pi@raspberrypi:~/Downloads/Half-Life-Repos/xash3d $ cmake . -DRPI=ON -DXASH_SDL=ON -DXASH_VGUI=OFF -DHL_SDK_DIR=hlsdk/ -DCMAKE_C_FLAGS="-mcpu=cortex-a7 -mfloat-abi=hard -mfpu=neon -funsafe-math-optimizations" -DCMAKE_CXX_FLAGS="-mcpu=cortex-a7 -mfloat-abi=hard -mfpu=neon -funsafe-math-optimizations"
<FindSDL2.cmake>
</FindSDL2.cmake>
CMake Error at /usr/share/cmake-3.0/Modules/FindPackageHandleStandardArgs.cmake:136 (message):
Could NOT find SDL2 (missing: SDL2_INCLUDE_DIR)
Call Stack (most recent call first):
/usr/share/cmake-3.0/Modules/FindPackageHandleStandardArgs.cmake:343 (_FPHSA_FAILURE_MESSAGE)
cmake/FindSDL2.cmake:172 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
engine/CMakeLists.txt:71 (find_package)
-- Configuring incomplete, errors occurred!
See also "/home/pi/Downloads/Half-Life-Repos/xash3d/CMakeFiles/CMakeOutput.log".
See also "/home/pi/Downloads/Half-Life-Repos/xash3d/CMakeFiles/CMakeError.log".
I also tried it today. But activating the OpenGL driver didn't work so well for me. My screen just looks absolutley strange and distorted. And any program I start crashes. I'm going to play around with resolution maybe that helps.I played up through most of "We've Got Hostiles!" It sometimes crashes, but I just start it up again and load the last auto-saved game. The whole game intro played well. The sound can get choppy, garbled and full of static. Restarting the game every once in a while can improve the sound issues, but the sound doesn't work very well in general. Multiplayer doesn't seem to work -- I only tried once, but it crashed shortly after joining and starting a game. Also, the in-game console doesn't seem to work (pressing the [`/~] key), the console slides down, but I am unable to type anything into it. Maybe I'm doing something wrong, I'm not that familiar with the game.
pi@raspberrypi:~/Half-Life $ LIBGL_FB=1 LIBGL_BATCH=1 LD_LIBRARY_PATH=/opt/vc/lib:/home/pi/glshim/lib:. ./xash3d -console -debug
[18:24:49] /home/pi/Half-Life is working directory now
(build 3224) started at Feb23 2016 [18:24.49]
(build 3224) fallback to dedicated mode
at Feb23 2016 [18:24.51]
[18:24:51] /home/pi/Half-Life is working directory now
(build 3224) started at Feb23 2016 [18:24.51]
[18:24:53] execing server.cfg
[18:24:53] Please add "defaultmap" cvar with default map name to your server.cfg!
[18:24:53] Server IP address: 127.0.1.1:27015
[18:24:53] execing config.cfg
[18:32:30] /home/pi/Half-Life is working directory now
(build 3224) started at Feb23 2016 [18:32.30]
at Feb23 2016 [18:32.32]
[18:32:32] /home/pi/Half-Life is working directory now
(build 3224) started at Feb23 2016 [18:32.32]
[18:32:34] execing server.cfg
[18:32:34] Server IP address: 127.0.1.1:27015
[18:32:34] ^3Warning:^7 loading library dlls/hl_i386.so: valve/dlls/hl_i386.so: cannot open shared object file: No such file or directory
[18:32:34] ^1Error:^7 SV_InitGame: can't initialize "dlls/hl_i386.so"
[18:32:34] execing config.cfg
-DRPI=ON wasn't activated so I changed it with ccmake, but after recompiling the game still won't start.Build xash3d:Now make hl.so:Code: Select all
cd ~ git clone https://github.com/SDLash3D/xash3d git clone https://github.com/ptitSeb/halflife cp -a halflife/. xash3d/hlsdk/ cd xash3d cmake . -DRPI=ON -DXASH_SDL=ON -DXASH_VGUI=OFF -DHL_SDK_DIR=hlsdk/ -DCMAKE_C_FLAGS="-mcpu=cortex-a7 -mfloat-abi=hard -mfpu=neon -funsafe-math-optimizations" -DCMAKE_CXX_FLAGS="-mcpu=cortex-a7 -mfloat-abi=hard -mfpu=neon -funsafe-math-optimizations" make -j4 cp engine/libxash.so /home/pi/Half-Life cp mainui/libxashmenu.so /home/pi/Half-Life cp game_launch/xash3d /home/pi/Half-Life
Build XashXT:Code: Select all
cd hlsdk/dlls make -f Makefile.rpi -j4 cp hl.so /home/pi/Half-Life
cd ~ git clone https://github.com/ptitSeb/XashXT cd XashXT/client make -f Makefile.rpi -j4 cp client.so /home/pi/Half-Life
[19:07:21] /home/pi/Half-Life is working directory now
(build 3224) started at Feb27 2016 [19:07.21]
at Feb27 2016 [19:07.23]
[19:07:23] /home/pi/Half-Life is working directory now
(build 3224) started at Feb27 2016 [19:07.23]
[19:07:25] execing server.cfg
[19:07:25] Server IP address: 127.0.1.1:27015
[19:07:25] ^3Warning:^7 loading library dlls/hl_i386.so: valve/dlls/hl_i386.so: cannot open shared object file: No such file or directory
[19:07:25] ^1Error:^7 SV_InitGame: can't initialize "dlls/hl_i386.so"
[19:07:25] execing config.cfg
pi@raspberrypi:~/xash3d $ cmake . -DRPI=ON -DXASH_SDL=ON -DXASH_VGUI=OFF -DHL_SDK_DIR=hlsdk/ -DCMAKE_C_FLAGS="-mcpu=cortex-a7 -mfloat-abi=hard -mfpu=neon -funsafe-math-optimizations" -DCMAKE_CXX_FLAGS="-mcpu=cortex-a7 -mfloat-abi=hard -mfpu=neon -funsafe-math-optimizations"
-- The C compiler identification is GNU 4.9.2
-- The CXX compiler identification is GNU 4.9.2
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
<FindSDL2.cmake>
-- Looking for include file pthread.h
-- Looking for include file pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
</FindSDL2.cmake>
-- Found SDL2: /usr/local/lib/libSDL2main.a;/usr/local/lib/libSDL2.so;-lpthread
<FindSDL2.cmake>
</FindSDL2.cmake>
-- Configuring done
-- Generating done
CMake Warning:
Manually-specified variables were not used by the project:
RPI
-- Build files have been written to: /home/pi/xash3d
-- checking for one of the modules 'sdl2'
CMake Error at /usr/share/cmake-3.0/Modules/FindPkgConfig.cmake:425 (message):
None of the required 'sdl2' found
engine/CMakeLists.txt:87 (pkg_search_module)
-- checking for one of the modules 'SDL2_image'
None of the required 'SDL2_image' found
engine/CMakeLists.txt:88 (pkg_search_module)
game_launch/CMakeLists.txt:42 (pkg_search_module)
See also "/home/pi/xash3d/CMakeFiles/CMakeOutput.log".
pi@raspberrypi:~/xash3d $ PATH=/home/pi/SDL2GL/bin
pi@raspberrypi:~/xash3d $ PKG_CONFIG_PATH=/home/pi/SDL2GL/lib/pgk-config
bash: cmake: command not found
pi@raspberrypi:~/xash3d $ /usr/bin/cmake . -DRPI=ON -DXASH_SDL=ON -DXASH_VGUI=OFF -DHL_SDK_DIR=hlsdk/ -DCMAKE_C_FLAGS="-mcpu=cortex-a7 -mfloat-abi=hard -mfpu=neon -funsafe-math-optimizations" -DCMAKE_CXX_FLAGS="-mcpu=cortex-a7 -mfloat-abi=hard -mfpu=neon -funsafe-math-optimizations"-- checking for one of the modules 'sdl2'
pi@raspberrypi:~/xash3d $ echo $PATH
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
pi@raspberrypi:~/xash3d $ PATH=/home/pi/SDL2GL/bin:$PATH
pi@raspberrypi:~/xash3d $ PKG_CONFIG_PATH=/home/pi/SDL2GL/lib/pgk-config:$PKG_CONFIG_PATH
/home/pi/SDL2GL/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
pi@raspberrypi:~/xash3d $ cmake -DRPI=ON -DXASH_SDL=ON -DXASH_VGUI=OFF -DHL_SDK_DIR=hlsdk/ -DCMAKE_C_FLAGS="-mcpu=cortex-a7 -mfloat-abi=hard -mfpu=neon -funsafe-math-optimizations" -DCMAKE_CXX_FLAGS="-mcpu=cortex-a7 -mfloat-abi=hard -mfpu=neon -funsafe-math-optimizations"
GNU gdb (Raspbian 7.7.1+dfsg-5) 7.7.1
Copyright (C) 2014 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "arm-linux-gnueabihf".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from ./xash3d...done.
(gdb) r
Starting program: /home/pi/Half-Life/xash3d
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
[New Thread 0x745ab460 (LWP 8014)]
[New Thread 0x73d8f460 (LWP 8015)]
[New Thread 0x733ff460 (LWP 8016)]
[New Thread 0x72bff460 (LWP 8017)]
[New Thread 0x723ff460 (LWP 8018)]
Program received signal SIGSEGV, Segmentation fault.
0x00000000 in ?? ()
(gdb) bt full
#0 0x00000000 in ?? ()
No symbol table info available.
#1 0x747b7070 in GL_SetDefaults ()
at /home/pi/hl/xash3d/engine/client/gl_vidnt.c:1841
i = 1954255980
#2 0x747b9794 in R_Init () at /home/pi/hl/xash3d/engine/client/gl_vidnt.c:2222
No locals.
#3 0x747439ac in CL_Init () at /home/pi/hl/xash3d/engine/client/cl_main.c:1833
loaded = (unknown: 160664)
#4 0x74826190 in Host_Main (argc=1, argv=0x7efff654,
progname=0x10f00 "valve", bChangeGame=0, func=0x10c24 <Sys_ChangeGame>)
at /home/pi/hl/xash3d/engine/common/host.c:1048
oldtime = 0
newtime = 0
event = {type = 139272, common = {type = 139272,
timestamp = 1995113128}, window = {type = 139272,
timestamp = 1995113128, windowID = 2130703552, event = 224 '\340',
padding1 = 243 '\363', padding2 = 234 '\352', padding3 = 118 'v',
data1 = 0, data2 = 1996484688}, key = {type = 139272,
timestamp = 1995113128, windowID = 2130703552, state = 224 '\340',
repeat = 243 '\363', padding2 = 234 '\352', padding3 = 118 'v',
keysym = {scancode = SDL_SCANCODE_UNKNOWN, sym = 1996484688,
mod = 61520, unused = 1954703044}}, edit = {type = 139272,
text = "\340\363\352v\000\000\000\000P\360\377vP\360\377v\304f\202t\000\000\000\000\234\375\352v8 \002", start = 69280, length = 68500}, text = {
type = 139272, timestamp = 1995113128, windowID = 2130703552,
text = "\340\363\352v\000\000\000\000P\360\377vP\360\377v\304f\202t\000\000\000\000\234\375\352v8 \002"}, motion = {type = 139272,
timestamp = 1995113128, windowID = 2130703552, which = 1995109344,
state = 0, x = 1996484688, y = 1996484688, xrel = 1954703044,
yrel = 0}, button = {type = 139272, timestamp = 1995113128,
windowID = 2130703552, which = 1995109344, button = 0 '\000',
state = 0 '\000', clicks = 0 '\000', padding1 = 0 '\000',
x = 1996484688, y = 1996484688}, wheel = {type = 139272,
x = 0, y = 1996484688}, jaxis = {type = 139272,
timestamp = 1995113128, which = 2130703552, axis = 224 '\340',
value = 0, padding4 = 0}, jball = {type = 139272,
timestamp = 1995113128, which = 2130703552, ball = 224 '\340',
xrel = 0, yrel = 0}, jhat = {type = 139272,
timestamp = 1995113128, which = 2130703552, hat = 224 '\340',
value = 243 '\363', padding1 = 234 '\352', padding2 = 118 'v'},
jbutton = {type = 139272, timestamp = 1995113128,
which = 2130703552, button = 224 '\340', state = 243 '\363',
padding1 = 234 '\352', padding2 = 118 'v'}, jdevice = {
type = 139272, timestamp = 1995113128, which = 2130703552},
caxis = {type = 139272, timestamp = 1995113128, which = 2130703552,
axis = 224 '\340', padding1 = 243 '\363', padding2 = 234 '\352',
padding3 = 118 'v', value = 0, padding4 = 0}, cbutton = {
button = 224 '\340', state = 243 '\363', padding1 = 234 '\352',
padding2 = 118 'v'}, cdevice = {type = 139272,
timestamp = 1995113128, which = 2130703552}, quit = {
type = 139272, timestamp = 1995113128}, user = {type = 139272,
timestamp = 1995113128, windowID = 2130703552, code = 1995109344,
data1 = 0x0, data2 = 0x76fff050 <_rtld_global>}, syswm = {
type = 139272, timestamp = 1995113128, msg = 0x7efff4c0},
tfinger = {type = 139272, timestamp = 1995113128,
touchId = 8568929386554717376, fingerId = 8574836441924763648,
x = 2.59552698e+33, y = 8.26517244e+31, dx = 0,
dy = 2.38308843e+33, pressure = 1.95228902e-40}, mgesture = {
touchId = 8568929386554717376, dTheta = 0, dDist = 2.59552698e+33,
x = 2.59552698e+33, y = 8.26517244e+31, numFingers = 0,
padding = 0}, dgesture = {type = 139272, timestamp = 1995113128,
touchId = 8568929386554717376, gestureId = 8574836441924763648,
numFingers = 1996484688, error = 8.26517244e+31, x = 0,
y = 2.38308843e+33}, drop = {type = 139272,
timestamp = 1995113128, file = 0x7efff4c0 "8 \002"},
padding = "\b \002\000\250\002\353v\300\364\377~\340\363\352v\000\000\000\000P\360\377vP\360\377v\304f\202t\000\000\000\000\234\375\352v8 \002\000\240\016\001\000\224\v\001\000\304f\202t"}
#5 0x00010da0 in main (argc=1, argv=0x7efff654)
at /home/pi/hl/xash3d/game_launch/xash.c:145
No locals.
(gdb) q
A debugging session is active.
Inferior 1 [process 8011] will be killed.
Quit anyway? (y or n)
sudo apt-get install git
sudo apt-get install cmake
sudo apt-get install cmake-curses-gui
sudo apt-get install libsdl2-2.0-0 libX11-dev libxext-dev
sudo apt-get install build-essential libfreeimage-dev libopenal-dev libpango1.0-dev libsndfile-dev libudev-dev libasound2-dev libjpeg8-dev libtiff5-dev libwebp-dev automake
cd ~
wget https://www.libsdl.org/release/SDL2-2.0.3.tar.gz
tar zxvf SDL2-2.0.3.tar.gz
cd SDL2-2.0.3 && mkdir build && cd build
../configure --host=armv7l-raspberry-linux-gnueabihf --disable-pulseaudio --disable-esd --disable-video-mir --disable-video-wayland --enable-video-x11 --enable-video-opengl
make -j 4
sudo make install
cd ~
wget http://www.libsdl.org/projects/SDL_image/release/SDL2_image-2.0.0.tar.gz
tar zxvf SDL2_image-2.0.0.tar.gz
cd SDL2_image-2.0.0 && mkdir build && cd build
../configure
make -j 4
sudo make install
cd ~
git clone https://github.com/ptitSeb/glshim
cd glshim
cmake . -DBCMHOST=1; make GL
cd ~
mkdir /home/pi/Half-Life
cd ~
git clone https://github.com/ptitSeb/xash3d
cd xash3d
make -j4
cd hlsdk/dlls
cd ~
cd XashXT/client
cd ~
sudo rm -r xash3d XashXT zxvf SDL2-2.0.3.tar.gz
sudo ldconfig
cd /home/pi/Half-Life
[18:42:33] . is working directory now
(build 3153) started at Mar06 2016 [18:42.33]
[18:42:33] 1 joysticks found
[18:42:33] Joystick Microsoft X-Box 360 pad has 6 axes
[18:42:35] execing video.cfg
[18:42:35] execing opengl.cfg
[18:42:35] CL_Shutdown()
(build 3153) fallback to dedicated mode
at Mar06 2016 [18:42.35]
=================================================================================[18:42:35] . is working directory now
(build 3153) started at Mar06 2016 [18:42.35]
[18:42:35] 1 joysticks found
[18:42:35] Joystick Microsoft X-Box 360 pad has 6 axes
[18:42:37] execing server.cfg
CL_Init, game = Half-Life
dlopen("./hl.so", RTLD_LAZY)=0x34c940, error=(null)
[18:42:37] Dll loaded for mod Half-Life
[18:42:37] Server loaded
[18:42:37] Server IP address 127.0.1.1:27015
[18:42:37] Spawn Server: lambda_bunker
[18:42:38] execing skill.cfg
[18:42:38] server: GAME SKILL LEVEL:1
[18:42:38] SV_LoadFromFile: 0 entities inhibited
[18:42:38] 8 player server started
[18:42:38] Usage: map <mapname>
[18:42:38] execing config.cfg
[18:42:43] SV_Shutdown: Server shutdown
[18:42:43] CL_Shutdown()
