Assembly challange
Posted: Thu Nov 29, 2018 7:55 pm
by bzt
Dear All,
I'd like to propose a very fun challange. We are looking for the Assembly equivalent of
if (AArch32) {
    - or -
if (AArch64) {
    - or -
if (!AArch32) {
    - or -
if (!AArch64) {
What makes this challange funny is that the resulting binary must work on both A32 and A64 just as-is. It either has to do nothing (or do irrelevant or insignificant operations without throwing an abort) on 32 bit platforms, and branch on A64, or vice-versa. It doesn't matter if the Assembly can be compiled on A32 or on A64, or if it uses only ".long" directives. The point is, only one interpretation (either 32 or 64) must branch, and not the other. If the same binary could be interpreted as a valid Thumb32 code too, that's a bonus, but not required.
You should read the ARM DDI0487 documentation to find the answer, but other sources can be used as well. If there's no solution until new year's eve, I'll present mine. If there are multiple solutions, then the shorter wins, or the one that also works on T32 and does the same as in A32 mode. If all are the same size and all are supported by the same execution modes, then I'll let the community decide which one is more elegant, and in lack of that, the first posted wins.
Good luck and happy opcode hunting! :-)
bzt
Re: Assembly challange
Posted: Fri Nov 30, 2018 1:21 am
by LdB
There is an obvious solution which is to pseudocode the opcodes, is that a valid or are we restricted to actual true assembler?
To some degree GCC already has pseudocoding in things like "ldr x1, =somevar"
The obvious most elegant answer to me is a simple include of a file with the assembler in it, there is exactly one if statement required.
I do it all the time with SmartStart32.S and SmartStart64.S being my omipresent library functions which are matched :-)
Posted: Fri Nov 30, 2018 6:50 am
by Paeryn
I don't think bzt means one source file that will compile for either instruction set, rather they want one single binary file which can be executed regardless of whether the processor is in A32 or A64 (and possibly even T32) mode whilst using the same entry point. So you would need to choose instructions carefully so that when it is read in say A64 it jumps over the A32 code and when in A32 it would run the A32 code and then jump over the A64 code.
An interesting experiment.
Posted: Fri Nov 30, 2018 6:58 pm
by DavidS
If only I had an assembler that supported AARCH64, sounds like a fun challenge, create a FAT binary for the ARM AARCH32 and AARCH64, should be interesting.
Posted: Sat Dec 01, 2018 12:03 pm
by jahboater
I hate to say it, but if you have Raspbian, the included assembler "as" happily supports AARCH64.
Harder to test though :(
Posted: Sat Dec 01, 2018 12:08 pm
by DavidS
The solution is simple, use a b ARM-32bit instruction to jump over the AARCH64 branch to entry (with a distance less than 16). On the instruction 0xEA00000n where n is the branch distance would be a ARM32 Branch, on AARCH64 it is a ANDS Rn, R0, R0 effective encoding (if I am reading the opcodes correctly for AARCH64), so benign.
So this is a simple challenge, even if I missread the opcodes there is a large enough difference between the two that finding the one that will branch on one of them should be a simple task for anyone that actually plays in AARCH64.
Posted: Sat Dec 01, 2018 12:11 pm
by DavidS
DavidS wrote: The solution is simple, use a b ARM-32bit instruction to jump over the AARCH64 branch to entry (with a distance less than 16). On the instruction 0xEA00000n where n is the branch distance would be a ARM32 Branch, on AARCH64 it is a ANDS Rn, R0, R0 effective encoding (if I am reading the opcodes correctly for AARCH64), so benign.
jahboater wrote: I hate to say it, but if you have Raspbian, the included assembler "as" happily supports AARCH64.
I do not use as which is actually gas because I do not like the syntax, personal pref.
Posted: Sat Dec 01, 2018 1:11 pm
by bzt
Yes, you are right, the point is to differentiate between AArch32 and AArch64 in run-time to have a fat binary.
And yes, @DavidS you're on the right track with the ANDS :-) And yes, this it isn't hard at all, I've deliberatly picked an easy task to involve more forum members.
There's no Assembler requirement, you can use anything you want. I wrote that ".long" (or "dd") directive is a solution too so that you can even use instructions not supported by a particular Assembler. You're welcome to use fasm-arm if you don't like gas syntax.
But you made your point, I'd like to clearify that the solution must contain which Assembler to use.
The winner post should contain code something like:
; compile with (assembler)
_start:
   ? ? ?                               ; branch if executed as A64
   ... some A32 code ...
AArch64:
   ... some A64 code ...
As I've said, the opposite solution is equally correct.
_start:
   ? ? ?                               ; branch if executed as A32
AArch32:
Hope you enjoy this challange,
bzt
Posted: Sun Dec 02, 2018 9:45 am
by LdB
1.) Formally you can read the CPU id for an ARM6 & ARM7 if it's either of those it has to be AARCH32.
2.) So then you come to an ARM8 It's still actually trivial the hint is look at the behaviour with an unknown opcode :-)
For example if GCC have done there job properly try
void __builtin_trap (void);
If you need further help when you pull an exception look at PSTATE
http://infocenter.arm.com/help/index.js ... JGFCI.html
So you can easily identify an ARM8 is in AARCH32 or AARCH64 mode.
Put all you functions behind a function pointer and set the function pointers based on mode ... job complete.
I not only obscure the processor modes in that way with my SmartStart code I obscure the Pi model base address and all the different video modes for the console in the same way.
I can offer one bit of code you will need without doubt being this .. it allows an ARM6 thru but drops an ARM7, ARM8 AARCH32 out of hyp mode. The opcode are set by literal because an ARM6 assembler doesn't have a clue about those opcodes.
mrs r0,cpsr		// Fetch the cpsr register which includes CPU mode bits
and r1, r0, #0x1F		// Mask off the CPU mode bits to register r1
cmp r1, #CPU_HYPMODE	// Check we are in HYP_MODE
bne .NotInHypMode	// Branch if not equal meaning was not in HYP_MODE
bic r0,r0,#0x1F		// Clear the CPU mode bits in register r0
orr r0, r0, #CPU_SVCMODE_VALUE// SVC_MODE bits onto register with Irq/Fiq disabled
msr spsr_cxsf,r0			// Hold value in spsr_cxsf
add lr,pc,#4				// Calculate address of .NotInHypMode label
/* I borrowed this trick from Ultibo because ARM6 code running on an ARM7/8 needs this opcode  */
/* The ARM6 compiler does not know these instructions so it is a way to get needed opcode here */
/* So our ARM6 code can drop an arm7 or arm8 out of HYP mode and run on an ARM7/8.             */
/* Native ARM7/8 compilers already understand the OPCODE but do not mind it this way either	   */
.long 0xE12EF30E		// "msr ELR_hyp, lr" Set the address to ELR_hyp
.long 0xE160006E		// "eret" Elevated return which will exit at .NotInHypMode in SVC_MODE
.NotInHypMode:
Posted: Thu Dec 06, 2018 5:14 pm
by bzt
So your solution is A32, but throws an UD abort when executed on A64, if I understand correctly?
This is not good, because you haven't set up the vbar_elX system registers. Now you need a code which does not abort on A32 but sets vbar on A64. Without that you branch to an undefined location. Otherwise good thinking!
Btw, __builtin_trap() is compiled into a BRK #0 instruction on A64 (haven't tried A32).
Cheers,
bzt
Posted: Thu Dec 06, 2018 7:10 pm
by LdB
Okay how about this .. you end up executing 32 bit code at 0x8000 even in AARCH64
.data
.globl I_AM_64_BIT;
I_AM_64_BIT : .4byte 0;
.org 0x8000
// If you start here you are AARCH32 from ARMSTUB.S, ARMSTUB7.S
// If I_AM_64_BIT = 1 ... you are actually now AARCH32 running under AAARCH64
// Execute your 32 bit code whatever you want
.org 0x80000
AArch32_Mode_SVC     EQU		0x13
// if you start here you are AARCH64 EL2 from ARMSTUB8.S
// First set I_AM_64_BIT  to 1
MOV X0,  =I_AM_64_BIT
MOV W1,  #1
STR W1, [X0]
// NOW SET EL1 to 32 bit
  MOV      x2, #1              ; NS bit
  MOV      x3, #(1 << 10)      ; RW bit
  MRS      x1, SCR_EL2
  BIC      w1, w1, w2          ; Clear NS bit (EL1 is secure)
  BIC      w1, w1, w3          ; Clear RW bit (EL1 is AArch32)
  MSR      SCR_EL2, x1
 // Now jump to 32 bit mode at normal start
  LDR      x1, =0x8000
  MSR      ELR_EL2, x1
  LDR      x1, =AArch32_Mode_SVC
  MSR      SPSR_EL2, x1
  ERET
Posted: Fri Dec 07, 2018 8:30 pm
by bzt
Don't get me wrong, your previous idea was not bad at all! I said "good thinking", because all I meant it was incomplete. (But could be a valid solution if start.elf clears vbar for sure (so it's always 0 after boot), because using kernel_old we can make start.elf to load our code at 0, meaning we can put a "b AArch64" in the right position.)
About this, this is an interesting idea too! Never considered the addresses 0x8000 and 0x80000 to be used for distintion before :-) Sounds promising, although I'm not sure how you suggest to put those two assembly in the same binary. Org is just an Assembler directive, it does not influence where start.elf loads our code (that only depends on the filename being kernel7.img or kernel8.img).
Cheers,
bzt
Posted: Sat Dec 08, 2018 7:46 am
by LdB
It is easy merge into a single file .. very common thing
http://infocenter.arm.com/help/index.js ... 15171.html
Posted: Thu Dec 13, 2018 1:20 pm
by bzt
Okay, but that's not what I meant. :-)
Let's assume we have a binary, how do you tell start.elf to load one part of it at 0x8000 when booted in A32 mode and another part to 0x80000 when booted in A64 mode? As far as I know the execution will start at the same first byte of the binary in both cases. (The obvious solution is to store one part in kernel7.img and the other in kernel8.img, but the challange is to have one binary which works regardless it's named kernel7.img or kernel8.img).
Btw, I'm looking for code that could determine it's own position in memory and jump depending on that. So far I have no luck, seems to be very difficult, but I haven't give up yet. :-)
Cheers,
bzt
Posted: Thu Dec 13, 2018 2:55 pm
by LdB
Ok for my solution you manually build the image always assuming 0x8000 and position 64 bit code at 0x80000
Then you force start address via config.txt with the line
kernel_address = 0x8000
You can also force 64bit if you need .. look for reference
https://www.raspberrypi.org/documentati ... xt/boot.md
I doubt you can do it by opcode as the new aarch64 opcode set is called a64.
search something like "a64 opcode bitfield" should give you the a64 layout
search something like "a32 opcode bitfield" should give you the a32 layout
I am guessing there is a set of zero opcodes that match as the encodings bitfields differ.
A64 also does not support thumb so my guess is your idea is dead in water.
Posted: Fri Dec 14, 2018 10:09 pm
by bzt
That's what gives the beauty of this challange, everybody doubts it is possible :-) But I can assure you, it's doable. I wouldn't made this challange if I weren't sure there's at least one good solution. That would be unfair, even evil to start a race without a finish line :-) And although DavidS hasn't presented a full assembly entry yet (hope he will), he already hinted a solution.
And thanks for the search tip, but I already have a fair knowledge on ARM instruction encoding. Enough to wrote an extremely compact (ca. 65k) disassembler for all the ARMv8.2 instructions ;-) But anyway, I appreciate your help! Thank you!
Well, it doesn't matter whether A64 supports thumb or not, because the CPU is using only one of the modes at any given time. The challange is, can you create a binary that can be interpreted as A32, A64 and (optionally) in T32 mode as well, and passes control to different addresses in each mode?
Cheers,
bzt
Posted: Sat Dec 15, 2018 4:10 am
by LdB
hehe good work to you if it's doable.
It was one of those things my immediate reaction knowing the opcode bitfield patterns was there is no chance, and there was a more obvious way around it.
Be interested to see what you come up with, so don't forget to post it :-)
Posted: Sat Dec 15, 2018 1:34 pm
by DavidS
bzt wrote: That's what gives the beauty of this challange, everybody doubts it is possible :-) But I can assure you, it's doable. I wouldn't made this challange if I weren't sure there's at least one good solution. That would be unfair, even evil to start a race without a finish line :-) And although DavidS hasn't presented a full assembly entry yet (hope he will), he already hinted a solution.
I guess this means I actually have to submit something, without having an AARCH64 capable assembler. I already know it is easily doable, not as much of a challenge as the old 68K/x86/z80 CP/M 3 ISA FAT challenge of the early 1980's (that was a difficult one, and I do not remember the solution anymore), though in all three cases the executable was a flat binary having the first instruction at the start of the executable.
Ok I guess I will have to write something, and do the AARCH64 bit in AARCH64 machine language. 7th project added to the currently coding list.
Posted: Sat Dec 15, 2018 6:30 pm
by bzt
@LdB: actually I have already written that post: describing the whole process I've used to find the solution, for educational purposes. I'm just waiting a bit longer before I post it to give chance to others. I hope you'll find my post interesting :-)
@DavidS: no, no, you don't "have to". It would be great if you could send a post with a code block that fulfills these criteria, but I don't want you to think that's a must in any way (I'm already convinced you could do it, don't you worry :-)). If you don't do it happily for fun, the whole thing worths nothing! This is just a funny game, nothing more.
Btw the first similar challange I had (about twenty years ago or so) was to write a .COM file which would run as a DOS command file as well as a VMS DCL script. I had some sleepless nights, because DOS COM is a binary, but DCL COM is a script file with ASCII text only, but I have solved that puzzle! :-)
Cheers,
bzt
Posted: Wed Jan 02, 2019 12:46 pm
by bzt
Happy New Year to you all! :-)
As promised, here's the solution. I will explain the whole process for educational purposes.
First, let's try to use an A64 jump. Luckily both A32 and A64 uses 32 bit instruction encodings, so we only need to compare a dword. A64 branch is encoded as 000101 plus 26 bits for relative offset. In A32, that encodes an STR.NE instruction, but with more bits. Because we don't want to use huge jumps, we must encode those bits as 0, and only use the A32 argument encoding for the offset in A64. Therefore the final solution is 000101000000, and a 20 bits offset:
0001 010 0 0 0 0 0 nnnn tttt iiiiiiiiiiii STR.NE Rt, [Rn], #+i12	;A32 instruction
000101 000000iiiiiiiiiiiiiiiiiiii B i20				;A64 instruction
This could work, but it has a serious side-effect in A32 mode: depending on register values and the state of flags, it could cause a memory corruption. So let's keep looking.
Second, check the A32 jump. Encoded as 11101010 plus 24 bits offset. Similar to the previous case, in A64 encoding there're more bits to encode the ANDS instruction, meaning we must use 11 bits which leaves us with 21 bits long offset for the jump.
11101010 000iiiiiiiiiiiiiiii B i21		;A32 instruction
11101010 00 0 mmmmm iiiiii nnnnn ddddd ANDS Xd, Xn, Xm LSL #i5	;A64 instruction
This does not have any other side effects than clobbering registers, which is perfect.
We are not done yet! The code will be loaded at two different locations in memory, and most assemblers cannot mix A32 and A64 instructions within a single source. That means we have to use two source files (and two assemblers) at a minimum, including one's output as binary in the other's. This poses a new problem, namely how to set up ORG directives for those two sources. We have a jump instruction and two codeblocks. If we use binary include for the second codeblock, then we need to know the size of the first in advance. Therefore I suggest to use the binary include for the first codeblock. Because our jump is A32, that settles things: the first codeblock (that we jump over) will be the A64 block. Now how to do a binary include? Most assemblers have such feature, for example in ARM ASM, it's called "incbin". Keeping that in mind, the full solution is:
; stub64.s
; compile with A64 assembler
ORG 0x80004	; we have to add 4 because of the branch/ands instruction
; ...here comes the A64 code...
; stub32.s
; compile with A32 assembler
ORG 0x8000
b a32mode
incbin "stub64.bin"
a32mode:
; ...here comes the A32 code...
BONUS:
With a highly advanced assembler, like fasm-arm, we can switch modes within one source file, and we can also calculate offsets dynamically. Thus, a single source file solution would be:
; compile with fasm-arm
ORG 80000h
start:
USE32
b a32mode
USE64
a32mode:
ORG 8000h + (a32mode-start)
USE32
We've used a few tricks here. The first ORG is before the start label, therefore both "start" and "a32mode" labels are calculated as 0x80000 offsets. This allows us to calculate the size of the A64 codeblock for the second ORG directive. Also to properly calculate the offset for the first branch, the "a32mode" label must preceed the second ORG. That will be calculated as jump to 0x8000X, but we don't care since A32 stores jump labels as relative offsets. No matter where the code is loaded (0x8000 or 0x80000) the relative jump to "a32mode" is the same :-)
That's all, hope you've enjoyed this little challenge! Cheers,
bzt
