre/bin/java: not found alguien sabe por que sucede?
Moomoo5
Sun Oct 27, 2019 4:45 pm
Please help! I have done everything the tutorial said, and when I run the optifine sh file, I get this error:
pi@raspberrypi:~/Minecraft $ ./runOptifine1_12_1.sh
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   756  100   590  100   166   1328    373 --:--:-- --:--:-- --:--:--  1706
todays access token = eyJhbGciOiJIUzI1NiJ9.eyJzdWIiOiJjNDcwNGMxMGMxYzBmNTg3NDM0ZWMxNTZiNTVhZjhiMyIsIm5iZiI6MTU3MjE5NDU2OSwieWdndCI6IjM1NTQ1YzExODZiYzQyNDY5ZDNkNGMwN2FjNzY3ZGVhIiwic3ByIjoiMGNmZjRhMmJjYjU0NDJlMjk1ZTE2MjQyZDEzNzNiNDIiLCJyb2xlcyI6W10sImlzcyI6ImludGVybmFsLWF1dGhlbnRpY2F0aW9uIiwiZXhwIjoxNTczMDU4NTY5LCJpYXQiOjE1NzIxOTQ1Njl9.p8If7MfNlx5maUDt_hwLPjt0D44kY254YtFX0_i6dRA
100    73  100    62  100    11    218     38 --:--:-- --:--:-- --:--:--   257
MINECRAFT_UUID=0cff4a2bcb5442e295e16242d1373b42
Please help! If you can figure out how to solve this I would be thankfull!
Thanks,
MooMoo5
NanoJedi
Mon Nov 18, 2019 5:26 pm
Hi there.
I love your tutorials, and I followed this one through on my Pi 3 in June and it worked to perfection. I have bought a new SD card because the old one burned out, I try to install Minecraft on it, but i get some error about the java not being there. Can you do an updated tutorial about this bug as I would highly appreciate it. Thanks!
rpiMike
Mon Nov 18, 2019 8:52 pm
Hi there.
Try the more recent tutorial https://www.raspberrypi.org/forums/view ... 8&t=243946
Moomoo5
Sat Nov 23, 2019 5:25 pm
Please help me! I did everything the tutorial said, but it didnt work.
Why does it work for everyone else except me?
rpiMike
Sat Nov 23, 2019 6:36 pm
Did you use the 1.12.2 tutorial in the link on the previous post or the very start of this tutorial?
seb.grant1
Mon Dec 02, 2019 1:57 am
my runOptifine thigny reads as "no java found"
rpiMike
Mon Dec 02, 2019 7:13 am
Use the newer tutorial https://www.raspberrypi.org/forums/view ... 8&t=243946
Return to “Gaming”
