CockPitt
Re: Xash3D Engine on Raspberry Pi
Thu Jul 16, 2015 6:28 am
Sorry, it's my first post here is the full post:
Hey there,
I wondered if a game like Half Life 1 could run on the Raspberry Pi 2.
After some investigation I discovered the https://github.com/SDLash3D/xash3d Engine. With it's help it's possible to run HF1 on Android.
I'm not very experienced in programming, compiling and all that stuff but I thought the installation guide would work on raspbian too... it didn't. At least the way I tried.
If I type the command "-DXASH_VGUI=yes -DCMAKE_OSX_ARCHITECTURES=i386 .." I get following Error:
-- checking for one of the modules 'sdl2'
CMake Error at /usr/share/cmake-2.8/Modules/FindPkgConfig.cmake:363 (message):
None of the required 'sdl2' found
Call Stack (most recent call first):
engine/CMakeLists.txt:75 (pkg_search_module)
-- checking for one of the modules 'SDL2_image'
None of the required 'SDL2_image' found
engine/CMakeLists.txt:76 (pkg_search_module)
game_launch/CMakeLists.txt:39 (pkg_search_module)
-- Configuring incomplete, errors occurred!
Does somebody know what I did wrong and how I can fix this Error or is it impossible to run the Xash3D Engine on raspian?
Thu Jul 16, 2015 6:37 am
The RPi has ARM Architecture, you are above stating Intel i386 x86 Architecture
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
CockPitt
Thu Jul 16, 2015 8:10 am
Is it possible to modify the Command so that it works?
super213
Sun Jul 26, 2015 1:10 am
no sadly the rpi has a ARM. but it fits the pi in ways :D. but you need to learn programming a little then modify the code for ARM Architecture! or try to recompile but it mostly wont work!
Hiradur
Mon Jul 27, 2015 3:27 pm
1. It's missing the sdl2 dev files. Build sdl2 yourself, there are some tutorials out there.
2. Use
cmake -DHL_SDK_DIR=PATH_TO_HALF_LIFE -DXASH_SDL=yes -DXASH_VGUI=yes
still no guarantee that it'll work in the end but if you managed to compile it it would be a start.
super213
Mon Jul 27, 2015 11:14 pm
Hiradur wrote:1. It's missing the sdl2 dev files. Build sdl2 yourself, there are some tutorials out there.
2. Use
But Wouldn't there be things like library's pre compiled for x86 and other things that are for x86 only?
Hiradur
Tue Jul 28, 2015 7:43 am
super213 wrote:But Wouldn't there be things like library's pre compiled for x86 and other things that are for x86 only?
I don't know. I didn't realize it requires the HL1 SDK. But apparently it runs on the OpenPandora: http://pandoralive.info/?p=5043
CockPitt
Wed Jul 29, 2015 12:47 pm
After installing SDL2 and trying following command:
pi@raspberrypi /opt/Xash3D $ sudo cmake -DHL_SDK_DIR=/opt/halflife -DXASH_SDL=yes -DXASH_VGUI=yes
I still get this Error:
Hiradur
Thu Jul 30, 2015 7:37 am
Don't use sudo for cmake. It isn't required and may screw up file permissions.
SDL2_image is a separate module you have to install manually. See here for a guide: viewtopic.php?p=544740
CockPitt
Thu Jul 30, 2015 8:12 pm
Big thanks to you Hiradur.
Now it compiles, but at 19% it crashes with an error. :(
pi@raspberrypi ~/xash3d/build $ make
Scanning dependencies of target xashmenu
[ 1%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_savegame.cpp.o
[ 2%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_vidoptions.cpp.o
[ 2%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_gameoptions.cpp.o
[ 3%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_multiplayer.cpp.o
[ 4%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_btns.cpp.o
[ 5%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_loadgame.cpp.o
[ 5%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_playersetup.cpp.o
[ 6%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_strings.cpp.o
[ 7%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_customgame.cpp.o
[ 7%] Building CXX object mainui/CMakeFiles/xashmenu.dir/basemenu.cpp.o
[ 8%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_video.cpp.o
[ 9%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_controls.cpp.o
[ 9%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_credits.cpp.o
[ 10%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_newgame.cpp.o
[ 11%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_main.cpp.o
[ 12%] Building CXX object mainui/CMakeFiles/xashmenu.dir/ui_title_anim.cpp.o
[ 12%] Building CXX object mainui/CMakeFiles/xashmenu.dir/utils.cpp.o
[ 13%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_creategame.cpp.o
[ 14%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_saveload.cpp.o
[ 14%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_audio.cpp.o
[ 15%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_configuration.cpp.o
[ 16%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_internetgames.cpp.o
[ 16%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_advcontrols.cpp.o
[ 17%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_langame.cpp.o
[ 18%] Building CXX object mainui/CMakeFiles/xashmenu.dir/menu_vidmodes.cpp.o
[ 19%] Building CXX object mainui/CMakeFiles/xashmenu.dir/udll_int.cpp.o
Linking CXX shared library libxashmenu.so
[ 19%] Built target xashmenu
[ 19%] Building CXX object engine/CMakeFiles/xash.dir/platform/android/android-gameif.cpp.o
c++: error: unrecognized command line option ‘-msse’
c++: error: unrecognized command line option ‘-msse2’
engine/CMakeFiles/xash.dir/build.make:54: recipe for target 'engine/CMakeFiles/xash.dir/platform/android/android-gameif.cpp.o' failed
make[2]: *** [engine/CMakeFiles/xash.dir/platform/android/android-gameif.cpp.o] Error 1
CMakeFiles/Makefile2:125: recipe for target 'engine/CMakeFiles/xash.dir/all' failed
make[1]: *** [engine/CMakeFiles/xash.dir/all] Error 2
Makefile:72: recipe for target 'all' failed
make: *** [all] Error 2
Any Idea to fix that?
Hiradur
Fri Jul 31, 2015 7:53 am
Easy to fix:
In engine/CMakeLists.txt
Change
set (CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -w -msse -msse2 -O2")
to
set (CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -w -O2")
then re-run cmake and make
CockPitt
Fri Jul 31, 2015 9:07 am
Thanks, that worked once again ;)
It finishes compiling now.
After follwing the next instructions, there is a new error, when running the last command:
$HOME/Desktop/Xash3D/xash3d.sh
(build 3030) started at Jul31 2015 [10:51.01]
/home/pi/Desktop/Xash3D/xash3d.sh: line 32: 6704 Segmentation fault ${DEBUGGER} "${GAMEROOT}"/${GAMEEXE} $@
Hiradur
Fri Jul 31, 2015 9:43 am
This requires further debugging but the output isn't really helpful. Could you check if this gives a more extensive output
LD_LIBRARY_PATH=~/Desktop/Xash3D:$LD_LIBRARY_PATH ~/Desktop/Xash3D/xash3d
Assuming ~/Desktop/Xash3D is the game's root directory.
CockPitt
Fri Jul 31, 2015 10:14 am
:| nothing helpful i think:
pi@raspberrypi ~ $ LD_LIBRARY_PATH=~/Desktop/Xash3D:$LD_LIBRARY_PATH ~/Desktop/Xash3D/xash3d
(build 3030) started at Jul31 2015 [12:11.26]
(build 3030) stopped with error at Jul31 2015 [12:11.27]
Hiradur
Fri Jul 31, 2015 2:09 pm
In that case you have to recompile it with debugging symbols and run it in gdb for debugging. Do this:
cmake -DHL_SDK_DIR=PATH_TO_HALF_LIFE -DXASH_SDL=yes -DXASH_VGUI=yes -DCMAKE_BUILD_TYPE=DEBUG
then re-run make.
After compiling finished start the game this way:
DEBUGGER=gdb $HOME/Desktop/Xash3D/xash3d.sh
<gdb will then load the debugging symbols and await your input when it's fnished>
(gdb) r
<wait for segfault>
(gdb) bt
Post the output of bt here.
CockPitt
Fri Jul 31, 2015 2:50 pm
I forgot to write that a had to turn VGUI off "-DXASH_VGUI=no" because of an error.
Here are the results of gdb:
pi@raspberrypi ~/xash3d/build $ DEBUGGER=gdb $HOME/Desktop/Xash3D/xash3d.sh
GNU gdb (GDB) 7.4.1-debian
Copyright (C) 2012 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "arm-linux-gnueabihf".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>...
Reading symbols from /home/pi/Desktop/Xash3D/xash3d...(no debugging symbols found)...done.
(gdb) r
Starting program: /home/pi/Desktop/Xash3D/xash3d
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
[New Thread 0x748d8450 (LWP 4294)]
[New Thread 0x740d8450 (LWP 4295)]
[New Thread 0x736ff450 (LWP 4296)]
[New Thread 0x72eff450 (LWP 4297)]
[New Thread 0x726ff450 (LWP 4298)]
(build 3030) started at Jul31 2015 [16:46.34]
Program received signal SIGSEGV, Segmentation fault.
0x00000000 in ?? ()
(gdb) bt
#0 0x00000000 in ?? ()
#1 0x749ad050 in R_Init () from /home/pi/Desktop/Xash3D/libxash.so
#2 0x749b157c in CL_Init () from /home/pi/Desktop/Xash3D/libxash.so
#3 0x74980e78 in Host_Main () from /home/pi/Desktop/Xash3D/libxash.so
#4 0x00010e00 in main ()
(gdb)
CockPitt
Fri Jul 31, 2015 2:55 pm
Sorry the results of my post are wrong here are the right ones ( I forgot to copy some files in the Xash3D executive dircetory):
Reading symbols from /home/pi/Desktop/Xash3D/xash3d...done.
(gdb) r
[New Thread 0x748d8450 (LWP 4449)]
[New Thread 0x740d8450 (LWP 4450)]
[New Thread 0x736ff450 (LWP 4451)]
[New Thread 0x72eff450 (LWP 4452)]
[New Thread 0x726ff450 (LWP 4453)]
(build 3030) started at Jul31 2015 [16:54.15]
0x00000000 in ?? ()
(gdb) bt
(gdb)
Hiradur
Fri Jul 31, 2015 3:30 pm
Sorry, I made a typo:
It should've been
-DCMAKE_BUILD_TYPE=Debug
instead of
It looks like your code is not compiled with debugging symbols because otherwise bt should show in which line of the source code the program crashed.
CockPitt
Fri Jul 31, 2015 3:49 pm
With "-DCMAKE_BUILD_TYPE=Debug" I still get this:
(gdb) r
[New Thread 0x748d8450 (LWP 3906)]
[New Thread 0x740d8450 (LWP 3907)]
[New Thread 0x736ff450 (LWP 3908)]
[New Thread 0x72eff450 (LWP 3909)]
[New Thread 0x726ff450 (LWP 3910)]
(build 3030) started at Jul31 2015 [17:47.12]
0x00000000 in ?? ()
(gdb) bt
(gdb)
Hiradur
Sat Aug 01, 2015 12:13 pm
Ok, thanks for doing it. I wasn't 100% sure if CMAKE_BUILD_TYPE is case sensitive or not. We still don't see the line in the code where it crashes. However, R_Init() is defined in gl_vidnt.c and initializes the renderer. So we are a bit closer. Three things to try which come to my mind are:
- start it with glshim. You'll have to use glshim for high FPS anyway because the engine only supports OpenGL and not OpenGL ES as I see it.
- recompile with -DPANDORA=1 as argument for cmake. There is some OpenPandora specific code inside. It could work on the Pi as well.
- set breakpoints to manually determine which line leads to the crash:
Inside gdb enter:
(gdb) break engine/client/gl_vidnt.c:linenumber
(gdb) r
<two options: it crashed or halted>
if execution is halted at breakpoint:
(gdb) break engine/client/glvidnt.c:linenumber+1
(gdb) c
<repeat until crash>
if it crashed you now got the number of the line causing the trouble
CockPitt
Sun Aug 02, 2015 4:45 pm
1. -DPANDORA=1
pi@raspberrypi ~/xash3d/build $ $HOME/Desktop/Xash3D/xash3d.sh
(build 3030) started at Aug01 2015 [22:32.59]
sudo: /usr/pandora/scripts/op_gamma.sh: command not found
/home/pi/Desktop/Xash3D/xash3d.sh: line 32: 3959 Segmentation fault ${DEBUGGER} "${GAMEROOT}"/${GAMEEXE} $@
2. "Starting with glshim" Produces an error:
pi@raspberrypi ~/glshim $ cmake . -DBCMHOST=1; make GL
-- The C compiler identification is GNU 4.9.2
-- The CXX compiler identification is GNU 4.9.2
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Configuring done
-- Generating done
-- Build files have been written to: /home/pi/glshim
Scanning dependencies of target GL
[ 0%] Building C object src/CMakeFiles/GL.dir/gl/array.c.o
In file included from /home/pi/glshim/src/gl/gl.h:27:0,
from /home/pi/glshim/src/gl/array.h:1,
from /home/pi/glshim/src/gl/array.c:1:
/home/pi/glshim/src/gl/wrap/glpack.h:43:5: error: unknown type name ‘EGLSyncNV’
EGLSyncNV sync;
/home/pi/glshim/src/gl/wrap/glpack.h:45:5: error: unknown type name ‘EGLTimeNV’
EGLTimeNV timeout;
/home/pi/glshim/src/gl/wrap/glpack.h:139:5: error: unknown type name ‘EGLNativeFileDescriptorKHR’
EGLNativeFileDescriptorKHR file_descriptor;
/home/pi/glshim/src/gl/wrap/glpack.h:156:5: error: unknown type name ‘EGLStreamKHR’
EGLStreamKHR stream;
/home/pi/glshim/src/gl/wrap/glpack.h:200:5: error: unknown type name ‘EGLStreamKHR’
/home/pi/glshim/src/gl/wrap/glpack.h:223:5: error: unknown type name ‘EGLSyncNV’
EGLSyncNV sync;
/home/pi/glshim/src/gl/wrap/glpack.h:249:5: error: unknown type name ‘EGLSyncNV’
EGLSyncNV sync;
/home/pi/glshim/src/gl/wrap/glpack.h:307:5: error: unknown type name ‘EGLStreamKHR’
/home/pi/glshim/src/gl/wrap/glpack.h:324:5: error: unknown type name ‘EGLSyncNV’
EGLSyncNV sync;
/home/pi/glshim/src/gl/wrap/glpack.h:419:5: error: unknown type name ‘EGLStreamKHR’
/home/pi/glshim/src/gl/wrap/glpack.h:429:5: error: unknown type name ‘EGLStreamKHR’
/home/pi/glshim/src/gl/wrap/glpack.h:439:5: error: unknown type name ‘EGLStreamKHR’
/home/pi/glshim/src/gl/wrap/glpack.h:441:5: error: unknown type name ‘EGLuint64KHR’
EGLuint64KHR * value;
/home/pi/glshim/src/gl/wrap/glpack.h:497:5: error: unknown type name ‘EGLSyncNV’
EGLSyncNV sync;
/home/pi/glshim/src/gl/wrap/glpack.h:506:5: error: unknown type name ‘EGLStreamKHR’
/home/pi/glshim/src/gl/wrap/glpack.h:516:5: error: unknown type name ‘EGLStreamKHR’
/home/pi/glshim/src/gl/wrap/glpack.h:524:5: error: unknown type name ‘EGLStreamKHR’
/home/pi/glshim/src/gl/wrap/glpack.h:532:5: error: unknown type name ‘EGLStreamKHR’
/home/pi/glshim/src/gl/wrap/glpack.h:25843:40: error: unknown type name ‘EGLSyncNV’
#define eglClientWaitSyncNV_ARG_EXPAND EGLSyncNV sync, EGLint flags, EGLTimeNV timeout
/home/pi/glshim/src/gl/wrap/glpack.h:25865:28: note: in expansion of macro ‘eglClientWaitSyncNV_ARG_EXPAND’
EGLint eglClientWaitSyncNV(eglClientWaitSyncNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:25843:70: error: unknown type name ‘EGLTimeNV’
/home/pi/glshim/src/gl/wrap/glpack.h:25866:33: note: in expansion of macro ‘eglClientWaitSyncNV_ARG_EXPAND’
EGLint stub_eglClientWaitSyncNV(eglClientWaitSyncNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:25867:43: note: in expansion of macro ‘eglClientWaitSyncNV_ARG_EXPAND’
typedef EGLint (*eglClientWaitSyncNV_PTR)(eglClientWaitSyncNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:25977:1: error: unknown type name ‘EGLSyncNV’
EGLSyncNV eglCreateFenceSyncNV(eglCreateFenceSyncNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:25978:1: error: unknown type name ‘EGLSyncNV’
EGLSyncNV stub_eglCreateFenceSyncNV(eglCreateFenceSyncNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:25979:20: error: expected declaration specifiers or ‘...’ before ‘*’ token
typedef EGLSyncNV (*eglCreateFenceSyncNV_PTR)(eglCreateFenceSyncNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26149:1: error: unknown type name ‘EGLStreamKHR’
EGLStreamKHR eglCreateStreamFromFileDescriptorKHR(eglCreateStreamFromFileDescriptorKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26128:73: error: unknown type name ‘EGLNativeFileDescriptorKHR’
#define eglCreateStreamFromFileDescriptorKHR_ARG_EXPAND EGLDisplay dpy, EGLNativeFileDescriptorKHR file_descriptor
/home/pi/glshim/src/gl/wrap/glpack.h:26149:51: note: in expansion of macro ‘eglCreateStreamFromFileDescriptorKHR_ARG_EXPAND’
/home/pi/glshim/src/gl/wrap/glpack.h:26150:1: error: unknown type name ‘EGLStreamKHR’
EGLStreamKHR stub_eglCreateStreamFromFileDescriptorKHR(eglCreateStreamFromFileDescriptorKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26150:56: note: in expansion of macro ‘eglCreateStreamFromFileDescriptorKHR_ARG_EXPAND’
/home/pi/glshim/src/gl/wrap/glpack.h:26151:23: error: expected declaration specifiers or ‘...’ before ‘*’ token
typedef EGLStreamKHR (*eglCreateStreamFromFileDescriptorKHR_PTR)(eglCreateStreamFromFileDescriptorKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26176:1: error: unknown type name ‘EGLStreamKHR’
EGLStreamKHR eglCreateStreamKHR(eglCreateStreamKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26177:1: error: unknown type name ‘EGLStreamKHR’
EGLStreamKHR stub_eglCreateStreamKHR(eglCreateStreamKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26178:23: error: expected declaration specifiers or ‘...’ before ‘*’ token
typedef EGLStreamKHR (*eglCreateStreamKHR_PTR)(eglCreateStreamKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26182:88: error: unknown type name ‘EGLStreamKHR’
#define eglCreateStreamProducerSurfaceKHR_ARG_EXPAND EGLDisplay dpy, EGLConfig config, EGLStreamKHR stream, const EGLint * attrib_list
/home/pi/glshim/src/gl/wrap/glpack.h:26205:46: note: in expansion of macro ‘eglCreateStreamProducerSurfaceKHR_ARG_EXPAND’
EGLSurface eglCreateStreamProducerSurfaceKHR(eglCreateStreamProducerSurfaceKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26206:51: note: in expansion of macro ‘eglCreateStreamProducerSurfaceKHR_ARG_EXPAND’
EGLSurface stub_eglCreateStreamProducerSurfaceKHR(eglCreateStreamProducerSurfaceKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26207:61: note: in expansion of macro ‘eglCreateStreamProducerSurfaceKHR_ARG_EXPAND’
typedef EGLSurface (*eglCreateStreamProducerSurfaceKHR_PTR)(eglCreateStreamProducerSurfaceKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26322:56: error: unknown type name ‘EGLStreamKHR’
#define eglDestroyStreamKHR_ARG_EXPAND EGLDisplay dpy, EGLStreamKHR stream
/home/pi/glshim/src/gl/wrap/glpack.h:26343:32: note: in expansion of macro ‘eglDestroyStreamKHR_ARG_EXPAND’
EGLBoolean eglDestroyStreamKHR(eglDestroyStreamKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26344:37: note: in expansion of macro ‘eglDestroyStreamKHR_ARG_EXPAND’
EGLBoolean stub_eglDestroyStreamKHR(eglDestroyStreamKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26345:47: note: in expansion of macro ‘eglDestroyStreamKHR_ARG_EXPAND’
typedef EGLBoolean (*eglDestroyStreamKHR_PTR)(eglDestroyStreamKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26403:37: error: unknown type name ‘EGLSyncNV’
#define eglDestroySyncNV_ARG_EXPAND EGLSyncNV sync
/home/pi/glshim/src/gl/wrap/glpack.h:26423:29: note: in expansion of macro ‘eglDestroySyncNV_ARG_EXPAND’
EGLBoolean eglDestroySyncNV(eglDestroySyncNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26424:34: note: in expansion of macro ‘eglDestroySyncNV_ARG_EXPAND’
EGLBoolean stub_eglDestroySyncNV(eglDestroySyncNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26425:44: note: in expansion of macro ‘eglDestroySyncNV_ARG_EXPAND’
typedef EGLBoolean (*eglDestroySyncNV_PTR)(eglDestroySyncNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26486:31: error: unknown type name ‘EGLSyncNV’
#define eglFenceNV_ARG_EXPAND EGLSyncNV sync
/home/pi/glshim/src/gl/wrap/glpack.h:26506:23: note: in expansion of macro ‘eglFenceNV_ARG_EXPAND’
EGLBoolean eglFenceNV(eglFenceNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26507:28: note: in expansion of macro ‘eglFenceNV_ARG_EXPAND’
EGLBoolean stub_eglFenceNV(eglFenceNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26508:38: note: in expansion of macro ‘eglFenceNV_ARG_EXPAND’
typedef EGLBoolean (*eglFenceNV_PTR)(eglFenceNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26738:1: error: unknown type name ‘EGLNativeFileDescriptorKHR’
EGLNativeFileDescriptorKHR eglGetStreamFileDescriptorKHR(eglGetStreamFileDescriptorKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26717:66: error: unknown type name ‘EGLStreamKHR’
#define eglGetStreamFileDescriptorKHR_ARG_EXPAND EGLDisplay dpy, EGLStreamKHR stream
/home/pi/glshim/src/gl/wrap/glpack.h:26738:58: note: in expansion of macro ‘eglGetStreamFileDescriptorKHR_ARG_EXPAND’
/home/pi/glshim/src/gl/wrap/glpack.h:26739:1: error: unknown type name ‘EGLNativeFileDescriptorKHR’
EGLNativeFileDescriptorKHR stub_eglGetStreamFileDescriptorKHR(eglGetStreamFileDescriptorKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26739:63: note: in expansion of macro ‘eglGetStreamFileDescriptorKHR_ARG_EXPAND’
/home/pi/glshim/src/gl/wrap/glpack.h:26740:37: error: expected declaration specifiers or ‘...’ before ‘*’ token
typedef EGLNativeFileDescriptorKHR (*eglGetStreamFileDescriptorKHR_PTR)(eglGetStreamFileDescriptorKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26773:39: error: unknown type name ‘EGLSyncNV’
#define eglGetSyncAttribNV_ARG_EXPAND EGLSyncNV sync, EGLint attribute, EGLint * value
/home/pi/glshim/src/gl/wrap/glpack.h:26795:31: note: in expansion of macro ‘eglGetSyncAttribNV_ARG_EXPAND’
EGLBoolean eglGetSyncAttribNV(eglGetSyncAttribNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26796:36: note: in expansion of macro ‘eglGetSyncAttribNV_ARG_EXPAND’
EGLBoolean stub_eglGetSyncAttribNV(eglGetSyncAttribNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26797:46: note: in expansion of macro ‘eglGetSyncAttribNV_ARG_EXPAND’
typedef EGLBoolean (*eglGetSyncAttribNV_PTR)(eglGetSyncAttribNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26818:1: error: unknown type name ‘EGLuint64NV’
EGLuint64NV eglGetSystemTimeFrequencyNV(eglGetSystemTimeFrequencyNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26819:1: error: unknown type name ‘EGLuint64NV’
EGLuint64NV stub_eglGetSystemTimeFrequencyNV(eglGetSystemTimeFrequencyNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26820:22: error: expected declaration specifiers or ‘...’ before ‘*’ token
typedef EGLuint64NV (*eglGetSystemTimeFrequencyNV_PTR)(eglGetSystemTimeFrequencyNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26841:1: error: unknown type name ‘EGLuint64NV’
EGLuint64NV eglGetSystemTimeNV(eglGetSystemTimeNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26842:1: error: unknown type name ‘EGLuint64NV’
EGLuint64NV stub_eglGetSystemTimeNV(eglGetSystemTimeNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:26843:22: error: expected declaration specifiers or ‘...’ before ‘*’ token
typedef EGLuint64NV (*eglGetSystemTimeNV_PTR)(eglGetSystemTimeNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27098:54: error: unknown type name ‘EGLStreamKHR’
#define eglQueryStreamKHR_ARG_EXPAND EGLDisplay dpy, EGLStreamKHR stream, EGLenum attribute, EGLint * value
/home/pi/glshim/src/gl/wrap/glpack.h:27121:30: note: in expansion of macro ‘eglQueryStreamKHR_ARG_EXPAND’
EGLBoolean eglQueryStreamKHR(eglQueryStreamKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27122:35: note: in expansion of macro ‘eglQueryStreamKHR_ARG_EXPAND’
EGLBoolean stub_eglQueryStreamKHR(eglQueryStreamKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27123:45: note: in expansion of macro ‘eglQueryStreamKHR_ARG_EXPAND’
typedef EGLBoolean (*eglQueryStreamKHR_PTR)(eglQueryStreamKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27127:58: error: unknown type name ‘EGLStreamKHR’
#define eglQueryStreamTimeKHR_ARG_EXPAND EGLDisplay dpy, EGLStreamKHR stream, EGLenum attribute, EGLTimeKHR * value
/home/pi/glshim/src/gl/wrap/glpack.h:27150:34: note: in expansion of macro ‘eglQueryStreamTimeKHR_ARG_EXPAND’
EGLBoolean eglQueryStreamTimeKHR(eglQueryStreamTimeKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27151:39: note: in expansion of macro ‘eglQueryStreamTimeKHR_ARG_EXPAND’
EGLBoolean stub_eglQueryStreamTimeKHR(eglQueryStreamTimeKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27152:49: note: in expansion of macro ‘eglQueryStreamTimeKHR_ARG_EXPAND’
typedef EGLBoolean (*eglQueryStreamTimeKHR_PTR)(eglQueryStreamTimeKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27156:57: error: unknown type name ‘EGLStreamKHR’
#define eglQueryStreamu64KHR_ARG_EXPAND EGLDisplay dpy, EGLStreamKHR stream, EGLenum attribute, EGLuint64KHR * value
/home/pi/glshim/src/gl/wrap/glpack.h:27179:33: note: in expansion of macro ‘eglQueryStreamu64KHR_ARG_EXPAND’
EGLBoolean eglQueryStreamu64KHR(eglQueryStreamu64KHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27156:97: error: unknown type name ‘EGLuint64KHR’
/home/pi/glshim/src/gl/wrap/glpack.h:27180:38: note: in expansion of macro ‘eglQueryStreamu64KHR_ARG_EXPAND’
EGLBoolean stub_eglQueryStreamu64KHR(eglQueryStreamu64KHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27181:48: note: in expansion of macro ‘eglQueryStreamu64KHR_ARG_EXPAND’
typedef EGLBoolean (*eglQueryStreamu64KHR_PTR)(eglQueryStreamu64KHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27349:36: error: unknown type name ‘EGLSyncNV’
#define eglSignalSyncNV_ARG_EXPAND EGLSyncNV sync, EGLenum mode
/home/pi/glshim/src/gl/wrap/glpack.h:27370:28: note: in expansion of macro ‘eglSignalSyncNV_ARG_EXPAND’
EGLBoolean eglSignalSyncNV(eglSignalSyncNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27371:33: note: in expansion of macro ‘eglSignalSyncNV_ARG_EXPAND’
EGLBoolean stub_eglSignalSyncNV(eglSignalSyncNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27372:43: note: in expansion of macro ‘eglSignalSyncNV_ARG_EXPAND’
typedef EGLBoolean (*eglSignalSyncNV_PTR)(eglSignalSyncNV_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27376:55: error: unknown type name ‘EGLStreamKHR’
#define eglStreamAttribKHR_ARG_EXPAND EGLDisplay dpy, EGLStreamKHR stream, EGLenum attribute, EGLint value
/home/pi/glshim/src/gl/wrap/glpack.h:27399:31: note: in expansion of macro ‘eglStreamAttribKHR_ARG_EXPAND’
EGLBoolean eglStreamAttribKHR(eglStreamAttribKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27400:36: note: in expansion of macro ‘eglStreamAttribKHR_ARG_EXPAND’
EGLBoolean stub_eglStreamAttribKHR(eglStreamAttribKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27401:46: note: in expansion of macro ‘eglStreamAttribKHR_ARG_EXPAND’
typedef EGLBoolean (*eglStreamAttribKHR_PTR)(eglStreamAttribKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27405:64: error: unknown type name ‘EGLStreamKHR’
#define eglStreamConsumerAcquireKHR_ARG_EXPAND EGLDisplay dpy, EGLStreamKHR stream
/home/pi/glshim/src/gl/wrap/glpack.h:27426:40: note: in expansion of macro ‘eglStreamConsumerAcquireKHR_ARG_EXPAND’
EGLBoolean eglStreamConsumerAcquireKHR(eglStreamConsumerAcquireKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27427:45: note: in expansion of macro ‘eglStreamConsumerAcquireKHR_ARG_EXPAND’
EGLBoolean stub_eglStreamConsumerAcquireKHR(eglStreamConsumerAcquireKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27428:55: note: in expansion of macro ‘eglStreamConsumerAcquireKHR_ARG_EXPAND’
typedef EGLBoolean (*eglStreamConsumerAcquireKHR_PTR)(eglStreamConsumerAcquireKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27432:74: error: unknown type name ‘EGLStreamKHR’
#define eglStreamConsumerGLTextureExternalKHR_ARG_EXPAND EGLDisplay dpy, EGLStreamKHR stream
/home/pi/glshim/src/gl/wrap/glpack.h:27453:50: note: in expansion of macro ‘eglStreamConsumerGLTextureExternalKHR_ARG_EXPAND’
EGLBoolean eglStreamConsumerGLTextureExternalKHR(eglStreamConsumerGLTextureExternalKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27454:55: note: in expansion of macro ‘eglStreamConsumerGLTextureExternalKHR_ARG_EXPAND’
EGLBoolean stub_eglStreamConsumerGLTextureExternalKHR(eglStreamConsumerGLTextureExternalKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27455:65: note: in expansion of macro ‘eglStreamConsumerGLTextureExternalKHR_ARG_EXPAND’
typedef EGLBoolean (*eglStreamConsumerGLTextureExternalKHR_PTR)(eglStreamConsumerGLTextureExternalKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27459:64: error: unknown type name ‘EGLStreamKHR’
#define eglStreamConsumerReleaseKHR_ARG_EXPAND EGLDisplay dpy, EGLStreamKHR stream
/home/pi/glshim/src/gl/wrap/glpack.h:27480:40: note: in expansion of macro ‘eglStreamConsumerReleaseKHR_ARG_EXPAND’
EGLBoolean eglStreamConsumerReleaseKHR(eglStreamConsumerReleaseKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27481:45: note: in expansion of macro ‘eglStreamConsumerReleaseKHR_ARG_EXPAND’
EGLBoolean stub_eglStreamConsumerReleaseKHR(eglStreamConsumerReleaseKHR_ARG_EXPAND);
/home/pi/glshim/src/gl/wrap/glpack.h:27482:55: note: in expansion of macro ‘eglStreamConsumerReleaseKHR_ARG_EXPAND’
typedef EGLBoolean (*eglStreamConsumerReleaseKHR_PTR)(eglStreamConsumerReleaseKHR_ARG_EXPAND);
In file included from /opt/vc/include/interface/vcos/vcos.h:185:0,
from /opt/vc/include/interface/vmcs_host/vc_dispmanx.h:33,
from /opt/vc/include/EGL/eglplatform.h:110,
from /opt/vc/include/EGL/egl.h:36,
from /home/pi/glshim/src/util/extypes.h:106,
from /home/pi/glshim/src/gl/types.h:9,
from /home/pi/glshim/src/gl/gl.h:9,
/opt/vc/include/interface/vcos/vcos_timer.h:112:6: warning: inline function ‘vcos_timer_delete’ declared but never defined
void vcos_timer_delete(VCOS_TIMER_T *timer);
/opt/vc/include/interface/vcos/vcos_timer.h:109:6: warning: inline function ‘vcos_timer_reset’ declared but never defined
void vcos_timer_reset(VCOS_TIMER_T *timer, VCOS_UNSIGNED delay);
/opt/vc/include/interface/vcos/vcos_timer.h:102:6: warning: inline function ‘vcos_timer_cancel’ declared but never defined
void vcos_timer_cancel(VCOS_TIMER_T *timer);
/opt/vc/include/interface/vcos/vcos_timer.h:95:6: warning: inline function ‘vcos_timer_set’ declared but never defined
void vcos_timer_set(VCOS_TIMER_T *timer, VCOS_UNSIGNED delay);
/opt/vc/include/interface/vcos/vcos_timer.h:80:15: warning: inline function ‘vcos_timer_create’ declared but never defined
VCOS_STATUS_T vcos_timer_create(VCOS_TIMER_T *timer,
In file included from /opt/vc/include/interface/vcos/vcos.h:135:0,
/opt/vc/include/interface/vcos/vcos_mem.h:93:15: warning: inline function ‘vcos_get_free_mem’ declared but never defined
unsigned long vcos_get_free_mem(void);
In file included from /opt/vc/include/interface/vcos/vcos.h:127:0,
/opt/vc/include/interface/vcos/vcos_thread.h:269:6: warning: inline function ‘vcos_thread_resume’ declared but never defined
void vcos_thread_resume(VCOS_THREAD_T *thread);
/opt/vc/include/interface/vcos/vcos_thread.h:262:5: warning: inline function ‘vcos_thread_running’ declared but never defined
int vcos_thread_running(VCOS_THREAD_T *thread);
/opt/vc/include/interface/vcos/vcos_thread.h:251:15: warning: inline function ‘vcos_change_preemption’ declared but never defined
VCOS_UNSIGNED vcos_change_preemption(VCOS_UNSIGNED pe);
/opt/vc/include/interface/vcos/vcos_thread.h:234:6: warning: inline function ‘vcos_thread_relinquish’ declared but never defined
void vcos_thread_relinquish(void);
/opt/vc/include/interface/vcos/vcos_thread.h:186:15: warning: inline function ‘vcos_thread_get_affinity’ declared but never defined
VCOS_UNSIGNED vcos_thread_get_affinity(VCOS_THREAD_T *thread);
src/CMakeFiles/GL.dir/build.make:54: recipe for target 'src/CMakeFiles/GL.dir/gl/array.c.o' failed
make[3]: *** [src/CMakeFiles/GL.dir/gl/array.c.o] Error 1
CMakeFiles/Makefile2:79: recipe for target 'src/CMakeFiles/GL.dir/all' failed
make[2]: *** [src/CMakeFiles/GL.dir/all] Error 2
CMakeFiles/Makefile2:91: recipe for target 'src/CMakeFiles/GL.dir/rule' failed
make[1]: *** [src/CMakeFiles/GL.dir/rule] Error 2
Makefile:147: recipe for target 'GL' failed
make: *** [GL] Error 2
3. breakpoints
This didn't work, because the file is in the compiling directory.
Breakpoint 1 (engine/client/gl_vidnt.c:1) pending.
(gdb) break engine/client/gl_vidnt.c:2
No source file named engine/client/gl_vidnt.c.
Make breakpoint pending on future shared library load? (y or [n]) y
Hiradur
Tue Aug 04, 2015 9:34 am
1. Looks like when built for the Pandora it makes use of specific system functions so this won't work.
2. Try again with my glshim script: viewtopic.php?f=78&t=116416&p=792906#p792906
3. Change the file path so it matches the correct path.
CockPitt
Wed Aug 05, 2015 9:22 am
1. glshim script
Compiling of glshim worked perfectly but if I try to start, "Permission denied" error announces:
pi@raspberrypi ~/glshim $ ./glshim.sh ~/Desktop/Xash3D
Starting game /home/pi/Desktop/Xash3D
./glshim.sh: 107: ./glshim.sh: /home/pi/Desktop/Xash3D: Permission denied
If I start with "sudo" it doesn't work either:
pi@raspberrypi ~/glshim $ sudo ./glshim.sh ~/Desktop/Xash3D
2. Breakpoints
Am I doning something wrong? I changed the directory to "/home/pi/xash3d" its not the game directory but the compiling directory,
but the "engine/client/gl_vidnt.c" file, wich produced the first error, is just in this directory.
(gdb) break engine/client/gl_vidnt.c:1
No symbol table is loaded. Use the "file" command.
Breakpoint 3 (engine/client/gl_vidnt.c:1) pending.
(gdb)
Hiradur
Wed Aug 05, 2015 1:52 pm
1. Did you make the script executable with
chmod +x glshim.sh
2. It doesn't matter where the sources are as long as they haven't been moved after the build. Try the full path to the source file.
You should also start with the linenumber of the first line that belongs to R_Init() (first line after the { bracket)
CockPitt
Thu Aug 06, 2015 10:17 am
1. This is what I did. Is there any mistake?
pi@raspberrypi ~ $ cd glshim
pi@raspberrypi ~/glshim $ sudo apt-get install cmake libx11-dev
Reading package lists... Done
Building dependency tree
cmake is already the newest version.
libx11-dev is already the newest version.
libx11-dev set to manually installed.
The following packages were automatically installed and are no longer required:
libgssglue1 libpq5
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@raspberrypi ~/glshim $ chmod +x glshim.sh
Attempting to build glshim and glues
Make sure you are connected to the internet and
cmake and libx11-dev are installed (sudo apt-get install cmake libx11-dev)
Building glshim...
switching to unstable-branch...
Already on 'unstable'
checking for updates...
Already up-to-date.
starting build...
-- Configuring done
-- Generating done
-- Build files have been written to: /home/pi/glwrapper/glshim
[100%] Built target GL
Building glues...
switching to glu-branch...
Already on 'glu'
Already up-to-date.
starting build...
-- Configuring done
-- Generating done
-- Build files have been written to: /home/pi/glwrapper/glues
Scanning dependencies of target GLU
[ 2%] [ 2%] [ 3%] [ 4%] Building C object CMakeFiles/GLU.dir/source/glues_registry.c.o
Building C object CMakeFiles/GLU.dir/source/glues_mipmap.c.o
Building C object CMakeFiles/GLU.dir/source/glues_error.c.o
Building C object CMakeFiles/GLU.dir/source/glues_quad.c.o
[ 5%] [ 6%] Building C object CMakeFiles/GLU.dir/source/glues_project.c.o
Building C object CMakeFiles/GLU.dir/source/libtess/tessmono.c.o
[ 7%] Building C object CMakeFiles/GLU.dir/source/libtess/normal.c.o
[ 8%] Building C object CMakeFiles/GLU.dir/source/libtess/geom.c.o
[ 10%] Building C object CMakeFiles/GLU.dir/source/libtess/tess.c.o
[ 11%] Building C object CMakeFiles/GLU.dir/source/libtess/priorityq.c.o
[ 12%] Building C object CMakeFiles/GLU.dir/source/libtess/sweep.c.o
[ 13%] Building C object CMakeFiles/GLU.dir/source/libtess/render.c.o
[ 14%] Building C object CMakeFiles/GLU.dir/source/libtess/mesh.c.o
[ 15%] Building CXX object CMakeFiles/GLU.dir/source/libnurbs/interface/bezierPatchMesh.cc.o
[ 16%] Building CXX object CMakeFiles/GLU.dir/source/libnurbs/interface/insurfeval.cc.o
[ 17%] Building CXX object CMakeFiles/GLU.dir/source/libnurbs/interface/bezierPatch.cc.o
[ 19%] Building CXX object CMakeFiles/GLU.dir/source/libnurbs/interface/gles_evaluator.cc.o
[ 20%] Building CXX object CMakeFiles/GLU.dir/source/libnurbs/interface/glrenderer.cc.o
[ 21%] Building CXX object CMakeFiles/GLU.dir/source/libnurbs/interface/glsurfeval.cc.o
[ 22%] Building CXX object CMakeFiles/GLU.dir/source/libnurbs/interface/glcurveval.cc.o
[ 23%] Building CXX object CMakeFiles/GLU.dir/source/libnurbs/interface/incurveeval.cc.o
[ 24%] [ 25%] [ 26%] Building CXX object CMakeFiles/GLU.dir/source/libnurbs/internals/backend.cc.o
Building CXX object CMakeFiles/GLU.dir/source/libnurbs/interface/glinterface.cc.o
Building CXX object CMakeFiles/GLU.dir/source/libnurbs/internals/monoTriangulationBackend.cc.o
[ 28%] Building CXX object CMakeFiles/GLU.dir/source/libnurbs/internals/slicer.cc.o
[ 29%] Building CXX object CMakeFiles/GLU.dir/source/libnurbs/nurbtess/rectBlock.cc.o
[ 30%] Building CXX object CMakeFiles/GLU.dir/source/libnurbs/nurbtess/primitiveStream.cc.o
[ 31%] Building CXX object CMakeFiles/GLU.dir/source/libnurbs/nurbtess/gridWrap.cc.o
[ 32%] Building CXX object CMakeFiles/GLU.dir/source/libnurbs/nurbtess/sampleCompRight.cc.o
[ 33%] Building CXX object CMakeFiles/GLU.dir/source/libnurbs/nurbtess/sampleMonoPoly.cc.o
[ 34%] Building CXX object CMakeFiles/GLU.dir/source/libnurbs/nurbtess/monoChain.cc.o
Linking CXX shared library libGLU.so.1
[100%] Built target GLU
Could not read from count file.
Already up-to-date.
-- Configuring done
-- Generating done
-- Build files have been written to: /home/pi/glwrapper/tinygles
[ 7%] [ 15%] [ 22%] Built target spin
Built target mech
Built target gears
[ 92%] Built target GLESv1_CM
[100%] Built target texobj
All libraries were successfully built
pi@raspberrypi ~/glshim $ ./glshim.sh /home/pi/Desktop/Xash3D
2. I'm very sorry, but I don't know how I set these breakpoints. I don't get it.
Return to “Gaming”
