antiloquax
ASM code not working
Sun Jun 23, 2013 8:23 am
I was having a play with using macros and wrote this little demo program.
@ macros.s
@ experimenting with a couple of macros
.section    .data
nl:
    .byte 0xA   @ ascii codes
spc:
    .byte 0x20
char:             @ initially holds 65 / 'A'.
    .byte 0x41
.macro print_ch a         @ NB this macro clobbers registers r0, r1, r2 and r7.
mov r0, $1                   @ A function would be wiser. This is just a demo.
ldr r1, =\a
mov r2, $1
mov r7, $4
svc $0
.endm
.section  .text
.globl  _start
_start:
ldr r3, =char
mov r4, $0x41         @ this is the bit that confuses me. I wanted to load the number 65 from r3
                              @ but if I do "ldr r4, [r3]" the program just prints a capital 'A' and exits. This immediate load works,
                              @ but it's annoying when I have the number right there in "char".
print_ch nl
loop:
    print_ch char
    print_ch spc
    cmp r4, $0x5a       @ are we done?
    addlt r4, r4, $1
    strlt r4, [r3]            @ increment char variable.
    blt loop
print_ch nl
mov r7, $1
svc $0
.end
As you can see from my comments, my problem is I don't seem to know how to get the 65 from char into r4. :oops:
Also, if anyone with assembly code knowledge would mind looking at ths other post, I'd really appreciate it.
Question about number printing function.
Re: ASM code not working
Sun Jun 23, 2013 10:27 am
I think you need ldrb r4, [r3] as you only want to load a byte in from that address, not the whole 32-bit word around it which will undoubtedly be higher than 0x51.
antiloquax
Sun Jun 23, 2013 10:39 am
Thanks rpdom.
Of course, you are right.
