dharanivel
how to use system timer in arm-asm
Tue Dec 25, 2018 6:08 am
how to use system timer in arm-asm in rpi zero. can anyone help me to know about this.
wh7qq
Re: how to use system timer in arm-asm
Wed Dec 26, 2018 3:30 am
You might find "cron" to be easier/better supported.
dharanivel
Wed Dec 26, 2018 7:31 am
what is cron
wh7qq
Wed Dec 26, 2018 4:41 pm
Really?
dharanivel wrote:what is cron
Really?
man cron
Explains it much better than I can. Still, I did not notice the forum you posted in...perhaps your needs are more extreme,
LdB
Fri Dec 28, 2018 7:36 am
Assumes you are using linux :-)
In baremetal ignore that as there is no such thing as cron you have to pick setup the timer for irq or fiq vector.
boochow
Fri Dec 28, 2018 9:58 am
In the BCM2835 peripheral manual page 113, nothing is described concerning IRQ number for the system timer. According to the linux kernel code ( https://github.com/raspberrypi/linux/bl ... platform.h ), they are IRQ #0, #1, #2, and #3.
The code below works on RPi Zero and is written in C but probably you can easily translate it to ASM.
https://github.com/boochow/bare_matal_r ... timer-irq2
emilpopa
Sat Jan 19, 2019 8:49 pm
The response in depending on your context.
There are 4 sys timers defined. For each of them you have the registers : CS, CLO, CHI, and c0--c3 attached to system timer 0-3.
Each timer is connected to an interrupt, for PI 2 interrupt 0-3.
You have to follow this steps :
- select a timer (ex T1)
- enable the selected timer in the CS register (01 correspond to timer 1)
- set the free run counter (CLO, CHI) 64 bit Low, High.(depends on your application)
- reset timer match (write 01 in the CS register)
- clear the pending interrupt (IRQ pending 1, bit 1)
- enable the interrupt 1 corresponding to SYS_TIMER_1
You are now ready to receive the interrupts :
- in the IRQ routine :
- check the interrupt pending bit for t1 (interrupt controller)
- if it is set :
- check register CS bit 1 for t1 interrupt
- if is set :
- do your action (so fast you can do, because the interrupts are disabled)
- set again the CLO, CHI counter
- clear pending interrupt for t1 (c1)
- clear the pending interrupt 1 (interrupt controller)
- restore saved registers
- exit IRQ mode and restore the original core mode.
If you need the more information or code example, let me know !
Emil
