Page 15 of 16
Re: How to setup Minecraft 1.12.1 on Raspberry Pi 3
Posted: Mon Mar 18, 2019 12:13 am
by HawaiianPi
whyme193 wrote:
Sun Mar 17, 2019 2:19 pm
hello everybody me and my brother just bought RPi 3 b+ with cases, heatsinks, fans and sd cards.Following the tutorial i have managed to get minecraft 1.12.1 running smooth with little to no lag. However the plan was for us to get modded minecraft up and running...
The Pi can barely run Minecraft as it is. Other than mods that make it run faster (Optifine), I think your goals may be too ambitious.
Firstly the way i understand it...
As I recall, copying and pasting that one line was all I needed to do to get 1.12.2 running. I did fiddle with the memory settings near the end of the script to try and get a longer render distance stable, and I managed to get it running at render distance 3, but only at low resolution. Other than that, I didn't play with it much.
I messed around on my Creeper Pie SMP server a bit, just because I could. It was a briefly amusing novelty to play Minecraft on a Pi, on a multi-player server also run on a Pi, but the Raspberry Pi is a really poor client machine for playing the game (works quite well as a server, though).
Good luck, but be sure to manage your expectations, because adding too many mods will likely make the game unplayable.
Posted: Mon Mar 18, 2019 12:43 am
by whyme193
My modding expectations are very low but it would be nice to add a small amount of light weight mods.
I unistalled minecraft completely restarted. trying for 1.12.2 from the start and using rpiMike's second run script thats already set for 1.12.2 as before it still wont launch but seems to be new error
 ./runOptifine1_12_2.sh
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   796  100   625  100   171    873    238 --:--:-- --:--:-- --:--:--   872
todays access token = 1e748edd5fe44b0bb1d101b84620cd38
100    75  100    63  100    12    148     28 --:--:-- --:--:-- --:--:--   148
MINECRAFT_UUID=21db5fafd18c4cb3999276c413b58178
Java HotSpot(TM) Client VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
[20:31:30] [main/INFO]: Loading tweak class name optifine.OptiFineTweaker
[20:31:30] [main/ERROR]: Unable to launch
java.lang.ClassNotFoundException: optifine.OptiFineTweaker
	at java.net.URLClassLoader.findClass(URLClassLoader.java:381) ~[?:1.8.0_65]
	at java.lang.ClassLoader.loadClass(ClassLoader.java:424) ~[?:1.8.0_65]
	at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331) ~[?:1.8.0_65]
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:1.8.0_65]
	at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:106) ~[launchwrapper-1.12.jar:?]
	at java.lang.Class.forName0(Native Method) ~[?:1.8.0_65]
	at java.lang.Class.forName(Class.java:348) ~[?:1.8.0_65]
	at net.minecraft.launchwrapper.Launch.launch(Launch.java:98) [launchwrapper-1.12.jar:?]
	at net.minecraft.launchwrapper.Launch.main(Launch.java:28) [launchwrapper-1.12.jar:?]
However once again if i switch to try and run 1.12.1 it works with no issues 60 FPS and no lag.
Posted: Mon Mar 18, 2019 2:59 am
by whyme193
I now have minecraft 1.12.2 up and running, I successfully installed forge, I copied Mikesome13's run script and named it runforge1_12_2.sh now I run the .sh in the terminal and
pi@raspberrypi:~/Minecraft $ ./runforge1_12_2.sh  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
100   796  100   625  100   171    812    222 --:--:-- --:--:-- --:--:--   812
todays access token = cdce55df042041edbbe83fabf76fe4b6
100    75  100    63  100    12    110     21 --:--:-- --:--:-- --:--:--   110
[22:57:16] [main/INFO]: Loading tweak class name net.minecraftforge.fml.common.launcher.FMLTweaker
[22:57:16] [main/ERROR]: Unable to launch
java.lang.ClassNotFoundException: net.minecraftforge.fml.common.launcher.FMLTweaker
Maybe there is something i should do prior to starting the run script? idk every step along this set up has given some kind of issues but atleast of already started learning a fair bit about raspian now.
Thanks in advanced for any help. :)
Posted: Mon Mar 18, 2019 5:23 am
by HawaiianPi
Look further back in this thread. I'm pretty sure there were others trying to get Forge working, but I don't recall the outcome.
Posted: Mon Mar 18, 2019 6:24 am
by Gess1t
rpiMike wrote:
Mon Mar 11, 2019 9:01 pm
I think something else is missing from Stretch Lite that is stopping the GL driver from working.
Have you got a spare SD Card you can install Stretch with Desktop?
Done what you suggested, but now, Minecraft need permission for me to click play when wanting to download the last bit of data for optifine.
java.io.FileNotFoundException: /home/pi/.minecraft/versions/1.12.1-OptiFine_HD_U_C5/1.12.1-OptiFine_HD_U_C5.json (Permission non accordée)
	at java.io.FileOutputStream.open0(Native Method) ~[?:1.8.0_65]
	at java.io.FileOutputStream.open(FileOutputStream.java:270) ~[?:1.8.0_65]
	at java.io.FileOutputStream.<init>(FileOutputStream.java:213) ~[?:1.8.0_65]
	at java.io.FileOutputStream.<init>(FileOutputStream.java:162) ~[?:1.8.0_65]
	at java.io.PrintWriter.<init>(PrintWriter.java:263) ~[?:1.8.0_65]
	at net.minecraft.launcher.updater.LocalVersionList.saveVersion(LocalVersionList.java:77) ~[launcher.jar:1.6.89-j]
	at net.minecraft.launcher.updater.MinecraftVersionManager.installVersion(MinecraftVersionManager.java:340) ~[launcher.jar:1.6.89-j]
	at com.mojang.launcher.game.runner.AbstractGameRunner.playGame(AbstractGameRunner.java:101) [launcher.jar:1.6.89-j]
	at net.minecraft.launcher.game.GameLaunchDispatcher$1.run(GameLaunchDispatcher.java:111) [launcher.jar:1.6.89-j]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_65]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_65]
	at java.lang.Thread.run(Thread.java:745) [?:1.8.0_65]
Permission non arccordée = Access Denied
EDIT: ok, i definitly had permissions issues on my raspberry pi, that i've fixed by editing them manually i followed the exact setup, and this isn't working anymore
Ok, i get the same issue than before i reflashed the OS, so i guess a kid broke the code, however, i'm wandering if the game is working for the others.
Edit 2 : fixed! I just started again from step 7 to step 11, and it was sucessful!
Apparently, the script will need you to fill the username in order for the script to recover the player's UUID from mojangs servers.
Posted: Mon Mar 18, 2019 3:57 pm
by Frederk
Sometimes i get these errors:
AL lib: (EE) ALCplaybackAlsa_mixerProc: available update failed: Broken pipe
AL lib: (EE) ALCplaybackAlsa_mixerProc: mmap commit error: Broken pipe
and my FPS drop to below 1. This occurs randomly and it is really annoying sometimes bc. I have to restart minecraft. I already tried turning down all sounds and using a resource pack without sounds without a result.
Posted: Tue Mar 19, 2019 2:46 pm
by DarkPlatinum
I had forge working. I had to try different versions though as it was hard to get mods paired with it.
Posted: Tue Mar 19, 2019 9:47 pm
by whyme193
Before even creating my account I've read this thread over completely at least twice. I'm only making posts because I've done everything mentioned in this thread and it did not yield the same result for me, probably through an error of mine but what error I have no clue. But anyways yes there were others trying to get forge working and they did, Mikesome13 also mentioned it only works with version 1.12.2.
Posted: Mon Apr 08, 2019 10:01 pm
by ZombieTiTan
When I put the ./runOptifine1_12_1.sh into the terminal this is what I get
Unrecognized option: --username
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
Can someone help. I have found the "--username" is in the runOptifine1_12_1.sh file but I dont know what to do with it. I am really new to this stuff and have no idea what to do. :cry: Please Help :cry:
Posted: Mon Apr 08, 2019 10:09 pm
by rpiMike
Did you amend the following with your details without changing the variable names?
MINECRAFT_LOGIN=aaa@bbb.ccc
MINECRAFT_USERNAME=abcdefghi
MINECRAFT_PASSWORD=xxxxxxxx
If you've got any unusual characters you may need double quotes.
Posted: Mon Apr 08, 2019 10:21 pm
by ZombieTiTan
I already have, I don't know if I have any unusual characters but I did just to be safe, I found out what I did when you said at the bottom of the whole tutorial
1 Install required version using java -jar Minecraft.jar - and allow to crash
2 Scroll up in terminal window and find last ../jre/bin/java command, scroll across and find ‘-cp ’, copy this path list until ‘ net.minecraft.launchwrapper.Launch’
3 Paste this text into the cp= in the run.sh script
Well I copied the -cp aswell I just deleted that and now it works! Thanks! :D :D
Posted: Mon Apr 08, 2019 10:58 pm
by ZombieTiTan
Hey @rpiMike, I have no idea if @ works but what the heck. Just a quick question what is the latest version of Minecraft running on the pi?
Posted: Mon Apr 08, 2019 11:01 pm
by rpiMike
The latest version that is currently possible is 1.12.2
1.13 and above requires lwjgl3 which is not available on the Pi - yet
https://github.com/LWJGL/lwjgl3/issues/206
Posted: Sat Apr 13, 2019 9:03 am
by ancba
Why i cannot use the last command,it says no permission
Posted: Sat Apr 13, 2019 3:05 pm
by rpiMike
Do you mean you get permission denied running './runOptifine1_12_1.sh' ?
Did you 'sudo chmod +x runOptifine1_12_1.sh' (end of step 12)
Posted: Fri Apr 26, 2019 9:43 am
by ancba
yes ,and I cannot use this command.but I update my system,they can work.thank you :D
Posted: Fri May 03, 2019 11:26 am
by DarkPlatinum
I made a post on my site on how to get Forge 1.12.2 working. Thanks for your script rpiMike!
My website post: https://html.dynu.net/index.php/how-to- ... on-1-12-2/
Raspberry Pi forums post: viewtopic.php?f=78&t=239592
Trying to make pi run minecraft 1.14.1
Posted: Fri May 17, 2019 2:22 pm
by jack jobby
I found the cp path list for 1.14.1 but could not find ‘ net.minecraft.launchwrapper.Launch’ in it so would it be possible for somebody to send me the correct cp ?
Re: Trying to make pi run minecraft 1.14.1
Posted: Fri May 17, 2019 3:36 pm
by rpiMike
Not possible unless you can get LWJGL3 compiling for ARM.
Posted: Fri May 17, 2019 6:12 pm
by HawaiianPi
Version 1.12.2 is the latest version you can run on a Raspberry Pi.
Even if you could get LWJGL3 compiled for ARM it's highly doubtful newer versions would be playable on a Pi. My budget gaming laptop with a quad-core i7, 16GB RAM and Nvidia GPU is pushed hard playing 1.13.2 or 1.14.1, so I can't imagine our little Pi computers running them at anything more than slideshow frame rates.
Posted: Wed May 22, 2019 10:24 pm
by BigrahamLincoln
every time I try to download glxgears it doesn't work and so in the end on the last step it won't work! please help
Posted: Thu May 23, 2019 1:09 am
by BigrahamLincoln
what do I do if it says unmet dependancies
Posted: Thu May 23, 2019 10:00 am
by rpiMike
What says unmet dependancies ?
Did you get glxgears working?
Which Pi are you using? Are you using the latest Raspbian Stretch? Are you using the official power supply? Are you using a 1080p HDMI screen?
Posted: Thu Jun 20, 2019 12:57 pm
by paulwratt
This should be working now according to:
https://github.com/LWJGL/lwjgl3/issues/ ... -496018922
I suggest (based on @HawaiianPi comments) that fullscreen 640x480 + kms-full and draw distance of 2 might get you v1.14 playable
Worth a crack just to see if it will run without crashing, even if the FPS is low.
Cheers, and thanks for all the effort put into this thread
Paul
Posted: Thu Jun 20, 2019 5:36 pm
by rpiMike
I have had 1.14.2 running but only lasted about 1 minute before crashing.
1.13.2 seems better: https://www.youtube.com/watch?v=TNCQXd1QzAc
