Gabgorozco
Urgent help thanks!
Mon Dec 10, 2018 2:36 am
Question: I am coding up the ladder game on my Raspberry Pi 3. This program is in assembly language. I have...
This program is in assembly language. I have a breadboard hooked up to the PI
There are a set of 6 LEDS and one button.
The LEDS will flash, and if you push the button as they flash you will move up to the next LED.
Ideally, I would like each LED to turn solid and stop blinking to show where you are currently at.
Maybe not have them all flash at once, but one at a time and have each one turn solid as you move up... whatever would be easier.
As of right now I have them all flashing together at the same time but can't figure out how to incorporate the button. Maybe some kind of interrupt to make the button turn solid.
Here is the code
.equ INPUT, 0
.equ OUTPUT, 1
.equ LOW, 0
.equ HIGH, 1
.data
.balign 4
Intro: .asciz "Ladder Game\n"
ErrMsg: .asciz "Didnt work... Exiting Now.\n"
pin2:   .int 2 //WiringPi pin 2 is equal to BCM 27
pin3:    .int    3 //WiringPi pin 3 is equal to BCM 22
pin4:    .int    4 //WiringPi pin 4 is equal to BCM 23
pin5:    .int    5 //WiringPi pin 5 is equal to BCM 24
pin6:    .int    6 //WiringPi pin 6 is equal to BCM 25
pin7: .int 7 //WiringPi pin 7 is equal to BCM 4
end:   .int 5
button: .int 26
i: .int 0
delayMs: .int 250
OUTPUT = 1
.text
.global main
.extern printf
.extern wiringPiSetup
.extern delay
.extern digitalWrite
.extern pinMode
.extern digitalRead
main: push {lr}
// printf( "Ladder Game..." ) ;
ldr r0, =Intro
bl printf
// if (wiringPiSetup() == -1) {
// printf( "Didnt work... Exiting Now" ) ;
// exit (1) ;
bl wiringPiSetup
mov r1,#-1
cmp r0, r1
bne init
ldr r0, =ErrMsg
bl printf
b done
// pinMode(pin, OUTPUT) ;
init:
   ldr    r0, =button
   ldr    r0, [r0]
   mov    r1, #OUTPUT
   bl    pinMode
ldr r0, =pin2
ldr r0, [r0]
mov r1, #OUTPUT
bl pinMode
   ldr r0, =pin3
ldr r0, [r0]
mov r1, #OUTPUT
bl pinMode
   ldr r0, =pin4
ldr r0, [r0]
mov r1, #OUTPUT
bl pinMode
   ldr r0, =pin5
ldr r0, [r0]
mov r1, #OUTPUT
bl pinMode
   ldr r0, =pin6
ldr r0, [r0]
mov r1, #OUTPUT
bl pinMode
   ldr r0, =pin7
ldr r0, [r0]
mov r1, #OUTPUT
bl pinMode
// for ( i=0; i<10; i++ ) {
ldr r4, =i
ldr r4, [r4]
mov r5, #10
forLoop:
cmp r4, r5
bgt done
// digitalWrite(pin, 1) ;
ldr r0, =pin2
ldr r0, [r0]
mov r1, #1
bl digitalWrite
   ldr r0, =pin3
ldr r0, [r0]
mov r1, #1
bl digitalWrite
   ldr r0, =pin4
ldr r0, [r0]
mov r1, #1
bl digitalWrite
   ldr r0, =pin5
ldr r0, [r0]
mov r1, #1
bl digitalWrite
   ldr r0, =pin6
ldr r0, [r0]
mov r1, #1
bl digitalWrite
   ldr r0, =pin7
ldr r0, [r0]
mov r1, #1
bl digitalWrite
// delay(250) ;
ldr r0, =delayMs
ldr r0, [r0]
bl delay
   ldr r0, =delayMs
ldr r0, [r0]
bl delay
   ldr r0, =delayMs
ldr r0, [r0]
bl delay
   ldr r0, =delayMs
ldr r0, [r0]
bl delay
   ldr r0, =delayMs
ldr r0, [r0]
bl delay
   ldr r0, =delayMs
ldr r0, [r0]
bl delay
// digitalWrite(pin, 0) ;
ldr r0, =pin2
ldr r0, [r0]
mov r1, #0
bl digitalWrite
   ldr r0, =pin3
ldr r0, [r0]
mov r1, #0
bl digitalWrite
   ldr r0, =pin4
ldr r0, [r0]
mov r1, #0
bl digitalWrite
   ldr r0, =pin5
ldr r0, [r0]
mov r1, #0
bl digitalWrite
   ldr r0, =pin6
ldr r0, [r0]
mov r1, #0
bl digitalWrite
   ldr r0, =pin7
ldr r0, [r0]
mov r1, #0
bl digitalWrite
// delay(250) ;
ldr r0, =delayMs
ldr r0, [r0]
bl delay
add r4, #1
b forLoop
done:
pop {pc}
I need a piece of code to make the lights turn solid. Thanks!
Re: Urgent help thanks!
Mon Dec 10, 2018 6:28 am
Here is the code
.equ INPUT, 0
.equ OUTPUT, 1
.equ LOW, 0
.equ HIGH, 1
.data
.balign 4
end:   .int 5
button: .int 26
i: .int 0
delayMs: .int 250
OUTPUT = 1
.text
.global main
.extern printf
.extern delay
.extern pinMode
.extern digitalRead
main: push {lr}
ldr r0, =Intro
bl printf
// exit (1) ;
bl wiringPiSetup
mov r1,#-1
cmp r0, r1
bne init
ldr r0, =ErrMsg
bl printf
b done
init:
   ldr    r0, =button
   ldr    r0, [r0]
   mov    r1, #OUTPUT
   bl    pinMode
ldr r0, =pin2
ldr r0, [r0]
mov r1, #OUTPUT
bl pinMode
   ldr r0, =pin3
ldr r0, [r0]
mov r1, #OUTPUT
bl pinMode
   ldr r0, =pin4
ldr r0, [r0]
mov r1, #OUTPUT
bl pinMode
   ldr r0, =pin5
ldr r0, [r0]
mov r1, #OUTPUT
bl pinMode
   ldr r0, =pin6
ldr r0, [r0]
mov r1, #OUTPUT
bl pinMode
   ldr r0, =pin7
ldr r0, [r0]
mov r1, #OUTPUT
bl pinMode
ldr r4, =i
ldr r4, [r4]
mov r5, #10
forLoop:
cmp r4, r5
bgt done
ldr r0, =pin2
ldr r0, [r0]
mov r1, #1
bl digitalWrite
   ldr r0, =pin3
ldr r0, [r0]
mov r1, #1
bl digitalWrite
   ldr r0, =pin4
ldr r0, [r0]
mov r1, #1
bl digitalWrite
   ldr r0, =pin5
ldr r0, [r0]
mov r1, #1
bl digitalWrite
   ldr r0, =pin6
ldr r0, [r0]
mov r1, #1
bl digitalWrite
   ldr r0, =pin7
ldr r0, [r0]
mov r1, #1
bl digitalWrite
// delay(250) ;
ldr r0, =delayMs
ldr r0, [r0]
bl delay
   ldr r0, =delayMs
ldr r0, [r0]
bl delay
   ldr r0, =delayMs
ldr r0, [r0]
bl delay
   ldr r0, =delayMs
ldr r0, [r0]
bl delay
   ldr r0, =delayMs
ldr r0, [r0]
bl delay
   ldr r0, =delayMs
ldr r0, [r0]
bl delay
ldr r0, =pin2
ldr r0, [r0]
mov r1, #0
bl digitalWrite
   ldr r0, =pin3
ldr r0, [r0]
mov r1, #0
bl digitalWrite
   ldr r0, =pin4
ldr r0, [r0]
mov r1, #0
bl digitalWrite
   ldr r0, =pin5
ldr r0, [r0]
mov r1, #0
bl digitalWrite
   ldr r0, =pin6
ldr r0, [r0]
mov r1, #0
bl digitalWrite
   ldr r0, =pin7
ldr r0, [r0]
mov r1, #0
bl digitalWrite
// delay(250) ;
ldr r0, =delayMs
ldr r0, [r0]
bl delay
add r4, #1
b forLoop
done:
pop {pc}
Duplication is not required or needed you original post is here:
viewtopic.php?f=72&t=228423&p=1400945#p1400945
adieu
My other Computer is an Asus CS10 ChromeBit
