aaa801
Gingerbread Image
Sat Jul 28, 2012 11:08 am
Just got the Ethernet menu added into this rom,
Network will probably need to be manually configured in the settings menu,
Once you have done this click the box off and on to start it properly.
Gingerbread cyanogen 7.2
2GB Image
http://rosefire.us/~razdroid/aaa801/Gin ... Manager.7z
bastian94
Re: Gingerbread Image
Sat Jul 28, 2012 2:21 pm
are cymogen mod 9 or 10 comming to the pi
aaa801
Sat Jul 28, 2012 2:56 pm
bastian94 wrote:are cymogen mod 9 or 10 comming to the pi
Not anytime soon, Its too slow without the broadcom drivers
edy_3dz
Mon Jul 30, 2012 11:35 am
After booting up (and showing the terminal), a blank black screen appears. There is no GUI?
I'm using the RCA Video output.
CrysisLTU
Mon Jul 30, 2012 2:56 pm
edy_3dz wrote:After booting up (and showing the terminal), a blank black screen appears. There is no GUI?
There is a GUI, but I think we didn't test composite video output... If you can, try HDMI - that should work.
aaa801
Mon Jul 30, 2012 7:15 pm
Can you remove the hdmi lines from config.txt?
raha0007
Tue Jul 31, 2012 9:10 am
I will try it, what will I have to configere about the lan connection?
aaa801
Tue Jul 31, 2012 12:59 pm
raha0007 wrote:I will try it, what will I have to configere about the lan connection?
Go into settings, theres a Ethernet Settings menu added
rpschmidtbma
Sun Jan 06, 2013 2:37 pm
I'm experiencing exactly the same with this image, only I'm using the HDMI output.
Last line in the terminal which I'm able to read is:
"Untracked PID 106 exited".
I've read the config but there isn't much in it either.
Warg
Sun Jan 06, 2013 7:59 pm
rpschmidtbma wrote:I'm experiencing exactly the same with this image, only I'm using the HDMI output.
That is odd, you should be getting a GUI after the "Untracked PID 106 exited"... Is your Pi hooked up to a network? If so, I'd appreciate it if you could pastie the output from logcat.
Note: Logcat output is pretty much required for us to be able to do anything about bugs/crashes etc, no matter what the bug is. If you don't know how to get it, read on!
To get logcat output, you'll need the Android SDK package. Once you have that, start the SDK Manager, select Android SDK Platform-tools (that's all you need unless you plan developing Android apps), wait for the download to finish, then open a command prompt and navigate to <your-sdk-directory>/platform-tools/. From there, run
adb connect <your-Pi's-ip>
and, if it connected properly,
adb logcat > ../log.txt
. Open the newly created <sdk-directory>/log.txt and paste its content somewhere where I can read it.
Thanks,
Warg
rpschmidtbma
Mon Jan 07, 2013 6:40 pm
Thanks for your reply.
It is indeed connected to the internet. I'll try to post Logcat outp a.s.a.p.
bennyweny1
Wed Jan 09, 2013 5:17 pm
I have installed this version of android with Ethernet. I use a wifi dongle in my pi but I can't seem to get the wifi to work. It says error. I need some instructions of what to do. Help would be appreciated :)
hundred
Thu Jan 10, 2013 8:03 am
bennyweny1 wrote:I have installed this version of android with Ethernet. I use a wifi dongle in my pi but I can't seem to get the wifi to work. It says error. I need some instructions of what to do. Help would be appreciated :)
I am having the same issue. I tried turning ethernet off, then wifi on. No luck. I know the wifi dongle works. I've used it with the pi running XBMC.
bennyweny1
Thu Jan 10, 2013 3:52 pm
I know my wifi dongle works but like haven't got a clue what to do. :(
Timeh
Fri Jan 18, 2013 10:56 pm
I'm experiencing exactly the same issue with the same setup, did anyone find out what is causing this?
Thanks in advance.
OMightyBuggy
Wed Jan 30, 2013 1:36 am
Can you update the OS or is the image with Ethernet the latest update? I only ask as this thread is old.
aaa801
Wed Jan 30, 2013 3:02 am
OMightyBuggy wrote:Can you update the OS or is the image with Ethernet the latest update? I only ask as this thread is old.
it will be updated when we have a stable build
fykos
Mon Feb 04, 2013 5:23 pm
Hello, I have a RaspberryPi that works seamlessly with Raspbian "wheezy". But with android 2 or 4 (gingerbread image) keeps crashing too, is very slow, can not even move. I leave just connected the HDMI and USB keyboard. What can it be? Thank you.
aaa801
Mon Feb 04, 2013 8:31 pm
fykos wrote:Hello, I have a RaspberryPi that works seamlessly with Raspbian "wheezy". But with android 2 or 4 (gingerbread image) keeps crashing too, is very slow, can not even move. I leave just connected the HDMI and USB keyboard. What can it be? Thank you.
Did you read any of the posts?
fykos
Tue Feb 05, 2013 4:32 pm
Yes, but neither is my case.
My own case is that android is slow, even disconnected from the internet.
aaa801
Tue Feb 05, 2013 9:21 pm
no hw acceleration at time, join irc channel #razdroid on freenode
ophirf15
Fri Jul 12, 2013 8:00 am
Hi, Im downloading the img right now.. I was thinking.. would i be able to install linux drivers on it? Im asking because I got a usb wifi adapter which needs to have a driver written to be able to work.. I got it working on raspibian (after long hours) so I wanted to ask if it is possible. Also does netflix work?
aaa801
Fri Jul 12, 2013 2:15 pm
ophirf15 wrote:Hi, Im downloading the img right now.. I was thinking.. would i be able to install linux drivers on it? Im asking because I got a usb wifi adapter which needs to have a driver written to be able to work.. I got it working on raspibian (after long hours) so I wanted to ask if it is possible. Also does netflix work?
Not usable for non devs
6677
Wed Jul 17, 2013 7:03 pm
ophirf15 wrote:Also does netflix work?
Consider the fact that android itself doesnt work. And then think about why that question is not even worth asking.
pavand
Mon Dec 16, 2013 6:50 am
I am trying to boot android OS(2.3) on R pi but I am getting some commands on the screen followed by rainbow color screen on the monitor . I changed the config text file in android OS but I am getting same thing . can you post the commands in the config text file in android OS based on that I will change the modes and groups in file .
Regards
pavan
Return to “Android”
