Stella Atari Emulator in Jessie
Posted: Sat Oct 10, 2015 6:58 pm
by rubikwizard
Hi
I am unable to get the Stella emulator working in the new Jessie image. I installed it as I used to under Wheezy
sudo apt-get install stella
but it will not start. The window flickers a bit and then it closes.
It is possible to start it with
stella -video software
but it is too slow to be of any use. After reading viewtopic.php?p=826344#p826344 I am guessing it is something to do with OpenGLES but I have no idea what to look at to try and get it working.
Thanks for any advice.
Re: Stella Atari Emulator in Jessie
Posted: Sun Oct 11, 2015 9:03 am
by tvjon
This very helpful post from exobug:
viewtopic.php?f=67&t=122525
looks like it'll solve your problem.
I installed stella about an hour ago after reading your post, & had the same errors as you.
So, off to GitHub to get the Retropie setup.
Set the script going...
Rebooted to the console (not X) & now:
pi@j1 ~ $ stella -video opengles2
brings up the setup screen.
That's as far as I've reached, as my old ST is in the loft, & I'll need to work out how to get the ROM code before I can proceed, but you might like to try it as you obviously already have the necessary tools.
I briefly tried it under the GUI, but just an outline window appeared so presumably it's not meant to be used under X.
HTH.
Posted: Sun Oct 11, 2015 10:18 pm
by rubikwizard
Thanks for this tvjon. I haven't had time to try it yet but will do over the next few days.
It always worked under the GUI in Wheezy ...
Posted: Sat Oct 24, 2015 8:59 pm
by rubikwizard
Still haven't managed to get Stella working in Jessie like it did in Wheezy.
Any more ideas anyone?
Posted: Mon Oct 26, 2015 1:06 am
by Vanfanel
rubikwizard wrote:Still haven't managed to get Stella working in Jessie like it did in Wheezy.
Stop using standalone emulators and use their libretro ports instead.
For Stella: https://github.com/libretro/stella-libretro.git
You will get fullscreen emulation with perfectly synced audio and video, no tearing and you can even use shaders to simulate scanlines and other effects.
Posted: Tue Feb 09, 2016 8:47 pm
by rubikwizard
I just installed the new version of Jessie and enabled the new OpenGL driver. I was pleased to see that Stella is now working again at full speed when in the default small window but if I go to full screen it is horrendously slow. OpenGL is selected in the settings.
Any ideas anyone?
Posted: Mon Sep 05, 2016 3:49 pm
by DavidS
HTH.
You could use EmuTOS to run it till you can get your ST hooked up. EmuTOS is an open source re-implementation of TOS built around the GPL'd source of DR-GEM with additions made for the GEMDOS and BIOS.
