erlkingh
[SOLVED] Unable to cross compile assembly
Sat Dec 01, 2018 7:21 pm
I'm unable to compile using arm-none-eabi-gcc toolchain.
The error I get is:
boot.S: Assembler messages:
boot.S:7: Error: ARM register expected -- `mrs x0,mpidr_el1'
boot.S:8: Error: ARM register expected -- `and x0,x0,#0xFF'
boot.S:9: Error: selected processor does not support `cbz x0,master' in ARM mode
boot.S:16: Error: ARM register expected -- `adr x0,bss_begin'
boot.S:17: Error: ARM register expected -- `adr x1,bss_end'
boot.S:18: Error: ARM register expected -- `sub x1,x1,x0'
The flags are:
-mcpu=cortex-a53 -mfpu=neon-fp-armv8 -mneon-for-64bits -mfloat-abi=hard -mlittle-endian -munaligned-access
I've spent quite a lot of time resolving other issues so I'm probably missing something with this one.
DavidS
Re: Unable to cross compile assembly
Sun Dec 02, 2018 3:39 pm
Looks like you are using AARCH64 instructions. Are you targetting a system running in AARCH64?
Though you may have to tell gcc that you are targetting AARCH64 as it likely defaults to standard ARM, even when targeting the A53.
RPi = Way for me to have fun and save power.
100% Off Grid.
Household TTL Electricity Usage = 1.4KW/h per day.
500W Solar System, produces 2.8KW/h per day average.
erlkingh
Sun Dec 02, 2018 3:46 pm
Yeah, that was the case.
I changed the toolchain to aarch64-linux-gnu, everything works fine.
My mistake was downloading a toolchain for the Cortex-RM processors.
Guess It’s solved now.
Return to “Bare metal, Assembly language”
