expandables
Mupen64plus will not compile rpi2
Thu Feb 26, 2015 5:54 pm
Hi i am trying to get mupen64plus to compile on the raspberry pi2 but i a, getting this error.
In file included from ../../src/api/vidext.c:38:0:
../../src/api/vidext_sdl2_compat.h:34:2: error: #error SDL is not build with OpenGL ES2 support. Try USE_GLES=0
Makefile:630: recipe for target '_obj/api/vidext.o' failed
make: *** [_obj/api/vidext.o] Error 1
make: Leaving directory '/home/pi/mupen64plus/ricrpi/mupen64plus-core/projects/unix'
:mrgreen:
By thinking like an engineer you can create a raspberry pi.
Michael Jackson enthusiast.
I got the PI model B, B+ and PI 2 model B.
When will I get the A? I don't know.
steev
Re: Mupen64plus will not compile rpi2
Fri Feb 27, 2015 4:48 am
When building SDL2, configure with --host=arm-raspberry-linux and make sure it says the GLES drivers are enabled
It should say something like:
Video drivers   : dummy opengl_es1 opengl_es2
Return to “Gaming”
