tioguay68
AYUDA JAVA A FATAL ERROR HAS BEEN DETECTED BY THE JAVA RUNTIME ENVIRONMENT:
Wed Jul 17, 2019 2:17 pm
pues estoy intendado hacer un server de minecraft y antes podia inciar el server lo unico que le hice fue un overcloking a 1,5ghz,le puse 128mb de memoria a la gpu,y le amplie la memria swap a 2048mb
despues de dar el comando de esto
pi@raspberry:~/Desktop/servidor $ java -Xmx1024M -Xms1024M -jar craftbukkit-1.14.2-R0.1-SNAPSHOT.jar nogui
*** Error, this build is outdated ***
*** Please download a new build as per instructions from https://www.spigotmc.org/go/outdated-spigot ***
*** Server will start in 20 seconds ***
Loading libraries, please wait...
=============== DEBUG MESSAGE: should not reach here ================
# A fatal error has been detected by the Java Runtime Environment:
# Internal Error (macroAssembler_arm.cpp:1620), pid=666, tid=691
# fatal error: should not reach here
# JRE version: OpenJDK Runtime Environment (11.0.3+7) (build 11.0.3+7-post-Raspbian-5)
# Java VM: OpenJDK Server VM (11.0.3+7-post-Raspbian-5, mixed mode, serial gc, linux-)
# No core dump will be written. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /home/pi/Desktop/servidor/hs_err_pid666.log
# If you would like to submit a bug report, please visit:
# Unknown
Abortado
Return to “Español”
