Haemogoblin
Midi and Dosbox
Wed May 24, 2017 9:13 am
Morning all
Random question as I'm trying to get WingCommander to work.
Is it normal to get an error like this with dosbox?
ALSA:Can't subscribe to MIDI port (65:0) nor (17:0)
MIDI:Can't open device:alsa with config:.
MIDI:Opened device:none
Cheers
Blackadder: Right Baldrick, let's try again, shall we? This is called adding. If I have two beans, and then I add two more, what do I have?
Baldrick: Some beans
Haemogoblin
Re: Midi and Dosbox
Wed May 24, 2017 5:16 pm
Anyone? Yes? No? :D
Re: Midi and Dosbox
Wed May 24, 2017 5:22 pm
Haemogoblin wrote:Anyone? Yes? No? :D
No one gets paid here, this Forum is run on Voluntary basis, jeez !!!!!
Retired disgracefully.....
Zebu
Re: Midi and Dosbox
Thu May 25, 2017 2:14 am
thats not so much an error as telling you that you have no midi device.
you could run timidity or the like in server mode that would work for general midi games but wing commander only supports adlib or MT32.
I believe some guys on the vogons forum got the MUNT mt32 emulator going on raspbian but i have not tried that
you could also use a USB midi adapter or a midi hat and a real MT-32 module but that is a much larger investment.
the mt-32 music is really nice but the easy way is to just use the ADLIB emulation built in to dosbox
Otto
Re: Midi and Dosbox
Thu May 25, 2017 12:34 pm
Haemogoblin wrote:Morning all
Cheers
Use rpix86 instead!
See the sticky:
viewtopic.php?f=78&t=32934
Return to “Gaming”
