bhaveshprajapat
Android for Hynix Rev B Board
Mon Mar 25, 2013 1:12 pm
Subject to my previous post about Android not booting up, I found that the cause of the failure of Android to load was because the image doesn't have boot code for the Hynix memory chip. Has anyone manged to change the code to get it to work or is there a specific image to make it work on the B v2 RPi :idea:
Re: Android for Hynix Rev B Board
Mon Mar 25, 2013 1:29 pm
Just replace the start.elf and bootcode.bin in the root partition with the latest version to see if that works.
bhaveshprajapat
Mon Mar 25, 2013 1:52 pm
jamesh wrote:Just replace the start.elf and bootcode.bin in the root partition with the latest version to see if that works.
Thank you Sir!
I didn't think it would be that easy but I'm getting a better knowledge of this now that I'm learning.
Mon Mar 25, 2013 4:15 pm
It may not work - but it's a good place to start!
aaa801
Thu Mar 28, 2013 11:37 am
jamesh wrote:It may not work - but it's a good place to start!
You should see our dev image, its scary :)
sheldonrush
Sun Apr 28, 2013 6:31 pm
hi bhaveshprajapat,
I also got the same issue with you.
could you help share your experience,
is it work on Rev B Board ?
BRs,
Sheldon
Mon Apr 29, 2013 2:32 am
sheldonrush wrote:hi bhaveshprajapat,
BRs,
Sheldon
It would a very quick job to try the latest start.elf and bootcode.bin...
sheldonrush
Mon Apr 29, 2013 2:37 pm
hi Jamesh,
it works, thank you very much
BRs,
Sheldon
bhaveshprajapat
Mon May 06, 2013 11:12 am
Yup, that's all you'll need!
Sorry I haven't been on this thread in a while. I would suggest using Fedora until Android gets up and running - you will need the bootcode.bin, start.elf and fixup.dat from the openELEC build - and that build only for some reason, probably because of partitioning. You'll need to download the .tar.bz2 (I think that's the extension!?) Extract twice with 7Zip.
Bhav.
P.S. Use SDFormatter's SDFULL Overwrite if you get mmcblk0p* errors
PeTiT
Thu Jun 27, 2013 7:16 am
thanks mate for the hint...but... where do I can find "the latest version" of these 2 files?
thanks again! ;)
EDIT: I found this https://github.com/raspberrypi/firmware ... aster/boot
Here I can find the 2 correct files u spoke about?
bhaveshprajapat
Thu Jun 27, 2013 2:23 pm
thanks again! ;)
Go to OpenELEC's site and download the .tar.bzip2 (i think it is this extension)
extract the .tar from the .bzip2
then extract all files from the .tar
use the start.elf bootcode.bin and the fixup.dat from there and move these to the boot partition using windows.
Note: this is only to fix android boot if the ACT light only flashes once and nothing is displayed.
I am not aware of any other files, inculding stock Raspbian files, that work
Bhavesh
PeTiT
Thu Jun 27, 2013 3:37 pm
this is exactly my issue.
Thanks for the perfect exlpanation: I'll try later then I'll update this thread to update my results ;)
finger crossed!!
bhaveshprajapat
Thu Jun 27, 2013 3:46 pm
finger crossed!!
No problem Sir!
Bhavesh
PeTiT
Thu Jun 27, 2013 8:11 pm
hey mate: IT WORKS ! ! ! :) :) :)
thanks a lot! :D
bhaveshprajapat
Thu Jun 27, 2013 10:54 pm
PeTiT wrote:hey mate: IT WORKS ! ! ! :) :) :)
thanks a lot! :D
Again no problem!
All of us RPi users just need to hope for a working build from BCM.
Bhavesh
PeTiT
Fri Jun 28, 2013 6:04 am
thanks a lot! :D
any hint to make Android running faster on RPi? :)
with default RPi settings Android is running very slow :(
Fri Jun 28, 2013 8:33 am
It's not yet hardware accelerated, and there is no current way to make it any faster.
PeTiT
Fri Jun 28, 2013 8:37 am
jamesh wrote:It's not yet hardware accelerated, and there is no current way to make it any faster.
do u think I'll have some benefits overclocking my RPi?
aaa801
Sat Jun 29, 2013 1:39 pm
Sure, if you clock it to around 6Ghz :D
PeTiT
Sat Jun 29, 2013 2:24 pm
...lol
Return to “Android”
