TheHarpoon_21
Add space for storing games
Fri Feb 19, 2016 12:33 am
Hi all,
I was looking around for games to install and decided that I wanted to install Quake 3 on my RaspberryPi, however during the installation/setup, I would run in to the issue of not having enough space on the Pi.
This is the guide I was following: viewtopic.php?f=78&t=18853
Would this require me to format a USB Stick/ Hard Drive to the Pi in order to use it as a built in storage?
I tried just plugging in a USB stick and everything was fine until I did not have permission to do step: 4. (
Now you can begin the compilation process by typing ./build.sh
) Even as the root/sudo, I did not have permission to do so.
Thoughts and ideas are appreciated thanks!
elatllat
Re: Add space for storing games
Fri Feb 19, 2016 2:23 pm
man mount
look for gmask
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
GTR2Fan
Fri Feb 19, 2016 3:00 pm
TheHarpoon_21 wrote:Hi all,
Most Pi games are tiny in relation to the size of even the smallest of SD cards most people use with a Pi, and Quake 3 is no exception to this. Did you expand the filesystem after installing Raspbian? It's the first option in raspi-config.
I'd also be interested to know which model of Pi you have and if you're overclocking or not so we can compare compilation times. The Pi2B in my sig compiles Quake 3 in exactly 6mins and 32 secs. :)
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
Return to “Gaming”
