Replacing car head unit
Posted: Mon Jun 18, 2018 1:32 am
by aharonhakohen
Hi All -
I have searched this forum, and the internet in general, but have come up empty handed.
I am new to Pi, so perhaps there is a reason I cannot find information...
I would like to REPLACE my car's head unit with a Raspberry Pi running Android. I would add a digital to analog audio converter, a USB GPS, a fm tuner, camera, etc.
Am I missing something? Why can I not find even one person attempting the same thing? Most projects have been installing a Pi to an existing head unit, which I do not want to do.
The "cheap" Android head units out there are junk, and I do not want to spend hundreds (at least) of dollars.
Although I am new to Pi, I have experience with car audio, electronics, soldering, etc.
The project seems pretty straight-foward. I know I only gave the very basics, but does anyone have any ideas, comments, or insights? I am all ears...
Thanks!
Re: Relacing car head unit
Posted: Mon Jun 18, 2018 11:54 am
by thagrol
Last time I checked there ia no version of android that runs on any Pi model. (Well android things but that isn't stock android)
Posted: Fri Jun 29, 2018 2:37 pm
by fruitoftheloom
Hi All -
Thanks!
Regards Android variants see:
viewtopic.php?f=73&t=217000
Android Auto open source variant OpenAuto:
https://www.raspberrypi.org/magpi/andro ... -openauto/
Please be aware you should approach the developers for support of whatever Android Solution you choose to implement..
Posted: Fri Jun 29, 2018 4:24 pm
by thagrol
It seems things have changed. See MagPi issue 71: https://www.raspberrypi.org/magpi/
Re: Replacing car head unit
Posted: Fri Jun 29, 2018 5:01 pm
by fruitoftheloom
Yes quite so, it was in the link I posted above which shows other Android AOSP / Things variants......
Posted: Wed Dec 11, 2019 5:34 pm
by KngArthr
I am also looking into doing this. I would like to get rid of the original car stereo header unit completely and create one with a Raspberry Pi and a touchscreen. I have a 2002 Honda Accord. Some concerns I have so far are:
-Is there a way to connect the header unit wires to the Raspberry Pi?
-I'm assuming there is an adaptor to be able to plug it into the USB port?
-I have heard that stereo head units have amplifiers and equalizers built-in. Is there a way the Raspberry PI can act/mimic those?
-How will the Raspberry Pi know which sounds to send to the tweeters and which sounds to send to the bass speakers?
-Will I be able to use my steering wheel controls?
-Is there a way for Bluetooth connectivity?
Respectfully.
KngArthr
Posted: Wed Dec 11, 2019 10:31 pm
by thagrol
Do you mean plug the Pi into the car rather than the head unit you're removing into the Pi?
Nope. There's a bunch of analogue connections on the back of the head unit and, if you're lucky there'll be one ot the car's data buses present too. The ISO standard is here but check whether that appplies to your model: https://en.wikipedia.org/wiki/Connectors_for_car_audio
Probably but it'll likely be easier to put a power amp between the Pi and the speakers. Try asking on a car audio specific forum.
it won't , and I doubt that your head unit does either. Equally, I doubt that your car has seperate woofers, tweeters and midrange speakers. It's generally something taken care of in the speaker cabinet or by an external crossover circuit. Again car audio or audiophile websites and forums are probably the best palce to look.
Maybe. If you can safely interface your car's data bus to the Pi then identify and decode the necessary messages. Be careful with the hardware interfacing here. If you damage your car you could be in for some expensive bills.
Possibly, it depends on what you want and which model Pi you're using. zeroW, zeroWH, 3A, 3B, 3A+, 3B+, and 4B have onboard bluetooth other Pi models don't.
