karlenando
Re: Continuous scroll on RCA video
Fri Oct 12, 2012 6:20 pm
how can I do if I have no screen?
aaa801
Fri Oct 12, 2012 6:50 pm
karlenando wrote:how can I do if I have no screen?
adb is enabled over network, just run adb connect 192.#####
then adb shell
then logcat
AndroidPI
Fri Oct 12, 2012 8:22 pm
So what is the best version of android to use
to boot on my Raspberry PI "B" board?
I will be using HDMI
but would also like to have
RCA video out and Audio out working too
karlenando
Fri Oct 12, 2012 9:36 pm
Hi.
I am in ubuntu 12.04 and the command adb was unknown.
I made a search over the internet and now I am installing the android sdk manager.
When finished what have I to do?
Tks
karlenando
Fri Oct 12, 2012 9:52 pm
Ok.
I have found how to run adb
I have written "./adb connect 192.168.1.251" (this is the ip my router reserved to rpi)
The answer has been: "unable to connect to 192.168.1.251:5555"
Then I have enabled port 5555 on my router but the answer was the same.
aaa801
Fri Oct 12, 2012 10:02 pm
karlenando wrote:Ok.
It may not be on that ip,
Try running a port scan on the 192.168.1.# range on port 5555
karlenando
Fri Oct 12, 2012 10:12 pm
I don't know how to scan port.
I have done the following:
1) "adb devices" and the answer was a blank line
2) ./adb kill-server
sudo ./adb start-server
[sudo] password for :
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
3) adb devices again and none found
karlenando
Fri Oct 12, 2012 10:22 pm
You were right . ;)
I have checked my router and the device ip is 192.168.1.21 and not 251
(in 251 is my android wi-fi mobile)
but the result is the same trying to connect 192.168.1.21
karlenando
Fri Oct 12, 2012 10:58 pm
:) I am in the device giving the number of the port adb 192.168.1.21:5555
so I have the logcat:
# logcat |more
--------- beginning of /dev/log/main
I/cm ( 54): Welcome to Android 2.3.7 /
I/cm ( 55): _
I/cm ( 56): __ __ _ ___ _ _ __ ___ __ _ _ _ _ __ __))
I/cm ( 57): ((_ \(/'((_( ((\( ((_)((_( (('((\( ((`1( ((_)((_(
I/cm ( 58): )) _))
I/cm ( 59):
I/mountsd ( 73): Checking filesystems..
I/run-parts( 49): e2fsck 1.41.12 (17-May-2010)
I/run-parts( 49): e2fsck: Device or resource busy while trying to open /dev/block/mmcblk0p2
I/run-parts( 49): Filesystem mounted or opened exclusively by another program?
E/mountsd ( 79): Unable to repair filesystem, disabling apps2sd
I/DEBUG ( 99): debuggerd: Jul 27 2012 21:14:00
--------- beginning of /dev/log/system
I/Vold ( 97): Vold 2.1 (the revenge) firing up
D/Vold ( 97): USB mass storage support is not enabled in the kernel
D/Vold ( 97): usb_configuration switch is not enabled in the kernel
D/Vold ( 97): Volume sdcard state changing -1 (Initializing) -> 0 (No-Media)
I/Netd ( 98): Netd 1.0 starting
D/Vold ( 97): Volume sdcard state changing 0 (No-Media) -> 2 (Pending)
D/DHCP ( 108): ===== DHCP message:
D/DHCP ( 108): op = BOOTREQUEST (1), htype = 1, hlen = 6, hops = 0
D/DHCP ( 108): xid = 0x08140000 secs = 0, flags = 0x8000 optlen = 14
D/DHCP ( 108): ciaddr = 0.0.0.0
D/DHCP ( 108): yiaddr = 0.0.0.0
D/DHCP ( 108): siaddr = 0.0.0.0
D/DHCP ( 108): giaddr = 0.0.0.0
D/DHCP ( 108): chaddr = { b8 27 eb 81 3a dd }
D/DHCP ( 108): sname = ''
D/DHCP ( 108): file = ''
D/DHCP ( 108): op 53 len 1 { 01 } discover
D/DHCP ( 108): op 55 len 4 { 01 03 06 1c }
D/Vold ( 97): Volume sdcard state changing 2 (Pending) -> 1 (Idle-Unmounted)
D/AndroidRuntime( 101):
D/AndroidRuntime( 101): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
I/AndroidRuntime( 101): Heap size: -Xmx16m
D/AndroidRuntime( 101): CheckJNI is ON
I/ ( 102): ServiceManager: 0x13b5d50
W/AudioHardwareInterface( 102): Using stubbed audio hardware. No sound will be produced.
D/AudioHardwareInterface( 102): setMode(NORMAL)
I/CameraService( 102): CameraService started (pid=102)
D/AudioFlinger( 102): setParameters(): io 1, keyvalue routing=2, tid 130, calling tid 102
I/AudioFlinger( 102): AudioFlinger's thread 0x13b7630 ready to run
I/ethernet( 101): Loading ethernet jni class
I/SamplingProfilerIntegration( 101): Profiler is disabled.
I/Zygote ( 101): Preloading classes...
E/Zygote ( 101): setreuid() failed. errno: 30
D/dalvikvm( 101): GC_EXPLICIT freed 47K, 77% free 237K/1024K, external 0K/0K, paused 5ms
W/MediaProfiles( 101): could not find media config xml file
D/RenderScript_jni( 101): RenderScript JNI library not found!
D/dalvikvm( 101): GC_FOR_MALLOC freed 2914K, 57% free 2208K/5123K, external 0K/0K, paused 75ms
D/DHCP ( 108): TIMEOUT
D/dalvikvm( 101): GC_FOR_MALLOC freed 2633K, 52% free 2486K/5123K, external 0K/0K, paused 69ms
D/DHCP ( 108): op = BOOTREPLY (2), htype = 1, hlen = 6, hops = 0
D/DHCP ( 108): xid = 0x08140000 secs = 0, flags = 0x8000 optlen = 64
D/DHCP ( 108): yiaddr = 192.168.1.21
D/DHCP ( 108): siaddr = 192.168.1.1
D/DHCP ( 108): op 53 len 1 { 02 } offer
D/DHCP ( 108): op 54 len 4 { c0 a8 01 01 }
D/DHCP ( 108): op 51 len 4 { 00 00 54 60 }
D/DHCP ( 108): op 1 len 4 { ff ff ff 00 }
D/DHCP ( 108): op 3 len 4 { c0 a8 01 01 }
D/DHCP ( 108): op 6 len 4 { c0 a8 01 01 }
D/DHCP ( 108): op 28 len 4 { c0 a8 01 ff }
D/DHCP ( 108): --- dhcp offer (2) ---
D/DHCP ( 108): ip 192.168.1.21 gw 192.168.1.1 mask 255.255.255.0
D/DHCP ( 108): dns1: 192.168.1.1
D/DHCP ( 108): server 192.168.1.1, lease 21600 seconds
D/DHCP ( 108): xid = 0x09140000 secs = 0, flags = 0x8000 optlen = 26
D/DHCP ( 108): op 53 len 1 { 03 } request
D/DHCP ( 108): op 50 len 4 { c0 a8 01 15 }
D/DHCP ( 108): xid = 0x09140000 secs = 0, flags = 0x8000 optlen = 64
D/DHCP ( 108): op 53 len 1 { 05 } ack
D/DHCP ( 108): --- dhcp ack (5) ---
D/DHCP ( 108): configuring eth0
I/Zygote ( 101): ...preloaded 1829 classes in 8268ms.
D/Zygote ( 101): setreuid() error ignored, same uid.
D/dalvikvm( 101): GC_EXPLICIT freed 852K, 48% free 2678K/5123K, external 0K/0K, paused 57ms
I/Zygote ( 101): Preload resources disabled, skipped.
D/dalvikvm( 101): GC_EXPLICIT freed 25K, 49% free 2653K/5123K, external 0K/0K, paused 46ms
D/dalvikvm( 101): GC_EXPLICIT freed <1K, 49% free 2653K/5123K, external 0K/0K, paused 45ms
I/dalvikvm( 101): System server process 133 has been created
I/Zygote ( 101): Accepting command socket connections
D/SystemClock( 133): Setting time of day to sec=86400
W/SystemServer( 133): System clock is before 1970; setting to 1970.
E/BatteryService( 133): usbOnlinePath not found
E/BatteryService( 133): batteryVoltagePath not found
E/BatteryService( 133): batteryTemperaturePath not found
I/sysproc ( 133): Entered system_init()
I/sysproc ( 133): ServiceManager: 0x1958bb0
I/SurfaceFlinger( 133): SurfaceFlinger is starting
I/SurfaceFlinger( 133): dithering enabled
I/SurfaceFlinger( 133): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
E/SurfaceFlinger( 133): Couldn't open /sys/power/wait_for_fb_sleep or /sys/power/wait_for_fb_wake
I/gralloc ( 133): using (fd=25)
I/gralloc ( 133): id = BCM2708 FB
I/gralloc ( 133): xres = 656 px
I/gralloc ( 133): yres = 512 px
I/gralloc ( 133): xres_virtual = 656 px
I/gralloc ( 133): yres_virtual = 1024 px
I/gralloc ( 133): bpp = 16
I/gralloc ( 133): r = 11:5
I/gralloc ( 133): g = 5:6
I/gralloc ( 133): b = 0:5
I/gralloc ( 133): width = 512 mm (32.543751 dpi)
I/gralloc ( 133): height = 656 mm (19.824390 dpi)
I/gralloc ( 133): refresh rate = 60.00 Hz
D/libEGL ( 133): egl.cfg not found, using default config
D/libEGL ( 133): loaded /system/lib/egl/libGLES_android.so
W/SurfaceFlinger( 133): ro.sf.lcd_density not defined, using 160 dpi by default.
I/SurfaceFlinger( 133): EGL informations:
I/SurfaceFlinger( 133): # of configs : 8
I/SurfaceFlinger( 133): vendor : Android
I/SurfaceFlinger( 133): version : 1.4 Android META-EGL
I/SurfaceFlinger( 133): extensions: EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_ANDROID_image_native_buffer EGL_ANDROID_swap_rectangle EGL_ANDROID_get_render_buffer
I/SurfaceFlinger( 133): Client API: OpenGL ES
I/SurfaceFlinger( 133): EGLSurface: 5-6-5-0, config=0x0
I/SurfaceFlinger( 133): OpenGL informations:
I/SurfaceFlinger( 133): renderer : Android PixelFlinger 1.4
I/SurfaceFlinger( 133): version : OpenGL ES-CM 1.0
I/SurfaceFlinger( 133): extensions: GL_OES_byte_coordinates GL_OES_fixed_point GL_OES_single_precision GL_OES_read_format GL_OES_compressed_paletted_texture GL_OES_draw_texture GL_OES_matrix_get GL_OES_query_matrix GL_OES_EGL_image GL_OES_compressed_ETC1_RGB8_texture GL_ARB_texture_compression GL_ARB_texture_non_power_of_two GL_ANDROID_user_clip_plane GL_ANDROID_vertex_buffer_object GL_ANDROID_generate_mipmap
I/SurfaceFlinger( 133): GL_MAX_TEXTURE_SIZE = 4096
I/SurfaceFlinger( 133): GL_MAX_VIEWPORT_DIMS = 4096
I/SurfaceFlinger( 133): flags = 000c0000
D/SensorService( 133): nuSensorService starting...
E/SensorService( 133): couldn't load sensors module (No such file or directory)
I/sysproc ( 133): System server: starting Android runtime.
I/sysproc ( 133): System server: starting Android services.
I/sysproc ( 133): System server: entering thread pool.
I/SystemServer( 133): Entered the Android system server!
I/SystemServer( 133): Entropy Service
D/libEGL ( 145): egl.cfg not found, using default config
D/libEGL ( 145): loaded /system/lib/egl/libGLES_android.so
W/zipro ( 145): Unable to open zip '/data/local/bootanimation.zip': No such f ile or directory
I/SystemServer( 133): Power Manager
I/SystemServer( 133): Activity Manager
I/ActivityManager( 133): Memory class: 16
W/UsageStats( 133): Usage stats version changed; dropping
I/SystemServer( 133): Telephony Registry
I/SystemServer( 133): Package Manager
I/installd( 105): new connection
I/Installer( 133): connecting...
D/dalvikvm( 133): GC_CONCURRENT freed 168K, 48% free 2956K/5639K, external 0K/0K, paused 7ms+6ms
W/PackageManager( 133): Running ENG build: no pre-dexopt!
W/PackageParser( 133): Unknown element under <manifest>: meta-data at /system/app/Cyanbread.apk Binary XML file line #43
D/dalvikvm( 133): GC_CONCURRENT freed 249K, 48% free 3124K/5895K, external 0K/0K, paused 4ms+6ms
W/ResourceType( 133): getEntry failing because entryIndex 296 is beyond type entryCount 171
W/ResourceType( 133): Failure getting entry for 0x01030128 (t=2 e=296) in package 0 (error -2147483647)
D/dalvikvm( 133): GC_CONCURRENT freed 196K, 44% free 3415K/6087K, external 0K/0
W/PackageParser( 133): Unknown element under <manifest>: meta-data at /system/app/Androidian.apk Binary XML file line #43
W/PackageParser( 133): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #132
W/PackageParser( 133): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #154
D/dalvikvm( 133): GC_CONCURRENT freed 223K, 43% free 3619K/6343K, external 0K/0K, paused 4ms+9ms
D/PackageManager( 133): No files in app dir /vendor/app
I/PackageManager( 133): Time to scan packages: 3.15 seconds
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.contacts
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
W/PackageManager( 133): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
ECEIVE in package com.koushikdutta.rommanagerom.google.android.c2dm.permission.R--More--
W/PackageManager( 133): Unknown permission com.android.vending.BILLING in package com.koushikdutta.rommanager
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.contacts
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cp in package com.android.providers.contacts
W/PackageManager( 133): Unknown permission com.google.android.gm.permission.WRITE_GMAIL in package com.android.settings
W/PackageManager( 133): Unknown permission com.google.android.gm.permission.READ_GMAIL in package com.android.settings
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager( 133): Unknown permission com.google.android.c2dm.permission.RECEIVE in package com.cyanogenmod.updatenotify
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.ACCESS_GOOGLE_PASSWORD in package com.android.development
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.development
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.ALL_SERVICES in package com.android.development
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.YouTubeUser in package com.android.development
W/PackageManager( 133): Unknown permission android.permission.READ_OWNER_DATA in package com.android.email
W/PackageManager( 133): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x8be45)
D/dalvikvm( 133): GC_EXPLICIT freed 365K, 45% free 3615K/6471K, external 0K/0K, paused 66ms
I/SystemServer( 133): Account Manager
I/SystemServer( 133): Content Manager
I/SystemServer( 133): System Content Providers
I/ActivityThread( 133): Pub settings: com.android.providers.settings.SettingsProvider
I/SystemServer( 133): Battery Service
D/SettingsProvider( 133): cache for settings table 'secure' rows=31; fullycached=true
I/SystemServer( 133): Lights Service
I/SystemServer( 133): Vibrator Service
D/SettingsProvider( 133): cache for settings table 'system' rows=59; fullycached=true
I/SystemServer( 133): Alarm Manager
I/SystemServer( 133): Init Watchdog
I/SystemServer( 133): Window Manager
W/dalvikvm( 133): threadid=16: thread exiting with uncaught exception (group=0x401f9560)
E/ActivityManager( 133): Attempt to launch receivers of broadcast intent Intent { act=android.intent.action.TIME_SET flg=0x20000000 } before boot completion
E/AndroidRuntime( 133): *** FATAL EXCEPTION IN SYSTEM PROCESS: AlarmManager
E/AndroidRuntime( 133): java.lang.IllegalStateException: Cannot broadcast before boot completed
E/AndroidRuntime( 133): at com.android.server.am.ActivityManagerService.verifyBroadcastLocked(ActivityManagerService.java:10544)
E/AndroidRuntime( 133): at com.android.server.am.ActivityManagerService.broadcastIntent(ActivityManagerService.java:10561)
E/AndroidRuntime( 133): at android.app.ContextImpl.sendBroadcast(ContextImpl.java:686)
E/AndroidRuntime( 133): at com.android.server.AlarmManagerService$AlarmThread.run(AlarmManagerService.java:665)
I/InputManager( 133): Initializing input manager
I/Process ( 133): Sending signal. PID: 133 SIG: 9
E/AndroidRuntime( 133): Error reporting crash
E/AndroidRuntime( 133): java.lang.NullPointerException
E/AndroidRuntime( 133): at android.os.DropBoxManager.isTagEnabled(DropBoxManager.java:288)
E/AndroidRuntime( 133): at com.android.server.am.ActivityManagerService.addErrorToDropBox(ActivityManagerService.java:6837)
E/AndroidRuntime( 133): at com.android.server.am.ActivityManagerService.handleApplicationCrash(ActivityManagerService.java:6546)
E/AndroidRuntime( 133): at com.android.internal.os.RuntimeInit$UncaughtHandler.uncaughtException(RuntimeInit.java:76)
E/AndroidRuntime( 133): at java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:854)
E/AndroidRuntime( 133): at java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:851)
I/ServiceManager( 96): service 'batteryinfo' died
I/ServiceManager( 96): service 'usagestats' died
I/ServiceManager( 96): service 'telephony.registry' died
I/ServiceManager( 96): service 'package' died
I/ServiceManager( 96): service 'permission' died
I/ServiceManager( 96): service 'activity' died
I/ServiceManager( 96): service 'meminfo' died
I/ServiceManager( 96): service 'cpuinfo' died
I/ServiceManager( 96): service 'entropy' died
I/ServiceManager( 96): service 'power' died
I/ServiceManager( 96): service 'SurfaceFlinger' died
I/ServiceManager( 96): service 'sensorservice' died
I/ServiceManager( 96): service 'account' died
I/ServiceManager( 96): service 'content' died
I/ServiceManager( 96): service 'battery' died
I/ServiceManager( 96): service 'hardware' died
I/ServiceManager( 96): service 'vibrator' died
I/ServiceManager( 96): service 'alarm' died
D/BootAnimation( 145): SurfaceFlinger died, exiting...
E/installd( 105): eof
E/installd( 105): failed to read size
I/installd( 105): closing connection
I/Zygote ( 101): Exit zygote because system server (133) has terminated
I/ServiceManager( 96): service 'media.audio_flinger' died
I/ServiceManager( 96): service 'media.audio_policy' died
I/ServiceManager( 96): service 'media.player' died
I/ServiceManager( 96): service 'media.camera' died
I/Netd ( 162): Netd 1.0 starting
D/AndroidRuntime( 163):
D/AndroidRuntime( 163): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
I/AndroidRuntime( 163): Heap size: -Xmx16m
D/AndroidRuntime( 163): CheckJNI is ON
I/ ( 161): ServiceManager: 0x12f8d50
W/AudioHardwareInterface( 161): Using stubbed audio hardware. No sound will be produced.
D/AudioHardwareInterface( 161): setMode(NORMAL)
I/CameraService( 161): CameraService started (pid=161)
D/AudioFlinger( 161): setParameters(): io 1, keyvalue routing=2, tid 168, calling tid 161
I/AudioFlinger( 161): AudioFlinger's thread 0x12fa640 ready to run
I/ethernet( 163): Loading ethernet jni class
I/SamplingProfilerIntegration( 163): Profiler is disabled.
I/Zygote ( 163): Preloading classes...
E/Zygote ( 163): setreuid() failed. errno: 30
D/dalvikvm( 163): GC_EXPLICIT freed 47K, 77% free 237K/1024K, external 0K/0K, paused 4ms
W/MediaProfiles( 163): could not find media config xml file
D/RenderScript_jni( 163): RenderScript JNI library not found!
D/dalvikvm( 163): GC_FOR_MALLOC freed 2915K, 57% free 2208K/5123K, external 0K/0K, paused 75ms
D/dalvikvm( 163): GC_FOR_MALLOC freed 2634K, 52% free 2485K/5123K, external 0K/0K, paused 68ms
I/Zygote ( 163): ...preloaded 1829 classes in 6736ms.
D/Zygote ( 163): setreuid() error ignored, same uid.
D/dalvikvm( 163): GC_EXPLICIT freed 849K, 48% free 2678K/5123K, external 0K/0K, paused 58ms
I/Zygote ( 163): Preload resources disabled, skipped.
D/dalvikvm( 163): GC_EXPLICIT freed 25K, 49% free 2653K/5123K, external 0K/0K, paused 47ms
D/dalvikvm( 163): GC_EXPLICIT freed <1K, 49% free 2653K/5123K, external 0K/0K, paused 47ms
I/dalvikvm( 163): System server process 171 has been created
I/Zygote ( 163): Accepting command socket connections
E/BatteryService( 171): usbOnlinePath not found
E/BatteryService( 171): batteryVoltagePath not found
E/BatteryService( 171): batteryTemperaturePath not found
I/sysproc ( 171): Entered system_init()
I/sysproc ( 171): ServiceManager: 0x19b4650
I/SurfaceFlinger( 171): SurfaceFlinger is starting
I/SurfaceFlinger( 171): dithering enabled
I/SurfaceFlinger( 171): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
E/SurfaceFlinger( 171): Couldn't open /sys/power/wait_for_fb_sleep or /sys/power/wait_for_fb_wake
I/gralloc ( 171): using (fd=25)
I/gralloc ( 171): id = BCM2708 FB
I/gralloc ( 171): xres = 656 px
I/gralloc ( 171): yres = 512 px
I/gralloc ( 171): xres_virtual = 656 px
I/gralloc ( 171): yres_virtual = 1024 px
I/gralloc ( 171): bpp = 16
I/gralloc ( 171): r = 11:5
I/gralloc ( 171): g = 5:6
I/gralloc ( 171): b = 0:5
I/gralloc ( 171): width = 512 mm (32.543751 dpi)
I/gralloc ( 171): height = 656 mm (19.824390 dpi)
I/gralloc ( 171): refresh rate = 60.00 Hz
D/libEGL ( 171): egl.cfg not found, using default config
D/libEGL ( 171): loaded /system/lib/egl/libGLES_android.so
W/SurfaceFlinger( 171): ro.sf.lcd_density not defined, using 160 dpi by default.
I/SurfaceFlinger( 171): EGL informations:
I/SurfaceFlinger( 171): # of configs : 8
I/SurfaceFlinger( 171): vendor : Android
I/SurfaceFlinger( 171): version : 1.4 Android META-EGL
I/SurfaceFlinger( 171): extensions: EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_ANDROID_image_native_buffer EGL_ANDROID_swap_rectangle EGL_ANDROID_get_render_buffer
I/SurfaceFlinger( 171): Client API: OpenGL ES
I/SurfaceFlinger( 171): EGLSurface: 5-6-5-0, config=0x0
I/SurfaceFlinger( 171): OpenGL informations:
I/SurfaceFlinger( 171): renderer : Android PixelFlinger 1.4
I/SurfaceFlinger( 171): version : OpenGL ES-CM 1.0
I/SurfaceFlinger( 171): extensions: GL_OES_byte_coordinates GL_OES_fixed_point
I/SurfaceFlinger( 171): GL_MAX_TEXTURE_SIZE = 4096
I/SurfaceFlinger( 171): GL_MAX_VIEWPORT_DIMS = 4096
I/SurfaceFlinger( 171): flags = 000c0000
D/SensorService( 171): nuSensorService starting...
E/SensorService( 171): couldn't load sensors module (No such file or directory)
I/sysproc ( 171): System server: starting Android runtime.
I/sysproc ( 171): System server: starting Android services.
I/SystemServer( 171): Entered the Android system server!
I/sysproc ( 171): System server: entering thread pool.
I/SystemServer( 171): Entropy Service
D/libEGL ( 183): egl.cfg not found, using default config
D/libEGL ( 183): loaded /system/lib/egl/libGLES_android.so
W/zipro ( 183): Unable to open zip '/data/local/bootanimation.zip': No such file or directory
W/zipro ( 183): Unable to open zip '/system/media/bootanimation.zip': No such file or directory
I/SystemServer( 171): Power Manager
I/SystemServer( 171): Activity Manager
I/ActivityManager( 171): Memory class: 16
W/UsageStats( 171): Usage stats version changed; dropping
I/SystemServer( 171): Telephony Registry
I/SystemServer( 171): Package Manager
I/Installer( 171): connecting...
D/dalvikvm( 171): GC_CONCURRENT freed 168K, 48% free 2969K/5639K, external 0K/0K, paused 4ms+6ms
W/PackageManager( 171): Running ENG build: no pre-dexopt!
W/PackageParser( 171): Unknown element under <manifest>: meta-data at /system/app/Cyanbread.apk Binary XML file line #43
D/dalvikvm( 171): GC_CONCURRENT freed 254K, 47% free 3174K/5959K, external 0K/0K, paused 4ms+9ms
W/ResourceType( 171): getEntry failing because entryIndex 296 is beyond type entryCount 171
W/ResourceType( 171): Failure getting entry for 0x01030128 (t=2 e=296) in package 0 (error -2147483647)
W/PackageParser( 171): Unknown element under <manifest>: meta-data at /system/app/Androidian.apk Binary XML file line #43
D/dalvikvm( 171): GC_CONCURRENT freed 214K, 45% free 3468K/6215K, external 0K/0K, paused 4ms+8ms
W/PackageParser( 171): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #132
W/PackageParser( 171): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #154
D/PackageManager( 171): No files in app dir /vendor/app
I/PackageManager( 171): Time to scan packages: 1.898 seconds
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.contacts
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
D/dalvikvm( 171): GC_CONCURRENT freed 282K, 43% free 3701K/6471K, external 0K/0K, paused 5ms+9ms
W/PackageManager( 171): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
W/PackageManager( 171): Unknown permission com.google.android.c2dm.permission.RECEIVE in package com.koushikdutta.rommanager
W/PackageManager( 171): Unknown permission com.android.vending.BILLING in package com.koushikdutta.rommanager
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.contacts
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cp in package com.android.providers.contacts
W/PackageManager( 171): Unknown permission com.google.android.gm.permission.WRITE_GMAIL in package com.android.settings
W/PackageManager( 171): Unknown permission com.google.android.gm.permission.READ_GMAIL in package com.android.settings
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager( 171): Unknown permission com.google.android.c2dm.permission.RECEIVE in package com.cyanogenmod.updatenotify
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.ACCESS_GOOGLE_PASSWORD in package com.android.development
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.development
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.ALL_SERVICES in package com.android.development
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.YouTubeUser in package com.android.development
W/PackageManager( 171): Unknown permission android.permission.READ_OWNER_DATA in package com.android.email
W/PackageManager( 171): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x8be45)
D/dalvikvm( 171): GC_EXPLICIT freed 306K, 46% free 3592K/6599K, external 0K/0K,
I/SystemServer( 171): Account Manager
I/SystemServer( 171): Content Manager
I/ActivityThread( 171): Pub settings: com.android.providers.settings.SettingsProvider
I/SystemServer( 171): System Content Providers
I/SystemServer( 171): Battery Service
D/SettingsProvider( 171): cache for settings table 'secure' rows=31; fullycached=true
I/SystemServer( 171): Lights Service
I/SystemServer( 171): Vibrator Service
D/SettingsProvider( 171): cache for settings table 'system' rows=59; fullycached=true
I/SystemServer( 171): Alarm Manager
I/SystemServer( 171): Init Watchdog
I/SystemServer( 171): Window Manager
I/InputManager( 171): Initializing input manager
I/WindowManager( 171): names for haptic settings for haptic long array: haptic_long_array default: haptic_long_array_default
I/WindowManager( 171): pulled string: 0,1,20,21 default: 0,1,20,21
I/WindowManager( 171): haptic done for long array!
I/WindowManager( 171): names for haptic settings for haptic down array: haptic_down_array default: haptic_down_array_defaultI/WindowManager( 171): pulled string: 0,10,20,30 default: 0,10,20,30
I/WindowManager( 171): haptic done for down array!
I/WindowManager( 171): names for haptic settings for haptic tap array: haptic_tap_array default: haptic_tap_array_default
I/WindowManager( 171): pulled string: 40 default: 40
I/WindowManager( 171): haptic done for tap array!
I/WindowManager( 171): names for haptic settings for haptic up array: haptic_up_array default: haptic_up_array_default
I/WindowManager( 171): pulled string: 5,18 default: 5,18
I/WindowManager( 171): haptic done for up array!
I/InputManager( 171): Starting input manager
I/SystemServer( 171): Bluetooth Service
I/EventHub( 171): New device: path=/dev/input/event2 name=USB Optical Mouse id=0x10000 (of 0x1) index=1 fd=91 classes=0x100
E/EventHub( 171): could not get driver version for /dev/input/mouse0, Not a typewriter
I/EventHub( 171): New keyboard: device->id=0x10001 devname='CHICONY USB Keyboard' propName='hw.keyboards.65537.devname' keylayout='/system/usr/keylayout/qwerty.kl'
I/EventHub( 171): New device: path=/dev/input/event1 name=CHICONY USB Keyboard id=0x10001 (of 0x2) index=2 fd=93 classes=0x15
I/EventHub( 171): New keyboard: device->id=0x10002 devname='CHICONY USB Keyboard' propName='hw.keyboards.65538.devname' keylayout='/system/usr/keylayout/qwerty
I/EventHub( 171): New device: path=/dev/input/event0 name=CHICONY USB Keyboard id=0x10002 (of 0x3) index=3 fd=94 classes=0x3
E/EventHub( 171): could not get driver version for /dev/input/mice, Not a typewriter
I/InputReader( 171): Device added: id=0x10002, name=CHICONY USB Keyboard, sources=00000101
I/InputReader( 171): Device added: id=0x0, name=CHICONY USB Keyboard, sources=00001103
I/InputManager-Callbacks( 171): No input device calibration properties found for device CHICONY USB Keyboard.
I/InputReader( 171): Device added: id=0x10000, name=USB Optical Mouse, sources=00002002
I/BluetoothProfileState( 171): Message:Entering Stable State
I/InputManager-Callbacks( 171): No input device calibration properties found for device USB Optical Mouse.
V/SystemServer( 171): Bluetooth Network Service
I/SystemServer( 171): Device Policy
I/SystemServer( 171): Status Bar
I/SystemServer( 171): Clipboard Service
I/SystemServer( 171): Input Method Service
I/InputManagerService( 171): Enabled input methods: com.android.inputmethod.latin/.LatinIME
I/SystemServer( 171): NetStat Service
I/SystemServer( 171): NetworkManagement Service
I/SystemServer( 171): Connectivity Service
I/ConnectivityService( 171): hostname has been set: android-519750752580062e
V/ConnectivityService( 171): Starting Ethernet Service.
I/ethernet( 171): interface eth0:2 found
E/ethernet( 171): android_net_ethernet_initEthernetNative exited with success
V/EthernetStateTracker( 171): Starts...
V/EthernetStateTracker( 171): Successed
I/ethernet( 171): User ask for device name on 0, list:1A23CB0, total:1
I/EthernetService( 171): Ethernet dev enabled 2
V/EthernetService( 171): device 0 name eth0
V/EthernetStateTracker( 171): start to monitor the ethernet devices
I/EthernetManager( 171): Init Ethernet Manager, service: com.android.server.EthernetService@407b21d8
I/EthernetStateTracker( 171): reset device eth0
D/dalvikvm( 171): GC_CONCURRENT freed 163K, 42% free 3843K/6599K, external 0K/0K, paused 4ms+13ms
W/EthernetStateTracker( 171): Could not stop DHCP
I/EthernetStateTracker( 171): trigger dhcp for device eth0
D/EthernetStateTracker( 171): DhcpHandler: DHCP request started
I/WifiService( 171): WifiService starting up with Wi-Fi disabled
D/NetworkManagmentService( 171): Registering observer
I/SystemServer( 171): Throttle Service
I/SystemServer( 171): Accessibility Manager
I/SystemServer( 171): Mount Service
I/SystemServer( 171): Profile Manager
I/PackageManager( 171): Updating external media status from unmounted to unmounted
D/VoldCmdListener( 97): volume list
D/VoldCmdListener( 97): share status ums
D/ProfileService( 171): Found active: 3bc7c46c-083b-4a05-b019-15072abfe187
D/ProfileService( 171): Set active profile to: 3bc7c46c-083b-4a05-b019-15072abfe187 - Default
D/ProfileService( 171): Saving profile data...
D/ProfileService( 171): Save completed.
I/SystemServer( 171): Notification Manager
I/SystemServer( 171): Device Storage Monitor
I/SystemServer( 171): Location Manager
I/SystemServer( 171): Search Service
I/SystemServer( 171): DropBox Service
I/SystemServer( 171): Wallpaper Service
I/SystemServer( 171): Audio Service
W/AudioPolicyManagerBase( 161): setPhoneState() setting same state 0
D/dalvikvm( 171): GC_CONCURRENT freed 307K, 41% free 4067K/6855K, external 0K/0K, paused 6ms+17ms
I/SystemServer( 171): Headset Observer
W/HeadsetObserver( 171): This kernel does not have wired headset support
I/SystemServer( 171): HDMI Observer
W/HDMIObserver( 171): This kernel does not have hdmi support
W/UsbDeviceSettingsManager( 171): settings file not found
I/SystemServer( 171): Dock Observer
W/DockObserver( 171): This kernel does not have dock station support
I/SystemServer( 171): USB Service
I/UsbService( 171): This kernel does not have USB configuration switch support
I/UsbService( 171): Trying legacy USB configuration switch support
I/UsbService( 171): This kernel does not have legacy USB configuration switch support
I/SystemServer( 171): UI Mode Manager Service
I/SystemServer( 171): Backup Service
V/BackupManagerService( 171): No ancestral data
I/BackupManagerService( 171): Found stale backup journal, scheduling
I/BackupManagerService( 171): android
I/BackupManagerService( 171): com.android.browser
I/BackupManagerService( 171): com.android.inputmethod.latin
I/BackupManagerService( 171): com.android.providers.settings
I/BackupManagerService( 171): com.android.providers.userdictionary
I/BackupManagerService( 171): Backup enabled => false
I/SystemServer( 171): AppWidget Service
I/WindowManager( 171): SAFE MODE not enabled
D/dalvikvm( 171): JIT started for system_server
I/SystemServer( 171): Recognition Service
I/SystemServer( 171): DiskStats Service
I/SystemServer( 171): AssetRedirectionManager Service
I/power ( 171): *** set_screen_state 1
E/power ( 171): Failed setting last user activity: g_error=0
D/PowerManagerService( 171): system ready!
I/ActivityManager( 171): System now ready
I/SystemServer( 171): Making services ready
I/StatusBarManagerService( 171): Starting service: ComponentInfo{com.android.systemui/com.android.systemui.statusbar.StatusBarService}
I/Zygote ( 171): Process: zygote socket opened
I/ActivityManager( 171): Start proc com.android.systemui for service com.android.systemui/.statusbar.StatusBarService: pid=229 uid=1000 gids={1015, 3002, 3001, 3003}
I/ActivityManager( 171): Config changed: { scale=1.0 imsi=0/0 loc=en_US touch=0 keys=0/0/0 nav=0/0 orien=0 layout=0 uiMode=17 seq=2 themeResource=null}
I/InputReader( 171): Device reconfigured: id=0x0, name=CHICONY USB Keyboard, di
I/InputManager-Callbacks( 171): No virtual keys found for device CHICONY USB Keyboard.
I/ActivityManager( 171): Config changed: { scale=1.0 imsi=0/0 loc=en_US touch=3 keys=2/1/2 nav=1/1 orien=2 layout=268435475 uiMode=17 seq=3 themeResource=null}
W/RecognitionManagerService( 171): no available voice recognition services found
D/dalvikvm( 171): GC_EXTERNAL_ALLOC freed 339K, 42% free 4042K/6919K, external 0K/0K, paused 126ms
W/AssetRedirectionManager( 171): No such resource found for com.tmobile.theme.Cyanbread:@drawable/frameworks_res_btn_toggle_off
W/AssetRedirectionManager( 171): No such resource found for android:drawable/star_small_on
W/AssetRedirectionManager( 171): No such resource found for android:drawable/star_small_half
D/dalvikvm( 229): GC_CONCURRENT freed 394K, 51% free 2774K/5639K, external 0K/0K, paused 15ms+31ms
D/dalvikvm( 171): GC_EXTERNAL_ALLOC freed 149K, 41% free 4126K/6919K, external 364K/512K, paused 105ms
D/dalvikvm( 171): GC_EXTERNAL_ALLOC freed 148K, 40% free 4179K/6919K, external 966K/1056K, paused 83ms
W/AssetRedirectionManager( 171): No such resource found for com.android.music:drawable/progress_horizontal
W/AssetRedirectionManager( 171): No such resource found for com.android.music:drawable/btn_playback_top_selected
W/AssetRedirectionManager( 171): No such resource found for com.android.music:drawable/ic_mp_album_playback
W/AssetRedirectionManager( 171): No such resource found for com.android.music:drawable/ic_mp_artist_playback
W/AssetRedirectionManager( 171): No such resource found for com.android.music:drawable/ic_mp_song_playback
I/ActivityManager( 171): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.launcher/.Launcher } from pid 0
W/AssetRedirectionManager( 171): No such resource found for com.tmobile.theme.Cyanbread:@drawable/shortcut_selector
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/home_button_pressed
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/home_button_focused
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/all_apps_button_pressed
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/all_apps_button_focused
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/hotseat_phone_focused
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/hotseat_phone_pressed
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/hotseat_phone_normal
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/hotseat_browser_focused
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/hotseat_browser_pressed
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/hotseat_browser_normal
D/dalvikvm( 171): GC_CONCURRENT freed 350K, 41% free 4244K/7111K, external 1516K/1658K, paused 12ms+9ms
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:color/apps3d_glow_pressed
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:color/apps3d_glow_focused
I/ActivityManager( 171): Start proc com.android.launcher for activity com.android.launcher/.Launcher: pid=238 uid=10010 gids={1015}
D/dalvikvm( 171): GREF has increased to 201
D/LockPatternKeyguardView( 171): onScreenTurnedOn()
karlenando
Fri Oct 12, 2012 10:59 pm
I/ActivityManager( 171): Start proc com.android.inputmethod.latin for service com.android.inputmethod.latin/.LatinIME: pid=242 uid=10028 gids={}
I/LocationManagerService( 171): Setting GPS Source to: 0
E/ThrottleService( 171): Could not open GPS configuration file /etc/gps.conf
W/AssetRedirectionManager( 171): No such resource found for com.android.systemui:drawable/stat_sys_data_wimax_signal_3_fully
W/AssetRedirectionManager( 171): No such resource found for com.android.systemui:drawable/stat_sys_data_wimax_signal_2_fully
W/AssetRedirectionManager( 171): No such resource found for com.android.systemui:drawable/stat_sys_data_wimax_signal_1_fully
W/AssetRedirectionManager( 171): No such resource found for com.android.systemui:drawable/stat_sys_data_wimax_signal_0_fully
I/ActivityManager( 171): Start proc com.android.phone for added application com.android.phone: pid=249 uid=1001 gids={3002, 3001, 3003, 1015}
I/SystemServer( 171): Enabled StrictMode for system server main thread.
W/GpsLocationProvider( 171): Could not open GPS configuration file /etc/gps.conf
I//system/bin/tc( 162): Cannot find device "rmnet0"
I/logwrapper( 162): /system/bin/tc terminated by exit(1)
W/ActivityManager( 171): Unable to start service Intent { act=@0 }: not found
W/GpsLocationProvider( 171): Failed to enable location provider
I//system/bin/tc( 162): Cannot find device "ifb0"
I/PowerWidget( 229): Clearing any old widget stuffs
I/PowerWidget( 229): Setting up widget
I/PowerWidget( 229): Default buttons being loaded
I/PowerWidget( 229): Button list: toggleWifi|toggleBluetooth|toggleGPS|toggleSound
D/dalvikvm( 229): GC_EXTERNAL_ALLOC freed 52K, 51% free 2787K/5639K, external 0K/0K, paused 366ms
D/dalvikvm( 242): GC_CONCURRENT freed 404K, 51% free 2767K/5639K, external 0K/0K, paused 4ms+44ms
D/dalvikvm( 238): GC_CONCURRENT freed 404K, 51% free 2767K/5639K, external 0K/0K, paused 16ms+45ms
D/dalvikvm( 249): GC_CONCURRENT freed 405K, 51% free 2767K/5639K, external 0K/0K, paused 4ms+55ms
D/dalvikvm( 171): GC_EXTERNAL_ALLOC freed 237K, 40% free 4316K/7111K, external 1643K/1658K, paused 341ms
I/ActivityManager( 171): Start proc com.android.settings for broadcast com.android.settings/.widget.SettingsAppWidgetProvider: pid=283 uid=1000 gids={1015, 3002, 3001, 3003}
I/ActivityThread( 238): Pub com.android.launcher.settings: com.android.launcher.LauncherProvider
D/dalvikvm( 171): GC_EXTERNAL_ALLOC freed 230K, 40% free 4334K/7175K, external 2092K/2175K, paused 176ms
D/szipinf ( 242): Initializing inflate state
I/ActivityThread( 249): Pub mms: com.android.providers.telephony.MmsProvider
I/ActivityThread( 249): Pub sms: com.android.providers.telephony.SmsProvider
I/ActivityThread( 249): Pub telephony: com.android.providers.telephony.TelephonyProvider
D/dalvikvm( 242): GC_EXTERNAL_ALLOC freed 40K, 51% free 2816K/5639K, external 0K/0K, paused 409ms
I/ActivityThread( 249): Pub icc: com.android.phone.IccProvider
I/ActivityThread( 249): Pub mms-sms: com.android.providers.telephony.MmsSmsProvider
D/dalvikvm( 283): GC_CONCURRENT freed 407K, 51% free 2765K/5639K, external 0K/0K, paused 5ms+44ms
D/dalvikvm( 238): GC_EXTERNAL_ALLOC freed 43K, 50% free 2828K/5639K, external 0K/0K, paused 389ms
D/dalvikvm( 242): GC_FOR_MALLOC freed <1K, 51% free 2816K/5639K, external 821K/1333K, paused 295ms
I/dalvikvm-heap( 242): Grow heap (frag case) to 6.774MB for 841021-byte allocation
D/dalvikvm( 171): GC_EXTERNAL_ALLOC freed 145K, 40% free 4306K/7175K, external 2563K/2837K, paused 241ms
D/dalvikvm( 242): GC_CONCURRENT freed <1K, 44% free 3637K/6471K, external 821K/1333K, paused 4ms+45ms
D/szipinf ( 242): Initializing zlib to inflate
D/dalvikvm( 171): GC_EXTERNAL_ALLOC freed 26K, 41% free 4286K/7175K, external 2506K/3130K, paused 264ms
I/ActivityManager( 171): Start proc android.process.acore for content provider com.android.providers.userdictionary/.UserDictionaryProvider: pid=296 uid=10025 gids={3003, 1015}
I/StatusBarManagerService( 171): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@40785ed8
D/CallManager( 249): registerPhone(GSM Handler{406dbc48})
D/StorageNotification( 229): Startup with UMS connection false (media state unmounted)
I/StorageNotification( 229): UMS connection changed to false (media state unmounted)
V/AudioManager( 229): shouldVibrate, group: a126d48a-aaef-47c4-baed-7f0e44aeffe5 mode: DEFAULT
W/ActivityManager( 171): Unable to start service Intent { act=com.android.ussd.IExtendedNetworkService }: not found
D/dalvikvm( 171): GREF has increased to 301
I/ActivityThread( 296): Pub com.android.social: com.android.providers.contacts.SocialProvider
I/TelephonyRegistry( 171): notifyServiceState: 1 home null null null Unknown CSS not supported -1 -1RoamInd: -1DefRoamInd: -1EmergOnly: false
I/TelephonyRegistry( 171): notifyDataConnection: state=0 isDataConnectivityPossible=false reason=radioTurnedOff interfaceName=null networkType=0
I/TelephonyRegistry( 171): notifyDataConnection: state=0 isDataConnectivityPossible=false reason=gprsDetached interfaceName=null networkType=0
E/EthernetStateTracker( 171): DhcpHandler: DHCP request failed: Timed out waiting for dhcpcd to start
I/ActivityThread( 296): Pub applications: com.android.providers.applications.ApplicationsProvider
D/BT HSHFP( 249): Starting BluetoothHeadsetService
D/dalvikvm( 238): GC_EXTERNAL_ALLOC freed 75K, 49% free 2919K/5639K, external 504K/512K, paused 650ms
V/SipBroadcastReceiver( 249): start auto registration
D/dalvikvm( 249): GC_CONCURRENT freed 167K, 47% free 3044K/5703K, external 0K/0K, paused 4ms+34ms
D/dalvikvm( 296): GC_CONCURRENT freed 418K, 52% free 2753K/5639K, external 0K/0K, paused 28ms+33ms
I/ActivityThread( 296): Pub contacts;com.android.contacts: com.android.providers.contacts.ContactsProvider2
D/ViewConsistency( 238): AbsListView com.android.launcher.AllAppsGridView@406a6f20 enabled= true
I/Database( 296): sqlite returned: error code = 0, msg = Recovered 107 frames from WAL file /data/data/com.android.providers.contacts/databases/contacts2.db-wal
D/HomeLoaders( 238): load applications
D/HomeLoaders( 238): loading user items in Thread[main,5,main]
D/HomeLoaders( 238): --> starting workspace loader
D/HomeLoaders( 238): ----> running workspace loader (1)
I/Database( 238): sqlite returned: error code = 0, msg = Recovered 8 frames from WAL file /data/data/com.android.launcher/databases/launcher.db-wal
D/dalvikvm( 238): GC_EXTERNAL_ALLOC freed 47K, 48% free 2957K/5639K, external 893K/1028K, paused 206ms
I/ActivityThread( 296): Pub call_log: com.android.providers.contacts.CallLogProvider
I/ActivityThread( 296): Pub user_dictionary: com.android.providers.userdictionary.UserDictionaryProvider
D/dalvikvm( 238): GC_EXTERNAL_ALLOC freed 10K, 48% free 2966K/5639K, external 1950K/2453K, paused 228ms
W/AssetRedirectionManager( 171): No such resource found for com.android.camera:
D/dalvikvm( 171): GC_CONCURRENT freed 585K, 42% free 4421K/7495K, external 2618K/3818K, paused 6ms+30ms
I/Database( 296): sqlite returned: error code = 0, msg = Recovered 4 frames from WAL file /data/data/com.android.providers.userdictionary/databases/user_dict.db-wal
D/HomeLoaders( 238): ----> workspace loader 1 finished loading data
D/HomeLoaders( 238): ----> worskpace items=9
D/HomeLoaders( 238): ----> worskpace widgets=3
D/HomeLoaders( 238): --> done loading workspace; not stopped
D/HomeLoaders( 238): ----> items cloned, ready to refresh UI
D/HomeLoaders( 238): ----> loading applications from workspace loader
D/HomeLoaders( 238): --> starting applications loader unlocked
D/HomeLoaders( 238): ----> running applications loader (1)
D/HomeLoaders( 238): ----> onDesktopItemsLoaded()
D/Launcher( 238): ------> binding 9 items
D/Launcher( 238): ------> binding 3 widgets
D/Launcher( 238): ------> start binding items
D/HomeLoaders( 238): ----> cleared application list
W/ActivityManager( 171): Activity idle timeout for HistoryRecord{40863368 com.android.launcher/.Launcher}
D/OtaStartupReceiver( 249): Not a CDMA phone, no need to process OTA
I/ActivityManager( 171): Start proc com.bel.android.dspmanager for broadcast com.bel.android.dspmanager/.ServiceLaunchReceiver: pid=326 uid=10005 gids={3002}
D/PowerManagerService( 171): bootCompleted
I/SurfaceFlinger( 171): Boot is finished (23693 ms)
D/VoldCmdListener( 97): volume mount /mnt/sdcard
I/Vold ( 97): /dev/block/vold/179:1 being considered for volume sdcard
D/Vold ( 97): Volume sdcard state changing 1 (Idle-Unmounted) -> 3 (Checking)
W/logwrapper( 331): Unable to background process (No such file or directory)
I/StorageNotification( 229): Media {/mnt/sdcard} state changed from {unmounted} -> {checking}
I/SearchManagerService( 171): Building list of searchable activities
D/dalvikvm( 238): GC_CONCURRENT freed 121K, 47% free 3077K/5703K, external 2296K/3289K, paused 10ms+25ms
D/dalvikvm( 296): GC_CONCURRENT freed 225K, 49% free 2941K/5703K, external 0K/0K, paused 5ms+15ms
I//system/bin/fsck_msdos( 97): ** /dev/block/vold/179:1
I//system/bin/fsck_msdos( 97): ** Phase 1 - Read and Compare FATs
I//system/bin/fsck_msdos( 97): Attempting to allocate 591 KB for FAT
D/dalvikvm( 229): GC_EXTERNAL_ALLOC freed 212K, 49% free 2948K/5703K, external 506K/512K, paused 330ms
I//system/bin/fsck_msdos( 97): ** Phase 2 - Check Cluster Chains
I//system/bin/fsck_msdos( 97): ** Phase 3 - Checking Directories
I//system/bin/fsck_msdos( 97): ** Phase 4 - Checking for Lost Files
I//system/bin/fsck_msdos( 97): 26 files, 63106 free (126212 clusters)
I/Vold ( 97): Filesystem check completed OK
I/Vold ( 97): Filesystem type is: VFAT
I/PackageManager( 171): Updating external media status from unmounted to mounted
I/Vold ( 97): Device /dev/block/vold/179:1, target /mnt/sdcard mounted @ /mnt/secure/staging
D/Vold ( 97): Volume sdcard state changing 3 (Checking) -> 4 (Mounted)
D/VoldCmdListener( 97): asec list
I/PackageManager( 171): No secure containers on sdcard
I/StorageNotification( 229): Media {/mnt/sdcard} state changed from {checking} -> {mounted}
I/RecoverySystem( 171): No recovery log file
I/HeadsetService( 326): Starting service.
I/ActivityManager( 171): Start proc com.android.providers.calendar for broadcast com.android.providers.calendar/.CalendarReceiver: pid=338 uid=10002 gids={3003}
I/ActivityManager( 171): Start proc android.process.media for content provider com.android.providers.downloads/.DownloadProvider: pid=341 uid=10006 gids={1015, 2001, 3003}
I/Effect-Equalizer( 161): EQ_PARAM_NUM_BANDS OK
D/dalvikvm( 163): GC_EXPLICIT freed 11K, 51% free 2665K/5379K, external 0K/0K, paused 264ms
I/HeadsetService( 326): Phone status idle: enable DSP.
I/Effect-BassBoost( 161): New strength: 0
I/Effect-Equalizer( 161): Setting band 2 to 0
I/Effect-Equalizer( 161): Setting band 2 to 1
I/Effect-Equalizer( 161): Setting band 2 to 2
I/Effect-Equalizer( 161): Setting band 2 to 3
I/Effect-Equalizer( 161): Setting band 2 to 4
I/Effect-Equalizer( 161): Setting loudness correction reference to 100.000000 dB
D/dalvikvm( 163): GC_EXPLICIT freed <1K, 51% free 2665K/5379K, external 0K/0K, paused 289ms
D/dalvikvm( 326): GC_CONCURRENT freed 345K, 52% free 2699K/5575K, external 0K/0K, paused 4ms+20ms
D/dalvikvm( 163): GC_EXPLICIT freed <1K, 51% free 2665K/5379K, external 0K/0K, paused 246ms
I/ActivityThread( 341): Pub media: com.android.providers.media.MediaProvider
I/ActivityThread( 338): Pub com.android.calendar: com.android.providers.calendar.CalendarProvider2
D/dalvikvm( 338): GC_CONCURRENT freed 390K, 52% free 2746K/5639K, external 0K/0K, paused 6ms+27ms
I/Database( 338): sqlite returned: error code = 0, msg = Recovered 34 frames from WAL file /data/data/com.android.providers.calendar/databases/calendar.db-wal
D/dalvikvm( 341): GC_CONCURRENT freed 421K, 52% free 2751K/5639K, external 0K/0K, paused 4ms+24ms
V/MediaProvider( 341): Attached volume: internal
V/MediaProvider( 341): /mnt/sdcard volume ID: -245575889
I/ActivityManager( 171): Start proc com.android.deskclock for broadcast com.android.deskclock/.AlarmInitReceiver: pid=357 uid=10007 gids={}
V/MediaProvider( 341): Attached volume: external
I/ActivityThread( 341): Pub downloads: com.android.providers.downloads.DownloadProvider
D/Calendar( 338): missed alarms found: 0
I/ActivityThread( 341): Pub drm: com.android.providers.drm.DrmProvider
I/Database( 341): sqlite returned: error code = 0, msg = Recovered 8 frames from WAL file /data/data/com.android.providers.downloads/databases/downloads.db-wal
I/ActivityThread( 357): Pub com.android.deskclock: com.android.deskclock.AlarmProvider
I/Database( 357): sqlite returned: error code = 0, msg = Recovered 4 frames from WAL file /data/data/com.android.deskclock/databases/alarms.db-wal
D/dalvikvm( 357): GC_CONCURRENT freed 406K, 52% free 2753K/5639K, external 0K/0K, paused 7ms+5ms
I/ActivityManager( 171): Start proc com.koushikdutta.rommanager for broadcast com.koushikdutta.rommanager/.UpdateReceiver: pid=367 uid=10018 gids={1015, 3003}
I/PurchasingManager( 367): Purchasing Framework initialization complete. Build ID 1.0.3
D/PurchasingManager( 367): In App Purchasing SDK - Sandbox Mode: PurchasingObserver registered: com.clockworkmod.billing.b@406fe2b8
D/SandboxRequestHandler( 367): In App Purchasing SDK - Sandbox Mode: sendGetUserIdRequest
W/ActivityManager( 171): Unable to start service Intent { act=com.amazon.testclient.iap.appUserId flg=0x10000000 (has extras) }: not found
I/ActivityManager( 171): Start proc com.android.mms for broadcast com.android.mms/.transaction.MmsSystemEventReceiver: pid=377 uid=10020 gids={3003, 1015}
D/dalvikvm( 367): GC_CONCURRENT freed 384K, 51% free 2785K/5639K, external 0K/0K, paused 4ms+7ms
W/System.err( 367): java.io.FileNotFoundException: /sdcard/clockworkmod/.settings (No such file or directory)
W/System.err( 367): at org.apache.harmony.luni.platform.OSFileSystem.open(Native Method)
W/System.err( 367): at dalvik.system.BlockGuard$WrappedFileSystem.open(BlockGuard.java:232)
W/System.err( 367): at java.io.FileOutputStream.<init>(FileOutputStream.java:94)
W/System.err( 367): at java.io.FileOutputStream.<init>(FileOutputStream.java:165)
W/System.err( 367): at java.io.FileOutputStream.<init>(FileOutputStream.java:144)
W/System.err( 367): at com.koushikdutta.rommanager.as.a(Unknown Source)
W/System.err( 367): at com.koushikdutta.rommanager.DownloadService.onCreate(Unknown Source)
W/System.err( 367): at android.app.ActivityThread.handleCreateService(ActivityThread.java:2066)
W/System.err( 367): at android.app.ActivityThread.access$2500(ActivityThread.java:123)
W/System.err( 367): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:993)
W/System.err( 367): at android.os.Handler.dispatchMessage(Handler.java:99)
W/System.err( 367): at android.os.Looper.loop(Looper.java:130)
W/System.err( 367): at android.app.ActivityThread.main(ActivityThread.java:3835)
W/System.err( 367): at java.lang.reflect.Method.invokeNative(Native Method)
W/System.err( 367): at java.lang.reflect.Method.invoke(Method.java:507)
W/System.err( 367): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:864)
W/System.err( 367): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:622)
W/System.err( 367): at dalvik.system.NativeStart.main(Native Method)
W/System.err( 367): java.lang.Exception: no proof string
W/System.err( 367): at com.clockworkmod.billing.aa.a(Unknown Source)
W/System.err( 367): at com.koushikdutta.rommanager.as.c(Unknown Source)
W/System.err( 367): at com.koushikdutta.rommanager.DownloadService.b(Unknown Source)
W/System.err( 367): at com.koushikdutta.rommanager.DownloadService.onStart(Unknown Source)
W/System.err( 367): at android.app.Service.onStartCommand(Service.java:428)
W/System.err( 367): at android.app.ActivityThread.handleServiceArgs(ActivityThread.java:2160)
W/System.err( 367): at android.app.ActivityThread.access$2800(ActivityThread.java:123)
W/System.err( 367): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1002)
I/ClockworkModBilling( 367): Refreshing Market purchases...
I/ClockworkBilling( 367): com.clockworkmod.billing.BillingReceiver.REFRESH_MARKET
W/ActivityManager( 171): Unable to start service Intent { act=com.android.vending.billing.MarketBillingService.BIND }: not found
leaked IntentReceiver com.clockworkmod.billing.bh@406e8778 that was originally registered here. Are you missing a call to unregisterReceiver()?
E/ActivityThread( 367): android.app.IntentReceiverLeaked: Service com.koushikdutta.rommanager.DownloadService has leaked IntentReceiver com.clockworkmod.billing.bh@406e8778 that was originally registered here. Are you missing a call to unregisterReceiver()?
E/ActivityThread( 367): at android.app.LoadedApk$ReceiverDispatcher.<init>(LoadedApk.java:756)
E/ActivityThread( 367): at android.app.LoadedApk.getReceiverDispatcher(LoadedApk.java:551)
E/ActivityThread( 367): at android.app.ContextImpl.registerReceiverInternal(ContextImpl.java:826)
E/ActivityThread( 367): at android.app.ContextImpl.registerReceiver(ContextImpl.java:813)
E/ActivityThread( 367): at android.app.ContextImpl.registerReceiver(ContextImpl.java:807)
E/ActivityThread( 367): at android.content.ContextWrapper.registerReceiver(ContextWrapper.java:318)
E/ActivityThread( 367): at com.clockworkmod.billing.aa.a(Unknown Source)
E/ActivityThread( 367): at com.koushikdutta.rommanager.as.c(Unknown Source)
E/ActivityThread( 367): at com.koushikdutta.rommanager.as.a(Unknown Source)
E/ActivityThread( 367): Service com.koushikdutta.rommanager.DownloadService has
E/ActivityThread( 367): at com.koushikdutta.rommanager.DownloadService.b(Unknown Source)
E/ActivityThread( 367): at com.koushikdutta.rommanager.DownloadService.onStart(Unknown Source)
E/ActivityThread( 367): at android.app.Service.onStartCommand(Service.java:428)
E/ActivityThread( 367): at android.app.ActivityThread.handleServiceArgs(ActivityThread.java:2160)
E/ActivityThread( 367): at android.app.ActivityThread.access$2800(ActivityThread.java:123)
E/ActivityThread( 367): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1002)
E/ActivityThread( 367): at android.os.Handler.dispatchMessage(Handler.java:99)
E/ActivityThread( 367): at android.os.Looper.loop(Looper.java:130)
E/ActivityThread( 367): at android.app.ActivityThread.main(ActivityThread.java:3835)
E/ActivityThread( 367): at java.lang.reflect.Method.invokeNative(Native Method)
E/ActivityThread( 367): at java.lang.reflect.Method.invoke(Method.java:507)
E/ActivityThread( 367): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:864)
E/ActivityThread( 367): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:622)
E/ActivityThread( 367): at dalvik.system.NativeStart.main(Native Method)
I/ActivityThread( 377): Pub com.android.mms.SuggestionsProvider: com.android.mms.SuggestionsProvider
D/dalvikvm( 377): GC_CONCURRENT freed 396K, 51% free 2777K/5639K, external 0K/0K, paused 11ms+32ms
I/Database( 249): sqlite returned: error code = 0, msg = Recovered 37 frames from WAL file /data/data/com.android.providers.telephony/databases/mmssms.db-wal
D/dalvikvm( 171): GREF has increased to 401
I/ActivityManager( 171): Start proc com.cyanogenmod.stats for broadcast com.cyanogenmod.stats/.ReportingServiceManager: pid=401 uid=10024 gids={3003}
D/dalvikvm( 249): GREF has increased to 201
D/CMStats ( 401): BOOT_COMPLETED: Setting checkedin=false
I/ActivityManager( 171): Start proc com.android.bluetooth for broadcast com.android.bluetooth/.opp.BluetoothOppReceiver: pid=410 uid=10032 gids={3003, 3002, 3001, 1015}
I/ActivityThread( 410): Pub com.android.bluetooth.opp: com.android.bluetooth.opp.BluetoothOppProvider
D/dalvikvm( 410): GC_CONCURRENT freed 399K, 52% free 2721K/5639K, external 0K/0K, paused 4ms+4ms
I/Database( 410): sqlite returned: error code = 0, msg = Recovered 5 frames from WAL file /data/data/com.android.bluetooth/databases/btopp.db-wal
D/MediaScannerService( 341): start scanning volume internal
I/ActivityManager( 171): Start proc com.android.voicedialer for broadcast com.android.voicedialer/.VoiceDialerReceiver: pid=422 uid=10036 gids={3002}
D/dalvikvm( 171): GC_CONCURRENT freed 898K, 43% free 4544K/7943K, external 2618K/3818K, paused 6ms+43ms
D/VoiceDialerReceiver( 422): onReceive Intent { act=android.intent.action.BOOT_COMPLETED cmp=com.android.voicedialer/.VoiceDialerReceiver }
V/RecognizerEngine( 422): deleteCachedGrammarFiles /data/data/com.android.voicedialer/files/openentries.txt
I/ActivityManager( 171): Start proc com.android.email for broadcast com.android.email/.service.EmailBroadcastReceiver: pid=431 uid=10038 gids={3003, 1015}
I/Database( 341): sqlite returned: error code = 0, msg = Recovered 94 frames from WAL file /data/data/com.android.providers.media/databases/internal.db-wal
I/dalvikvm( 171): Jit: resizing JitTable from 512 to 1024
D/dalvikvm( 431): GC_CONCURRENT freed 406K, 52% free 2756K/5639K, external 0K/0K, paused 15ms+18ms
I/ActivityThread( 431): Pub com.android.email.provider: com.android.email.provider.EmailProvider
I/ActivityThread( 431): Pub com.android.email.attachmentprovider: com.android.email.provider.AttachmentProvider
I/ActivityThread( 431): Pub com.android.exchange.provider: com.android.exchange.provider.ExchangeProvider
I/Database( 431): sqlite returned: error code = 0, msg = Recovered 28 frames fr
D/EAS SyncManager( 431): !!! EAS SyncManager, onCreate
I/ActivityManager( 171): Start proc com.android.music for broadcast com.android.music/.MediaAppWidgetProvider4x2: pid=442 uid=10026 gids={3003, 1015}
D/EAS SyncManager( 431): !!! EAS SyncManager, onStartCommand
D/Email ( 431): BOOT_COMPLETED
I/Database( 431): sqlite returned: error code = 0, msg = Recovered 6 frames from WAL file /data/data/com.android.email/databases/EmailProviderBody.db-wal
D/MediaScanner( 341): prescan time: 848ms
D/MediaScanner( 341): scan time: 797ms
D/MediaScanner( 341): postscan time: 36ms
D/MediaScanner( 341): total time: 1681ms
D/MediaScannerService( 341): done scanning volume internal
D/dalvikvm( 442): GC_CONCURRENT freed 395K, 52% free 2754K/5639K, external 0K/0K, paused 15ms+5ms
D/EAS SyncManager( 431): !!! EAS SyncManager, stopping self
D/Eas Debug( 431): Logging:
D/EAS SyncManager( 431): !!! EAS SyncManager, onDestroy
I/ActivityManager( 171): Start proc com.android.quicksearchbox for broadcast com.android.quicksearchbox/.SearchWidgetProvider: pid=454 uid=10031 gids={3003}
I/ActivityThread( 454): Pub com.android.quicksearchbox.google: com.android.quic
I/ActivityThread( 454): Pub com.android.quicksearchbox.shortcuts: com.android.quicksearchbox.ShortcutsProvider
I/ActivityManager( 171): Start proc com.android.protips for broadcast com.android.protips/.ProtipWidget: pid=462 uid=10035 gids={}
D/dalvikvm( 454): GC_CONCURRENT freed 365K, 52% free 2751K/5639K, external 0K/0K, paused 4ms+5ms
I/ActivityManager( 171): Start proc com.cyanogenmod.cmparts for broadcast com.cyanogenmod.cmparts/.intents.LEDNotificationReceiver: pid=470 uid=1000 gids={1015, 3002, 3001, 3003}
D/dalvikvm( 462): GC_CONCURRENT freed 379K, 52% free 2728K/5639K, external 0K/0K, paused 4ms+34ms
D/dalvikvm( 163): GC_EXPLICIT freed 11K, 51% free 2665K/5379K, external 0K/0K, paused 236ms
D/dalvikvm( 163): GC_EXPLICIT freed <1K, 51% free 2665K/5379K, external 0K/0K, paused 135ms
I/ActivityThread( 470): Pub com.cyanogenmod.cmparts.provider.Settings: com.cyanogenmod.cmparts.provider.SettingsProvider
D/dalvikvm( 163): GC_EXPLICIT freed <1K, 51% free 2665K/5379K, external 0K/0K, paused 99ms
I/ActivityManager( 171): Start proc com.cooliris.media for broadcast com.cooliris.media/com.cooliris.cache.BootReceiver: pid=479 uid=10004 gids={1015, 3003}
D/dalvikvm( 470): GC_CONCURRENT freed 411K, 52% free 2738K/5639K, external 0K/0
I/ActivityThread( 479): Pub com.cooliris.picasa.contentprovider: com.cooliris.picasa.PicasaContentProvider
D/dalvikvm( 479): GC_CONCURRENT freed 424K, 52% free 2746K/5639K, external 0K/0K, paused 4ms+5ms
I/Database( 479): sqlite returned: error code = 0, msg = Recovered 10 frames from WAL file /data/data/com.cooliris.media/databases/picasa.db-wal
I/BootReceiver( 479): Got intent with action android.intent.action.MEDIA_MOUNTED
I/CPUSettings( 470): Restore disabled by user preference.
D/MediaScannerService( 341): start scanning volume external
I/BootReceiver( 479): Got intent with action android.intent.action.MEDIA_SCANNER_FINISHED
V/MediaScanner( 341): pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@406bd420
V/MediaScanner( 341): /pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@406bd420
D/MediaScanner( 341): prescan time: 228ms
D/MediaScanner( 341): scan time: 11ms
D/MediaScanner( 341): postscan time: 9ms
D/MediaScanner( 341): total time: 248ms
D/MediaScannerService( 341): done scanning volume external
D/dalvikvm( 479): GC_CONCURRENT freed 504K, 52% free 2785K/5767K, external 0K/0K, paused 4ms+5ms
I/CacheService( 479): Starting CacheService
I/CacheService( 479): Preparing DiskCache for all thumbnails.
I/CacheService( 479): DiskCache ready for all thumbnails.
I/ActivityManager( 171): No longer want com.android.settings (pid 283): hidden #16
E/ActivityThread( 367): Service com.clockworkmod.billing.BillingService has leaked ServiceConnection com.clockworkmod.billing.t@406a8ae8 that was originally bound here
E/ActivityThread( 367): android.app.ServiceConnectionLeaked: Service com.clockworkmod.billing.BillingService has leaked ServiceConnection com.clockworkmod.billing.t@406a8ae8 that was originally bound here
E/ActivityThread( 367): at android.app.LoadedApk$ServiceDispatcher.<init>(LoadedApk.java:938)
E/ActivityThread( 367): at android.app.LoadedApk.getServiceDispatcher(LoadedApk.java:833)
E/ActivityThread( 367): at android.app.ContextImpl.bindService(ContextImpl.java:898)
E/ActivityThread( 367): at android.content.ContextWrapper.bindService(ContextWrapper.java:347)
E/ActivityThread( 367): at com.clockworkmod.billing.BillingService.onSta
rtCommand(Unknown Source)
W/ActivityManager( 171): Unbind failed: could not find connection for android.os.BinderProxy@40917488
D/dalvikvm( 367): GC_EXPLICIT freed 297K, 52% free 2763K/5639K, external 0K/0K, paused 52ms
D/dalvikvm( 171): GC_CONCURRENT freed 1058K, 45% free 4546K/8135K, external 2618K/3818K, paused 6ms+9ms
D/dalvikvm( 229): GC_CONCURRENT freed 136K, 47% free 3026K/5703K, external 507K/1012K, paused 4ms+6ms
I/power ( 171): *** set_screen_state 0
D/LockPatternKeyguardView( 171): onScreenTurnedOff()
I/dalvikvm( 171): Jit: resizing JitTable from 1024 to 2048
D/dalvikvm( 171): GC_CONCURRENT freed 1023K, 44% free 4578K/8135K, external 2618K/3818K, paused 6ms+9ms
D/dalvikvm( 249): GC_CONCURRENT freed 403K, 49% free 3078K/6023K, external 0K/0K, paused 5ms+7ms
I have done this quote with "logcat|more" because the system didn't accept "logcat >pippo".
It has been a hard work and I hope it is ok for you :) ;)
And I had to split it in 2 messages as you know
aaa801
Re: Continuous scroll on RCA video
Fri Oct 12, 2012 11:15 pm
mhm can't see anything obvious to why it isn't loading properly, what shows on screen
karlenando
Sat Oct 13, 2012 7:28 am
:shock:
at the beginning it appears the logo of raspberry red and green.
after a few lines it disappears but the rpi still works.
then it pauses at the line: command "start" r=0
then it says something like .......... time will ......
and the screen comes black wil the rpi continues to work.
:shock:
cleverca22
Thu Mar 28, 2013 2:47 am
this looks similar to a problem i just ran into as well, the key things ive found so far are this (from above log)
and
what ive found, is that if yres is over 600, it fails to support page flipping (yres == yres_virtual) and everything just works fine
while trying to get page flipping to work, i used config.txt to force the hdmi to 800x600 (did you force 656x512, or is your tv just really sucky?)
and once i had the resolution low enough, it began to crash in the same spot, sending a broadcast before boot is done
the only 'fix' right now that i can see, is to bring yres over 600, but thats far from optimal
aaa801
Thu Mar 28, 2013 11:34 am
cleverca22 wrote:this looks similar to a problem i just ran into as well, the key things ive found so far are this (from above log)
and
that is ignorable, its due to there being no rtc hardware
cleverca22
Thu Mar 28, 2013 6:38 pm
its causing the entire system_server to crash, and on the 2nd start, the screen remains completely black
any idea why it would be solid black?
aaa801
Thu Mar 28, 2013 6:55 pm
cleverca22 wrote:its causing the entire system_server to crash, and on the 2nd start, the screen remains completely black
No idea, we havnt investigated rca due to it being a PITA
cleverca22
Thu Mar 28, 2013 9:32 pm
after digging arround more, ive found out that the framebuffer in razdroid is using 6 month old code with a bug in it
if the screen height is over 600, it will fail to support page flipping
the composite video out (on mine) runs at 656x416, so it doesnt trigger the bug, same as when i forced 800x600 on hdmi
the fact that the framebuffer is allowing page flipping, then triggers the screen being completely black
i have since updated the kernel framebuffer driver to fix that bug, and now it supports page flipping at 1280x1024, causing the same black screen bug as before
Return to “Android”
